Custom Short Shifter Ordering Process. - Page 33
Page 33 of 53 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 481 to 495 of 793
Like Tree33Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Custom Short Shifter Ordering Process. in Cadillac CTS-V Series Forum - 2004 - 2007; You can tell by looking under the car where it attaches to the shift linkage. The three on the right ...
  1. #481
    PISNUOFF Guest
    Re: Custom Short Shifter Ordering Process.
    The three on the right are stock shifters and the one on the left has had a piece of pipe welded on the bottom.
    Here are the same stock shifters above after my modification. As you can see, there is a stainless steel insert pressed between the nylon pivot ball and the rectangular base. You will be able to see this from under the car.
  2. #482
    Silencertk is offline Cadillac Owners Member
    Automobile(s): CTS-V V1
    Oct 2012
    Germany
    36
    97
    so........ can the "swap" can be done entirely from inside the car ? In other words, I dont need a lift or anything. Just regular set of tools, a little some mechanical skills and time. Is that correct? My car will be going on hibernation here in a couple of days. I'm going to go ahead and pay up and add myself to the list - since wait time will be irrelevant.
  3. #483
    PISNUOFF Guest
    You will have to unbolt and bolt from the underside of the car. Most people do it by putting the car on jack stands. You can always remove yours and send it to me for modification, that eliminates waiting in line and dealing with the core charge. Simply send $185 via PayPal and send me your shifter. I can email you directions for removing your shifter.
  4. #484
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by PISNUOFF View Post
    Please try to include the small items attached to the rectangular end, these include two nylon bushings, two rubber seals and one metal sleeve.
    I may end up sending you my stock shifter and compare it to my UUC.
    so do you reuse the rubber seals and nylon bushings or do you replace them with new parts ? My seals would need replaced for sure.
  5. #485
    PISNUOFF Guest
    Quote Originally Posted by SevillianSTS View Post
    Yes, that's a really old quote. I do not need them and replace them. That was the reason for the price increase way back when. You can send me yours for modification and compare the difference between your UUC or sell it to me if you are happy with your UUC.
  6. #486
    Aug 2005
    Northern IN
    1,006
    Whats the general consensus on shortening the stalk along with this mod ?
    Will the top of the shifter sit lower than where the UUC is now ?
    Does your video have the stalk shortened, or is that just the insert on the lower end ?
    Thanks,
    BTW... did you happen to see the video I posted on the other thread with my shifter movement with the engine off ?
  7. #487
    PISNUOFF Guest
    The stalk is shortened in that vid along with the lower end modifications. I like it lower than stock. The UUC leaves the knob at the stock height.
  8. #488
    DaveSRX is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jan 2005
    Harrisburg Pa
    150
    Can you email me the instructions for removing my shifter as well so I can order yours? blkz06vette@yahoo.com
  9. #489
    jakegee01 is offline Cadillac Owners Member
    Oct 2012
    26
    4
    I would like to buy one of your shifters. I can send you mine if I can get some removal instructions? Will I need to order bushings? Thanks
  10. #490
    PISNUOFF Guest
    Quote Originally Posted by jakegee01 View Post
    You will need to order polyurethane ones if you want them. I don't carry them anymore.
  11. #491
    Oct 2012
    26
    4
    So how much will it be? About how long do you expect if I wait to send you my shifter?
  12. #492
    PISNUOFF Guest
    If you send me your shifter, I'll get it done right away and send it back. There is no waiting in line for a core if you send me your core to modify.
  13. #493
    Oct 2012
    26
    4
    So how much do I need to send?
  14. #494
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Dec 2008
    Huntsville
    49
    291
    Brian may have additional cores now. I sent mine in and it looks like one or two others have as well.
    I did want to say that dealing with Brian was a very positive experience. He promptly answered questions and all transactions were timely and positive. Also, as most everyone else has noted this is a great mod. I didn't realize how much I didn't like the stock part until I did this mod.
  15. #495
    PISNUOFF Guest
    $185
    Quote Originally Posted by sssnake View Post
    All cores have been modified and are back out. I don't have any just sitting around, people are still on the waiting list.
  16. Remove Advertisements
