Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Differential Install
  1. #16
    PISNUOFF Guest
    Re: Differential Install
    Quote Originally Posted by Willsol View Post
    Id like to know where to purchase a steel diff.
    'Nutz' had that one patterned after the stocker. It's much beefier and he was trying to get people to sign up to have them machined. I believe he's working on making it out of a piece that's closer to the final dimensions to cut down on the amount of machining. You might be able to find a couple threads on here that were started by him.
  2. #17
    jweymar's Avatar
    jweymar is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Eforce LS3 V
    Apr 2008
    802
    here it is
  3. #18
    Nutz's Avatar
    Nutz is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS-V a tuxedo with a jetpack!
    Oct 2007
    Northeast Ohio hammer down
    49
    2,460
    Quote Originally Posted by lunarx View Post
    Can it really eliminate all clunking?
    Clunk is essentially gone, as I was able to use an aluminum block in replacement for the cheesy factory rubber front support, due to the strength that the steel front support area has now.
    Quote Originally Posted by deedubb View Post
    Will, it's a one off....only one in existence I believe.
    Correct. Sadly, no investors or commitment to purchase could be shaken up every time I tried in many areas. Mr. Weymar was quite persistent and certainly financially capable. Let's hope now that he has the torch, it can be lit on the west coast. I'm also very excited that an LS3 powered car is being mated up with my diff.
  4. #19
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    I jizz in my pants everytime I see that thing!
    And no more of these?? Noooooooo!!!
  5. #20
    jweymar's Avatar
    Apr 2008
    802
    Well Im going with rpm to do the install, and I might do heads and cam at the same time!
    I'm excited to put some power down without cringing every second...
    Now I gotta get some 305s under that thing
  6. #21
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    just did my diff today. about 1.5 day of slow easy going. take your time and not trouble. the write up make very straight forward. I did get hung as i did remove my ball joint from the hub. i had to get a ball joint pry bar. already had axle rebuilt and replaced that while in there. added a UUC bushing. I am no mechanic and did it in my garage about 18" off floor. I never worked on a car before my V and i dove straight in mod hell!
    metric short and deep sockets
    19, 21mm gear wrench
    18" breaker bar
    pry bar to pop axles out
    be sure to have a vent (if diff is new)
    dead blow and brass hammer
    metric hex wrenches
    the touch and go part was raising the diff on a jack while trying to get it in position. Literally used my leg to jack it up while laying on my side to lift in and get driver axle into diff and then into position. (I did diff leaving entire driver side together). if you got any questions.. ask. I have not driven it yet to evaluate because i am still doing my cutouts.
    save mad coin and have pride and doit yourself... unless im missing something there are no real tricks.
  • You may not post replies
