Results 1 to 9 of 9
Thread: Stability control light comes on sporadically
    shellballright is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Aug 2009
    I dont want to waste anyone's time so i tried to do some research on my own, but I think i am to the point of where i need some help to narrow it down.
    Several weeks past I hit a pretty big pot hole in the road. Ever since, my stability control light will come on for no reason just driving down the road. I have narrowed it down to either being a bad wheel speed sensor or a steering position sensor. i hit the pot hole on the driver side of the car so i have it narrowed down to a side, but can someone tell me if there is a way to test the wheel sensors? Can you use a voltmeter to test, what if its a bad wheel hub setting it off? can you test the hub? my steering wheel is also just slightly off center in my car now, so i am thinking steering position sensor too? Can you test this sensor? Any insight on where to start and how to diagnose would be great...thanks
  2. #2
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Re: Stability control light comes on sporadically
    On mine it was the yaw sensor, located at the rear of the center console.
    You can check with TECH II the steering wheel position sensor by banging on the column while monitoring and turning lock to lock.
    The readings should change but not "jump around".
    Check your "G" meter for funny readings also.
    That was what my yaw sensor did, 1G+ readings (I don't drive it that hard)
  3. #3
    Aug 2009
    thanks for the info heavymetals...my G readings are all below 1...i think the yaw is ok if that is what it controls. do you know of a way to check the wheel speed sesnor?
  4. #4
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    It might go away. One 450 mile trip I kept getting the random Stability Control. It was happening a lot. But since then it hasn't happened again (knock on wood).
  5. #5
    jerrycecco is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jun 2005
    TX
    469
    I had my come on too a few times over the past few months...
    I get the error warnnig shortly after I start the car, but if I turn off the car for a minute then restart the error msg goes away and all is fine.
    Yesterday, I had a GM/Caddy mechanic look at it, he FIRST said it's probably the "steering sensor, that's VERY common to go out"
    BUT after he inspected he found "wheel speed sensor in the left front hub bearing" so I need to replace the whole left front hub bearing
    --Jerry
  6. #6
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    I have a similar problem. I was driving down the road and the service stabilty system warning came on and then my ABS and TC idiot lights came on. Pulld over on the highway ,Restarted the car and then the same lights popped up after a few mins. Any ideas. No warranty so Any ideas??
  7. #7
    uwood's Avatar
    uwood is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade
    Sep 2007
    Morton, Illinois, United State
    317
    Interesting read. My light just started going on and off shortly after the header install. If I were a betting man, I am going after the steering sensor.
  8. #8
    dqw1's Avatar
    dqw1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    Apr 2005
    Madison, AL
    55
    2,018
    Mine ended up being the tire size of all things when I had 255-40-18's on. After I went back to stock, 245-45-18, it went away and never came back. I know others run way different sizes and I haven't seen this reported. My car is weird for whatever reason.
  9. #9
    JMP1020 is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Jul 2011
    5
    mine does the same thing. Its an 04 cts and every day once in a while the stability control comes on ramdonly...I bought it used, and its been doing it since day one...
  • You may not post replies
