- 11-16-09 09:23 AM #1
Cadillac(s) I Drive: 04 CTS-V
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
Built some custom kicks and pillars for my V
This will be a thread for the install I'm doing in my CTS-V. Most equipment is here and I've started a few things.
Equipment:
Alpine CDA-9886
Metra double-din dash kit
Wet Sounds WS-420 pre-amp/line-driver/eq
Digital Designs 6.5" component set (kicks and pillars)
Digital Designs 6.5" coaxials (front and rear doors for fill only)
Digital Designs M3B 1500W mono amp
Digital Designs C4A 100x4 amp
Digital Designs 1508 8" woofers (2)
Stinger 1/0 power wire, ANL fuseholder up front
Stinger Helix RCA's
Stinger 5F digital hybrid capacitor
Pillars were built about a week ago. There was originally a Blose tweeter in each one. I removed those, cut them out, and fiberglassed a ring in for the tweeter. Each panel was glassed, sanded down, then wrapped in suede.
Next will be forming up the kick panels to hold the 6.5's. The trick is that the e-brake is like a truck and sits below the dash, not to mention there's a clutch pedal, so that's gonna take some trickery. Probably start on those next week.
Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.- Join Date
- Always
- Age
- 2010
- Posts
- Many
- 11-16-09 09:24 AM #2
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
Re: Built some custom kicks and pillars for my V
1 week goes by.......
Finally got some more work done. The pillars have been tucked in my closet since done, so now I started on the kick panels. The floormats in the car are tan, and I'm slowly swapping everything over to black as I can afford to. I've got new black OEM V floormats coming, so it'll look a little different once the work is done.
Started making the form
Resin and fiberglass mat
Raw forms ready for sanding and to be trimmed down
Cut out some speaker rings, sanded flush, and mounted the plastic ring
Wrapped the ring in foamboard so the speaker is recessed
Mounted the ring to the form and about to wrap in grill cloth
- 11-16-09 09:24 AM #3
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
I missed a few pics inbetween, but basically wrapped in grill cloth, 2 coats of resin, then sanded down and covered in suede to match the pillars and seat inserts
Mounted in drivers side, again, black carpet and floormats coming soon.
Both completed on the bench
A new toy that helped this job in a big way
And another goody added along with a UUC short shifter. The old shift knob wouldn't stay straight because it was broken, and the bushings were destroyed on the original shifter.
- 11-16-09 09:28 AM #4
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
Also started on mounting up the pre-amp. This dash kit sucks for using a single-din head unit. It's almost like something is missing. There's a gap between both trim rings that will have to be filled. I filled the gap between the top and bottom of the eq, but can't start on the middle between the head unit until it comes in and is mounted.
If this doesn't turn out right, I'm gonna pull the eq and relocate the volume and sub control to the dash, then mount the chassis and remaining buttons in the trunk and use a pocket in it's place.
- 11-16-09 09:43 AM #5
Cadillac(s) I Drive: 2005 CTS-V
- Join Date
- Sep 2009
- Location
- Belleville, Mi.
- Age
- 32
- Posts
- 315
Impressive. I can't wait the see the finishes project. As for the speakers on the floor. Aren't you worried about stepping on them?
- 11-16-09 10:53 AM #6
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
I am worried about stepping on them. The woofer is angled so much that I'll miss with teh clutch, but the e-brake in the floor will be tough to get used to. That's why I recessed the speaker into the panel, so the grill wouldn't take too much abuse.
- 11-16-09 11:40 AM #7
Looks good man. I agree that I'd be worried about stepping on those floow speakers too, not to mention acidentally getting water in them.
- 11-16-09 01:12 PM #8
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
When I press the clutch in, my heel isnt straight, it's towards the right a little, so that helps.
- 11-16-09 02:28 PM #9
- Join Date
- Dec 2006
- Location
- an I-294 traffic jam
- Age
- 35
- Posts
- 20,842
- Blog Entries
- 4
You definitely get an A for dedication.
I don’t know what the key to success is, but the key to failure is trying to please everyone.
- 11-16-09 03:38 PM #10
Looks great. I'd be more worried about the passenger side. Chicks are just clumsy
'05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links lHawk HP+/HPS l CG-Lock l Specter Bushings l FG2s l Ground control 550/600 l MAGGIE 439RWHP/414RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS
l Original diff
l RT cats l 90mm upgrade
- 11-16-09 04:49 PM #11
pillars look nice in all that !swayyde!
on the rest StainlessWorks 1-3/4 Headers w/Cats to SW 3in Exhaust|CS Motor Mounts|160 t-stat|Katech SS |Ling CAI+homemade intake tube| GTO Shift knob & boot|Specter Werkes Bushings|CTS armrest| TKS Rear Strut Tower Bar|LED int/ext|smoked sidemarkers & fogs with 55w 8k HID's|Aluminum locks & knobs|20%tints|SRP satin pedals|Aeroforce|
- 11-16-09 06:14 PM #12
- Join Date
- Sep 2009
- Age
- 34
- Posts
- 156
| Sponsored Cadillac Advertisements (Supporting Members don't see these ads): | |
LinkBack URL
About LinkBacks
