Intermittent no crank - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
2004-2007 Cadillac CTS-V General Discussion Discussion, Intermittent no crank in Cadillac CTS-V Series Forum - 2004 - 2007; don't order from GMpartsdirect.com whatever you do!...
  1. #16
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    Re: Intermittent no crank
  2. #17
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8
    May 2008
    35
    1,354
    No, no, I won't. I haven't ordered from them since their "heyday" if they had one. I have a guy up in NH that I like to use (from my B-body days) who gives me dealer cost + 10%. I also have some sway bar bushings on order with Luke @ Lindsay. For internet orders, I use Rockauto a bit, at least for my 93 Caprice, 91 Ranger and my wife's 2000 Malibu. Then there's my local Napa. Autozone occasionally. Yeah I get parts from just about everywhere.
  3. #18
    branland's Avatar
    branland is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V SC
    Jun 2008
    San Diego
    54
    399
    I had a similar problem. Turned out to be the starter or the solenoid. When I had the old starter out, I could jumper it and it would work, but when I put it back in the car I got nothing.
    Like Houdini, since I've had the new Starter, zero problems.
  4. #19
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    On one of my previous cars, corrosion between the engine and trans was causing an intermittent voltage drop that would prevent the car from starting. Something to consider.
  5. #20
    May 2008
    35
    1,354
    That sounds like the starter was bolted onto the trans, not the engine, so the ground return path had a high resistance.
  6. #21
    Dec 2006
    42
    37,302
    I think the starter was bolted to the engine, but the ground connection went through the trans. That was a front drive transaxle though.
    My point is with modern automobiles, anything is possible. Including problems.
  7. #22
    dedeaux89 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Aug 2010
    Bay Area California (Suisun)
    167
    Does anyone have the part number for the clutch start switch that way I have more reassurance that I'm ordering the right part. If anyone could recommend the best website I'd appreciate it.
  8. #23
    Aug 2010
    167
    I put the clutch start switch in and it worked like magic.... For a few days now it's doing this same problem.. I replaced that one wire on the starter already is a new starter my next step or should I try something else cheaper before I gamble on it being the starter or not
  9. Remove Advertisements
