Originally Posted by BiGIVIiKe1 Thanks for the help PERFECT....
Anyone that has any other ideas that could help I'd really appreciate them...
Belt is NOT slipping, Size of my ALT is not making my engine BOG, Engine bog was due to the electrical issue....Any idea how to diagnose the electrical problem? |
How are you not making this connection?
You installed an aftermarket H.O. alternator
You have "electrical issues" that are affecting your engine (causing it to bog)
Yet, claim that the alt isn't the culprit?
Have you tried monitoring the voltage coming from the alt to your battery? And not just monitoring it with the in-car battery voltmeter or a standard DMM, but an actual scoping voltmeter or DMM that can show transients and spikes (or sags). The ECU/computer on the car is sensitive to over/under voltage and could easily be affected by an alternator.
As far as the steering goes I don't have much comment on how the new alt could be causing steering "tightness". Perhaps your belt is tensioned too much..I don't know
Steering "tightness" to me sounds like you are losing power steering responsiveness and the only way I could image how you could introduce that is to have a belt that isn't properly spinning the PS pump.
And don't be a ass to me since I'm the only one in here offering you advice.
