Custom Short Shifter Ordering Process. - Page 13
Page 13 of 53 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 181 to 195 of 793
Like Tree33Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Custom Short Shifter Ordering Process. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Houdini Can anyone else see the above video? I've tried two computes, 3 browsers, and my phone... ...
  1. #181
    PISNUOFF Guest
    Re: Custom Short Shifter Ordering Process.
    Quote Originally Posted by Houdini View Post
    Can anyone else see the above video? I've tried two computes, 3 browsers, and my phone... can't see it.
    Sorry, trying to do it with my phone. Try this.
  2. #182
    PISNUOFF Guest
    Quote Originally Posted by DrSpeed View Post
    Short of going through all 11 pages of posts, now that I have a CTS-V, the shifter is sloppy as all hell.
    What do you do differently than a standard bolt-on short shifter?
    Do you send out an entire assembly, and we send our old one back (core return)?
    Or do we pull it apart and wait for you do modify it?
    The ordering info is in the first post.
    I replace all the bushings in the base of the shifter with ones that I designed. I also lower the knob height by 1/2". There is also zero noise/vibration transmitted through my shifters.
    I use a core return system. But, I will also modify your's the same day I receive it and send it back the next if you want to bypass the wait list.
  3. #183
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    Hey Brian,
    Is this what the normal shifter looks like? When I pull up on the shift knob the whole top piece pulls up with it.
  4. #184
    PISNUOFF Guest
    Hi Brandon. No, the conical piece has come detached from the internal rubber on your shifter. It looks like someone tried to repair it with clear silicone. That will never hold. Once it heats up the silicone will start detaching as it has done.
    Just to clarify, that's not one of my shifters.
    Brian
  5. #185
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by PISNUOFF View Post
    Brian
    Sorry, I was not saying that was one of yours. I am going to buy a STS and with the core exchange wanted to make sure I wasn't sol.
    I noticed the shifter sat lower once I got it back from getting the clutch installed (2 years ago). Do you think that they messed up and ended up modifying my shifter? You can also see one of the tabs is broken and a piece of tape is inserted.
    I am the original owner and have not had it modified. I figured this was normal till I looked at others.
  6. #186
    PISNUOFF Guest
    Whoever replaced your clutch pulled the shifter apart while trying to remove the knob. They should have heated it up to adhere the rubber again. I'm not sure you'll be able to remove all the silicone in order to repair it properly. The silicates in it inhibit the rubber from attaching. If you can have the car down, you can send it to mr and I'll see what I can do. In fact, I have an extra cone piece in my shop. PM me if you want to work something out.
  7. #187
    PrelateBishop is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2010
    Mile High
    45
    129
    Wait...what? I didn't know this was an option. Then again, I haven't read through every post in this thread. So I have to ask, what is the approximate turnaround time for one of your shifters if I send you my stock shifter first? Also, if I send you my stock shifter first AND want the new/upgraded bushings, how much do I PayPal?
    If this has already been answered, my apologies.
    Thanks for the clarification in advance.
  8. #188
    PISNUOFF Guest
    Quote Originally Posted by PrelateBishop View Post
    The wait time if you send me your shifter is only shipping plus one day. The upgraded bushings for the base are included with every shifter. You would only send $185 for the shifter modifications/upgrades and an additional $30 if you would like a set of UUC polyurethane bushings.
  9. #189
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Brian, Just sent you money for a shifter and bushings.
  10. #190
    PISNUOFF Guest
    Quote Originally Posted by Andringa View Post
    Got it. Thanks.
  11. #191
    Mar 2010
    Mile High
    45
    129
    Uh, that sounds like a whole heap of awesome.
    Do you recommend the UUC bushings? Also, are you able to provide disassembly instructions for the stock shifter? I'd like to have a guide so as to prevent me from breaking something in the process.
    I'm almost certain that I'll be doing this, especially with the quick turnaround time.
    Thanks!
  12. #192
    PISNUOFF Guest
    Thanks!
    If your shifter bushings are worn out, the UUC ones will make a noticeable improvement. They will also last a lifetime, whereas the stock ones definitely will not. I do recommend getting them for that simple reason. PM me your email address and I'll send you the directions.
  13. #193
    Mar 2010
    Mile High
    45
    129
    PM sent!
    *eagerly awaits light reading*
  14. #194
    PISNUOFF Guest
    Sorry, I got the PM but haven't been home to my computer yet. I'll get the information to you within a couple hours.
  15. #195
    mcline86 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Black CTS-V
    Jul 2010
    MA
    30
    136
    Installed my shifter/bushings today. AMAZING! car feels completly different just from the shifter, So much tighter and shorter. Makes the stock shifter seem like it was a little fisher price POS. Thanks Brian excellent job on the shifter, i will get my stock shifter out to you in a day or two.
  16. Remove Advertisements
