Differential Install
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
2004-2007 Cadillac CTS-V General Discussion Discussion, Differential Install in Cadillac CTS-V Series Forum - 2004 - 2007; So I am going to replace my diff soon and I am wondering if it is an easy swap? I ...
    jweymar's Avatar
    jweymar is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Eforce LS3 V
    Apr 2008
    802
    So I am going to replace my diff soon and I am wondering if it is an easy swap? I dont want to do it myself but can any mechanic do it?
    I would like to just take it to a local shop rather than drive 2+ hours back to RPM who is great but just a PITA.
    What would you guys do?
  2. #2
    lunarx's Avatar
    lunarx is offline Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s
    Aug 2006
    SoCal
    1,728
    Re: Differential Install
    Whats up with your diff?
    You might want to try Ryan Cunningham of Cunningham Motors.
    He is in Lake Elsinore which could possibly be a better drive for you.
  3. #3
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,823
    Shane (lollygagger8) did a great writeup with pictures of his diff replacement.
    Even if you don't want to do it yourself, I'd print that off and take it to your local shop as added information ... it can't hurt (unless their ego is bruised a bit).
    EDIT: Nice to hear from you Ernie!
  4. #4
    jweymar's Avatar
    Apr 2008
    802
    Quote Originally Posted by lunarx View Post
    Thanks! Nice to hear from you!
    My diff has developed clunk on top of clunk, and is whining loud. So I pulled the trigger and I am a new proud owner of Jims steel differential
    No more clunk, no more worries, no more waiting for someone to come up with a solution that works like factory.
    ohhhh, and no more money!
  5. #5
    silver02stang's Avatar
    silver02stang is offline Cadillac Owners Enthusiast
    Automobile(s): LS6 CTS-V
    Oct 2008
    Appleton, WI
    39
    548
    The diff swap really isn't that big of a deal. Take your time if its the first time doing it. I did mine about 2 weeks ago and it would have been done in a day if I hadn't run into a couple headaches. Listed to Rand49er and make sure to have the write-up on hand. In the write up he mentions a 21mm Gearwrench. INVALUABLE! Also, I overlooked the breather valve which is the freakin reason it took me two days to do the install. The local dealers were closed and its a dealer only item.
    Did the swap in my driveway with the car on jackstands. No "special" tools really to speak of.
  6. #6
    PISNUOFF Guest
    Very straight forward. You don't need to remove the upper ball joints to get the axles out of the hubs and if you can't find a 21mm gear wrench, get a 13/16 gear wrench as it's essentially the same size but easier to find. I've had axles out several times and removed my diff once. I could do it in about 4 hours now, while laying on a garage floor.
  7. #7
    maxspeed96ct is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V
    Aug 2009
    31
    1,048
    Congrates on the steel diff !
  8. #8
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    You could do it yourself no problem. Just take your time and follow the instructions.
    http://www.cadillacforums.com/forums...f-install.html
    There's the writeup w/o pics and I just reposted this with the pics in the right places like 3 weeks ago, but I can't find it. Search engine sucks on this forum, but I'll keep looking.
    Just print off the instrustions and hand em to the mechanic and say here, or if you don't want to use em wipe your a$$ with em or whatever. Can't hurt. They might just use em!
    Ya a 21mm gear wrench get's used on most of the bolts on the suspension.......GET ONE.
  9. #9
    Apr 2008
    Indiana
    4,913
    Found the one with pics.......
    http://www.cadillacforums.com/forums...-write-up.html
    Tony,Jimmy, or Heavy can you add this to the FAQ/Do it yourself Link? Thanks fellaz
  10. #10
    lunarx's Avatar
    Aug 2006
    SoCal
    1,728
    Quote Originally Posted by jweymar View Post
    Wow, the Steel Diff.
    I could have used one of those.
    I just had my diff completely rebuilt by RPM Motors because it had a clutch pack problem and then somehow developed a whine after the diff bushing install.
    Definetly let us know how that Steel Diff turns out.
    Can it really eliminate all clunking?
  11. #11
    lunarx's Avatar
    Aug 2006
    SoCal
    1,728
    Quote Originally Posted by rand49er View Post
    Rand,
    Good advice as usual.
    It's always a pleasure to see your posts.
    I miss not bieng on here more.
  12. #12
    Apr 2008
    Indiana
    4,913
    You have a steel diff and you aren't posting pics?? Cmon now, don't hold out on us
  13. #13
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,823
    Quote Originally Posted by lollygagger8 View Post
    Lucky stiff.
  14. #14
    Willsol is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jul 2010
    25
    Id like to know where to purchase a steel diff.
  15. #15
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    Will, it's a one off....only one in existence I believe.
  16. Remove Advertisements
