| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Diff Rebuild -- Is it worth it?
08-27-09, 05:08 PM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Diff Rebuild -- Is it worth it? Randy, you aren't getting any vibrations? That is a random sound!! Almost sounds like you ran over an animal and it's flapping around back there.
Since it starts up after it gets a little warm.....I'm with you.....sounds like the diff is acting up. I wonder if the pinion bearing is not tight enough? It takes some pretty crazy torque to get it right. Didn't you have that update done recently? Wonder if they didn't torque it correctly.....
Check those CV bolts on your axles too maybe, but I would think you would see some grease from the CV on the inside of your rims if they were loose.
Check the level on your diff too.....is there any fluid residue around the axle seals on the diff?
__________________ Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff, Clear Fogs/Sidemarkers, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq |
08-27-09, 05:27 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Diff Rebuild -- Is it worth it? Quote:
Originally Posted by lollygagger8 Randy, you aren't getting any vibrations? That is a random sound!! Almost sounds like you ran over an animal and it's flapping around back there.
Check the level on your diff too.....is there any fluid residue around the axle seals on the diff? | Haven't touched the pinion seal/bearing yet, so can't be that. I tightened the CV bolts myself; I believe they are tight, and there's no grease anywhere there that I can see. I just changed diff fluid and put in Amsoil plus their additive (old stuff looked GREAT and plug had virtually no ferrous particles on it). I DO have a pinion seal leak, but it doesn't seem too bad as it doesn't even leave any drops on the garage floor.
However, I did remove the KARS kit, took it for a very brief spin, and holy cow did that quiet things up! I hear very very little in the way of that clicking/clunking while shifting now. It's like a tenth of what it was. I DO, however, still hear the strange noise like a vibration but without feeling anything. Heard it while going 25 MPH leaving the neighborhood. It is less pronounced with the KARS removed but definitely still there.
Gonna clean the KARS kit up and put it on the block I think. ibtl
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
08-27-09, 10:15 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Diff Rebuild -- Is it worth it? See if you can get some audio on the noises that are still there when you finish this go-round.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
08-28-09, 12:46 AM
|  | CTS  ader Cadillac(s): 2006 CTS 3.6 // 2005 CTS-V | | Join Date: Dec 2006 Location: an I-294 traffic jam Age: 35 | | | Re: Diff Rebuild -- Is it worth it? Quote:
Originally Posted by ewill3rd Maybe I need to fly up to MI?  | Chicago
__________________ |
08-28-09, 07:40 AM
Originally Posted by ewill3rd See if you can get some audio on the noises that are still there when you finish this go-round. | Sunday. |
08-28-09, 08:00 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Diff Rebuild -- Is it worth it? Something tells me I could put some tools in my car, take a month off, and drive back and forth across this great country and not have to worry about gas money  |
08-28-09, 08:10 AM
Originally Posted by ewill3rd Something tells me I could put some tools in my car, take a month off, and drive back and forth across this great country and not have to worry about gas money  | If I fill you up here, you could get to Chicago, no problem. JimmyH, you're next! |
08-28-09, 09:29 AM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Diff Rebuild -- Is it worth it? Quote:
Originally Posted by rand49er Haven't touched the pinion seal/bearing yet, so can't be that. I tightened the CV bolts myself; I believe they are tight, and there's no grease anywhere there that I can see. I just changed diff fluid and put in Amsoil plus their additive (old stuff looked GREAT and plug had virtually no ferrous particles on it). I DO have a pinion seal leak, but it doesn't seem too bad as it doesn't even leave any drops on the garage floor.
Gonna clean the KARS kit up and put it on the block I think. ibtl  | Sweet! Good find Randy! Sell it!!! Quote:
Originally Posted by ewill3rd Something tells me I could put some tools in my car, take a month off, and drive back and forth across this great country and not have to worry about gas money  | Stop in Indiana for some beers too Boss!! :alki: |
08-28-09, 02:52 PM
Originally Posted by ewill3rd Something tells me I could put some tools in my car, take a month off, and drive back and forth across this great country and not have to worry about gas money  | or food money, or lodging. we'll take care of ya! that would be one hell of a road trip. see the country and fix people's cars |
08-29-09, 11:40 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Diff Rebuild -- Is it worth it? get enough of us together and we could cover the expenses...
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,327 and counting... |
09-14-09, 07:58 PM
|  | Nucking Car Fut "If cool, must own" Cadillac(s): 2009 CTS-V, 60 Coupe Deville | | Join Date: Oct 2007 Location: Northeast Ohio hammer down Age: 41 | | | Re: Diff Rebuild -- Is it worth it? Any updates Rand?
__________________ Come back Tiffany
"Give it the beans" -James May Top Gear
Thank you GM Performance, John Heinricy, and the UAW.
My youtube channel http://www.youtube.com/user/hpjim
Visit my Photo Album. |
09-14-09, 09:47 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Diff Rebuild -- Is it worth it? No update, except that I still have the noise. Not sure if I have one at about 25 MPH and another one at higher speeds or if they're the same one. Sounds TERRIBLE at 25 MPH!
I thought of another way to describe it. It's sort of like the sound a bowling ball makes when it's going down the alley except as if it's going over a more irregular surface and not a completely smooth one. It's about that same frequency and character I'd say.
Wish the dang thing would just break somewhere  and be done with it! Then, at least I'd know what to fix. Got on the expressway near home the other day and let Miss Maggie do her thing somewhat into fourth gear then finally backed off doing 95 MPH before someone said, "Arrest that old man before he hurts himself!" Point is, the sound doesn't seem to get any worse or better at least in the short term like that.
Ewill3rd last posted that he'd like to hear another audio of it, but I don't think I could improve on what I've already done in that regard. Oh, and Jim, it really is more audible than when you last heard it. Maybe it is getting worse and hopefully closer to failure, just slowly and over time. |
09-14-09, 09:55 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V | | Join Date: Nov 2005 Location: Spring, Texas | | | Re: Diff Rebuild -- Is it worth it? Quote:
Originally Posted by rand49er No update, except that I still have the noise. Not sure if I have one at about 25 MPH and another one at higher speeds or if they're the same one. Sounds TERRIBLE at 25 MPH!
Ewill3rd last posted that he'd like to hear another audio of it, but I don't think I could improve on what I've already done in that regard. Oh, and Jim, it really is more audible than when you last heard it. Maybe it is getting worse and hopefully closer to failure, just slowly and over time. | I'd wager that if you loaned it to SkullV for a few days you would find its weakest link. |
09-14-09, 10:05 PM
|  | Nucking Car Fut "If cool, must own" Cadillac(s): 2009 CTS-V, 60 Coupe Deville | | Join Date: Oct 2007 Location: Northeast Ohio hammer down Age: 41 | | | Re: Diff Rebuild -- Is it worth it? ^That's funny. I'll bet he's shreddin some rubba right now since the wheelhop is history. A definite cause for celebration. Quote:
Originally Posted by rand49er . Oh, and Jim, it really is more audible than when you last heard it. Maybe it is getting worse and hopefully closer to failure, just slowly and over time. | I cringe at the thought of that dreaded sound. BTW, maybe leave the camera in the trunk well and shoot some time, based on what I heard with the camera in the trunk the sound ought to be very clear. The offer on a spare diff still remains.  Good luck. |
09-14-09, 10:23 PM
|  | <10 poasts, CF newbie Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior | | Join Date: Mar 2007 Location: Sunny CA. Age: 43 | | | Re: Diff Rebuild -- Is it worth it? Quote:
Originally Posted by darkman I'd wager that if you loaned it to SkullV for a few days you would find its weakest link. | I'm guessing he doesn't need a few days.
__________________ Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
