new gen 4 diff, which oil? also broken out of the box ugh - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 71
2004-2007 Cadillac CTS-V General Discussion Discussion, new gen 4 diff, which oil? also broken out of the box ugh in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by ewill3rd JDB, what did you just say? The additive is required from the factory. Stay away from ...
  1. #46
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Re: new gen 4 diff, which oil? also broken out of the box ugh
    Quote Originally Posted by ewill3rd View Post
    Stay away from that dealer or educate them....
    That's what I thought (from reading this forum), but they said that they checked and it was not required to be put into the new diffs.
    Is there a new GM fluid? PN? Someone earlier posted GM fluid, Part #89021677. That's the # on my invoice. They seem to think that this fluid works fine in the gen 4 diff.
    Is there an 800 number Cadillac? ...because I want a 100% answer.
    http://www.cadillac.com/pages/mds/he...r/contactUs.do ?
    I'll be calling on Monday.
  2. #47
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    The new diff is structurally different but it is still a limited slip.
    That dealer doesn't know what in the world they are talking about.
    The specifications I posted somewhere apply to replacement diffs as well.
    It won't really do any short term damage but they need to get the modifier in there or the clutch packs are going to start grinding and making you nuts.
    That is the right fluid, but they have to add 4 oz. of the friction modifier.
  3. #48
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    i got a new (what i assume is a new gen 4, i have not seen paperwork yet) diff friday. ive noticed that it sings a bit... that is, with the radio down and listening closely... seems worst in 4th on light decel around 40-50..other gears not as much noise if any at all.
    should a new diff be whisper quiet or will all of these have 'some' noise? i recall the gen3 replacement i got in 08 being quieter than this.
    im not worried about it breaking, just that perhaps the correct fluids were not added up front. i want to preserve this thing...
    the car has not been driven hard at all since install and i dont plan on romping it for weeks.....this is going to be VERY hard not to do considering i had the cs grey mounts installed at the same time......
  4. #49
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,199
    Quote Originally Posted by CadzillaTN View Post
    A new differential should be silent - if it is not I would complain about that immediately. The absence of the limited slip additive, as you know, only causes chatter in slow corners. Whining indicates the ring-gear-to-pinion clearance is wrong or the gears are worn (which presumably is not possible if the unit is truely new).
  5. #50
    CadzillaTN's Avatar
    Apr 2008
    2,061
    thanks, ill take it back.
  6. #51
    kirchbed's Avatar
    kirchbed is offline Cadillac Owners Fanatic
    Sep 2008
    Washington, DC
    337
    You should. I've been driving w/ a new one since Friday and it's absolutely silent.
  7. #52
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    That's what I figured too, since it makes no sense. BUT, I called a different dealer today and they too said that they're not using the additive now.
    I'm tempted to buy it or the one that Amsoil sells and put it in myself.
  8. #53
    JNR
    JNR is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Jun 2010
    SoCal
    44
    55
    Does the fluid already contain a LSD additive, perhaps? I know some of the aftermarket ones do, but I've personally never had luck using only that and end up having to put additional LSD additive in, to avoid the chattering and lopsided wheel feeling.
    I changed the diff oil this weekend (love having the plug on the bottom!) and used Mobil 1 and the equa torque stuff and seems to work pretty well. The hardest thing was determining when it was actually full, since my pump's tube wouldn't go all the way into the threaded hole (next time will put a nipple on the end of the hose that will protrude in more), so halfway thru it started dripping out...IIRc, took about 1 1/2 quarts.
    I looked around and couldn't find a p/n on the housing...So, does anybody know where I could find out the p/n I have? (it's a 2007 and as I mentioned above, the guy claims the dealer upgraded it, but I'm skeptical). No issues, but I like to know what I have.
  9. #54
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    rear of diff upper passenger side mounting arm. it is a white getrag label 2"x3" at least. should not be able to miss it
  10. #55
    JNR
    Jun 2010
    SoCal
    44
    55
    Thanks, I will check it out next time I'm under there.
  11. #56
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Yep, brought the '04 in to Lindsay the week before V-Day I and my expiring warranty. Motor mounts, diff bushing and a whole slew of items to get the V tech ready were to be done. As I was on the way down the day before to pick it up, I stopped on the NJ TP to check in on the forums to see how everything was going.
    and wouldn't you know it, Bill thought the whine was too loud and was able to get me a new(latest gen) unit. Heaven is Lindsay Cadillac...
  12. #57
    CadzillaTN's Avatar
    Apr 2008
    2,061
    Quote Originally Posted by darkman View Post
    parts dept told my writer it was a new unit. the service mgr rode with me to listen...he said it would be very odd for it to be bad out of the box but acknowledged it was possible and he would return it if so...
    it sang over rush hour traffic in 4th, and when i tested it tonight with the seats down it howled like a wolf on decel from 48 down to 40 in both 3rd and 4th. didnt try 5th.
    im bringing her back in for another issue.. they're going to put the stethoscope on 'to rule out anything else'. dont see what it could be
  13. #58
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    Quote Originally Posted by thebigjimsho View Post
    Did they use the additive?
  14. #59
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    We always put in the additive because we are literate.
    Seriously though, it really boils my blood to hear you guys tell me that dealers are saying that the diff "doesn't need" friction modifier.
    Ask them to show you in writing where it says that the updated diff doesn't require the friction modifier!
    I have shown you guys in print where the limited slip diff calls for it.
    If they say it isn't limited slip tell them to raise the car, put it in gear with the park brake released and ask them to spin a rear wheel.
    After they give themselves a hernia have them explain why it isn't a limited slip and if it is, why it wouldn't require the modifier that it calls for in the manual for a limited slip diff.
    Be polite
  15. #60
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    PS: I just blasted them on the GM tech forum for this.
    Can't wait to hear the excuses....
  16. Remove Advertisements
