[Help!] Battery not Charging Problem - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
Like Tree4Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, [Help!] Battery not Charging Problem in Cadillac CTS-V Series Forum - 2004 - 2007; Has your alternator ever been checked ? On the flip side, some people here have experienced incorrect alternator assessment before....
  1. #31
    POS VETT is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2010
    44
    274
    Re: [Help!] Battery not Charging Problem
  2. #32
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    No not yet, aside from pulling my battery cables and the car still runs, and the dic voltage remaining constant.
    First i'm going to make sure all alternator wires are well away from my plug wires, I know some are close, and I have NGK iridium plugs. Then I'm going to check and retighten the alternator main line to battery connection, seems secure but I never removed it. I'll also try unplugging my horn and see if that works.
    If none of the above works, I'll get my alternator checked.
    If it checks out, the next time I get a tune I'll get the code shut off, it maybe just an ecm tune glitch like stated on the corvette forum.
  3. #33
    tiremarx723 is offline Awaiting Email Confirmation
    Automobile(s): CTS-V
    Apr 2009
    34
    10
    I had this same problem the past few weeks, until it finally died. Props to the fellow who spoke of checking the orange wire for voltage when the key is in the on position. This led to 0 volts on the connector in this position versus 11-12v about 1 inch past the connector on the wire where i peeled the orange wire back a little. All I did was simply pop out the connector pin from the connector and resoldier a wire onto the connector pin, pushed the pin back into the connector and then resoldierd the newly soldierd wire and pin to the factory wire (which is really short) from the wire harness. Everything is back to normal now.
    For those of you that are getting this message and your battery is still charging, but says it is not. it is most likely the gray wire that has lost its connection not the orange wire.
    Cost to fix = $0
    However I ordered a new alternator anyways, guess Ill have to return it.
    Thanks for the posts on this topic, it really helped me solve this problem
    tyma1026 likes this.
  4. #34
    samson1 is offline Cadillac Owners Member
    Automobile(s): 2005 cts-v
    Apr 2012
    58
    1
    I know it been a long time since you had battery problem, But I need your help, going for the gray and orange wires I need the connector, My Cadiallic dealer said no part like that, help me if you can, Thnaks Greatly jim hanna in greater northwest arkansas 2005 v series 44,000 mile and havcing problems, what about how many push button connectors are holding on the front bumper and big expensive plastic parts on the corners, welcome to GM at it best,
  5. #35
    bcarv87's Avatar
    bcarv87 is offline Cadillac Owners Fanatic
    Automobile(s): 05` maggied V
    Oct 2007
    MA
    142
    I just bought one from Luke for $30, pm him
  6. #36
    killernoodle is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V --- the RED one :)
    May 2010
    31
    281
    I just wanted to chime in and say I had the exact same problem. Battery voltage would fluctuate between 13.9 and 11.x, got random battery not charging messages, red battery light on the dashboard, and when the voltage dropped significantly I got some messages about servicing the stability control system.
    My engine mounts are going out and I read a couple posts in this thread and they were exactly right. The pigtial that plugs into the alternator had a break in the orange wire. I spliced a new wire in its place and got everything fixed up. It charges constantly at 14v now! It took about an hour to get to the wire, I had to remove the airbox to get to the connector, and the connector fought pretty hard. It took a pick to lift the piece of the connector that locks it in place so I could pull it out. After this, the fix was pretty simple, but I went the extra mile to make sure it wouldn't happen again. I depinned the connector with a needle and soldered longer leads on the pins, then used some small crimp connectors to reattach it to the harness. I then added some electrical tape and split loom to make sure everything stayed in place and undamaged.
    Thanks everyone who posted in this thread!
  7. #37
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Well, this thread saved me a big headache.
  8. #38
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,822
    That's funny. Well, maybe not so much. I got this message yesterday.
    Thanks, Tony, for bumping this thread.
  9. #39
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by rand49er View Post
    Post what voltage you get out of the pink wire.
  10. #40
    hefftone's Avatar
    hefftone is offline Cadillac Owners Member
    Automobile(s): LS2-V
    Jul 2014
    Dallas, Ga
    84
    Clear! Necro bump.
    I replaced my alternator after mine failed a test at oreilly. I am getting the battery light, yet DIC shows voltage at 14+. The battery light will turn off intermittently, if I am hammering downing, or if low speed idle in 3 gear (slow traffic.)
    I just pulled the harness plug. What voltage should the orange wire show? And the grey....rest for continuity only?
  11. #41
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    See attached.
  12. #42
    Ozburb is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Jun 2014
    Australia
    52
    9
    Guys,
    I just experienced the same problem on my 04 Escalade. I installed electric radiator fans in lieu of the original mech fan. The wiring loom included adding two more pins into the PCM connectors.
    After that, the car started with the battery not charging alarm. It even threw up the check engine light, and the engine started missing intermittently. The problem just about sent me mad.
    Replaced the alternator. And the fusible link (original was very tight, and the stress had weakened the lug on the alternator such that it broke when I removed the old alternator). Thought it was grounding, so I doubled up on a few of the ground connections to the engine. My scanner wouldn't talk to the PCM, which was a seperate problem with my scanner (the PCM obviously talks OK to the instrument cluster).
    battery voltage was around 14V with the engine running, so the battery is charging OK.
    Volt drop between the alternator and the battery pos was around 0.2V. Between the engine block and the battery neg was around 0.1V so both OK.
    Next I unplugged the PCM again and checked the wiring continuity for the generator control wires to the PCM. All OK.
    I then re-assembled the PCM back into the car, making sure the plugs on the PCM were well and truly properly seated in.
    Started the car, and everything is OK now. Fixed.
    ie, the problem appears to have been some weak contacts in the PCM plugs?
  13. #43
    CTSvOH's Avatar
    CTSvOH is offline Cadillac Owners Member
    Automobile(s): 2004 CTSv
    Jun 2016
    dayton
    33
    13
    I am having the same problem, battery not charging light keeps coming on. At the orange wire I am getting 10.6 volts when the ignition is on and nothing at the grey. Should the grey wire be grounded? If it is, I am not getting a ground from it. I have stripped the tape off the two wires and checked for ground in the grey wire until it reaches the main wire loom where it comes out of. Does anyone know where this grey is grounded at? I don't really want to start cutting into my wire harness to find out. I am using a power probe 3 to do all my testing fyi and this thing is really handy for doing this kind of stuff.
  14. Remove Advertisements
