Custom Short Shifter Ordering Process. - Page 49
Page 49 of 53 FirstFirst ... 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 LastLast
Results 721 to 735 of 793
Like Tree33Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Custom Short Shifter Ordering Process. in Cadillac CTS-V Series Forum - 2004 - 2007; Did you get my core? ---------- Did you get my core? Scott...
  1. #721
    ranger2525's Avatar
    ranger2525 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts-v,2003 escalade,2000 corvette conv. 1996 harley, 20
    Jun 2010
    Overland Park, Kansas
    52
    142
    Re: Custom Short Shifter Ordering Process.
    Scott
  2. #722
    PISNUOFF Guest
    Quote Originally Posted by ranger2525 View Post
    Scott
    I got an email from UPS stating I got a package from Kansas. I'm just leaving my 'day' job after being there for 12 hours and I have a 70 mile drive home so I probably won't make it to my shop to see it and refund your core charge until tomorrow.
  3. #723
    Rez Rider's Avatar
    Rez Rider is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Sep 2013
    Oregon
    46
    I am interested in buying one of these shifters from you. How long is the current wait? and if I read correctly the bushings now have to be purchased separately? from somewhere else? I can't remember the total price (including refundable core charge) could you tell me just so I have the latest updated price? Also if you could send me the instructions to ptdavisjr@gmail.com, so I can make sure I can do this! lol! thanks in advance for all your help!!
  4. #724
    PISNUOFF Guest
    That is correct. I was getting the UUC bushings from Luke at Lindsay Cadillac. There are a couple vendors that supply similar polyurethane bushings. The cost is $185 plus a refundable $115 core charge, total to send is $300. I can ship a shifter to you on Saturday. The specifics for ordering are also in the first post of this thread.
    Thanks,
    Brian
  5. #725
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    do the instructions you include with the shifter require using the bushings from Lindsay Cadillac? And would you have a link to buy them from him? sorry but a little new to the forum and not quite familiar with all the vendors. I just want to make sure that the installation is correct so I don't have any of the noise issues that I have read some of the other shifters have after installation. Also I may want the extra 1" shorter as mentioned in previous posts. would that be a problem? thanks again for all the help!
  6. #726
    PISNUOFF Guest
    The polyurethane bushings are not required but recommended. The noise issues are not an issue with my shifters as there is a rubber connection between two halves of the shifter which absorbs the noise and vibration. Below is the contact info for two vendors that sell the polyurethane shifter bushings.
    Thanks,
    Brian
    Lindsay Cadillac - Luke
    (703) 647-8670
    Creative Steel
    www.creative-steel.com
  7. #727
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    ok, thanks for the info! I will take a look at the instructions you sent me and will let you know when I have sent my payment. thanks!
  8. #728
    V for victory is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2013 Dodge Durnago R/T
    Mar 2011
    Levittown, PA
    51
    243
    Hey Brian,
    Just ordered my CS bushings, now your shifter.
    PM sent
    Bam! ordered up....
    PISNUOFF likes this.
  9. #729
    07cadv's Avatar
    07cadv is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2014
    Ft Rucker Al.
    326
    Payment sent Brian. Thanks!
  10. #730
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Hey Brian not sure if u remember me saying in your thread I had quite a bit of shifter noise? Well I just got done with the tranny mount and motor mounts and the car feels great, just sounds awful shifting. Normal aggressive shifts but no power shifting or slamming and it is very whiney and noises from transmission. And just sitting in neutral running if I pull into any gear and push or pull it makes a little noise. But when driving it is verrrry verrrry loud.
    What are your thoughts i wish it had stops for the shifts .
    Maybe I should take it all apart and check it out.
    I tried sending you a PM but your inbox is full
  11. #731
    PISNUOFF Guest
    Hi Nick:
    I cleared out some PM's immdiately and tried to PM you but your box was full also. LOL You can always get ahold of me by email br_1868(at)hotmail(dot)com.
    It is not common for one of my shifters to be doing what your's is doing. Obviously the installation of motor and trans mounts has raised the back of your trans even more. Did you install the new bushings I sent you last week? Some people have experienced noise after installation of a new trans mount or insert irregardless of the shifter that is installed. Typically this goes away after the mount 'settles'. I think there is definitely something else going on with yours. It sounds exactly like your center linkage bar is hitting the boss on the top/rear of your trans. Please double check that the nylon pivot ball housing is installed with the 'relief' facing downward. This will raise the entire shifter assembly about 1/4" into the cabin. You should be able to see this from inside the center console. The top side of the pivot housing should be flat. I'll send you an entirely new shifter or we can find some other resolution that satisfies you. Sorry for your troubles.
    Brian
  12. #732
    Becker's Avatar
    May 2013
    31
    391
    Word on customer support. Thx Brian but I won't get a chance to touch it until next week or the following week. I just sent an email. I do question the install now, I'm sure your shifter is not the issue. You have only made hundreds of them, issue free hah
    Again, thx so much for your customer service. If you made every general mod for the V I'd get them from you!
  13. #733
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    Hey there... I'm wanting todo the hurst shifter mod soon and was wondering what the turn around time is? I see hurst offers an option for a black knob which I prefer.
    Also does $275 include you getting the shifter, modifying it and shipping to me? (Sry if you have answered this 10x I'm just still not clear.
  14. #734
    PISNUOFF Guest
    Quote Originally Posted by H-town_V View Post
    http://www.cadillacforums.com/forums...hifters-v.html
    The $275 includes everything. I order the shifter, modify it and ship it to you. I will have to order a kit with the black knob for you today. It will most likely show up at my place on Friday so it'll be able to ship Monday. If it shows up on Thursday I'll ship it out to you on Friday.
  15. #735
    H-town_V's Avatar
    Feb 2013
    341
    Quote Originally Posted by PISNUOFF
    http://www.cadillacforums.com/forums...hifters-v.html The $275 includes everything. I order the shifter, modify it and ship it to you. I will have to order a kit with the black knob for you today. It will most likely show up at my place on Friday so it'll be able to ship Monday. If it shows up on Thursday I'll ship it out to you on Friday.
    That's a great deal!!! I'm gonna wait a couple weeks before I place the order (sry if I made it seem like I needed it urgently). If you do get a black one and modify it by Monday...well I might not be able to resist.
  16. Remove Advertisements
