How to Instructions - Differential Lube Change - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
2004-2007 Cadillac CTS-V General Discussion Discussion, How to Instructions - Differential Lube Change in Cadillac CTS-V Series Forum - 2004 - 2007; Thanks!!...
  1. #16
    rabid's Avatar
    rabid is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Apr 2004
    Columbia, Maryland
    302
    Re: How to Instructions - Differential Lube Change
    Thanks!!
  2. #17
    BeagleBrains is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 Seville; 2004 CTS V; 2011 CTS V Coupe
    Cedar Rapids, IA
    806
    Quote Originally Posted by tzoid
    real, big time racers will tell you, quite loudly(!) to NEVER pre fill an engine oil filter before installing. You will then be pumping unfiltered oil (even tho it's new, it very likely could have contaminants in it) thru your engine. Most of them have a kill switch on the fuel system or the ignition system to allow for turning over the engine without firing to build up oil pressure...unless your running a very special, highly modified engine, I wouldn't worry about the low oil pressure when you change oil and first start up. Fact is, you really don't need anything more than the stock oil filter...most users change the oil and filter WAY before they need too. We're all fanatics with the baby!
    I use a replacable cartridge type oil filter that filters at about 8 microns. To this I have installed a bleadoff line to a 2 micron filter (which is too restrictive for maintaining normal oil flow and pressure). Amsoil has such as set-up available, also. This is ten times finer filtration that any "standard" filter. I prefill the canister to ensure that pressurized oil reaches the oil gallies and bearings as quickly as possible. 90% of engine wear is suffered during initial engine startup because the bearings are dry until oil flow at pressure refills the oil passages.
  3. #18
    StealthV's Avatar
    StealthV is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
    May 2004
    MN>ND>MN>SD>IL>MN>IL
    48
    4,860
    Stephen, are you using the Amsoil cartridge filter? If so, I've looked at that one in the catalog and have a little curiousity in trying one out. Which model number is for the V?
  4. #19
    TheTwins is offline Cadillac Owners Member
    Aug 2004
    23
    Good info, nice job w/the write-up. Q - just curious why is the stock exhaust back on your car?
  5. #20
    benjet's Avatar
    benjet is offline Cadillac Owners Connoisseur
    Dec 2003
    Bay Area, CA
    1,372
    Quote Originally Posted by TheTwins
    I *think* (and I know I'm assuming and posting for Stealth - I know he can post for himself) if you look at the date of the original post, no aftermarket exhausts were released at that time. Therefore not back on, but not yet off.
  6. #21
    Aug 2004
    23
    My bad, you're right. Thought those bending / holding marks on the exhaust pipes looked a little suspicious that's all.
  7. #22
    Cedar Rapids, IA
    806
    Quote Originally Posted by StealthV
    The filter I use is a Nascar racing design. I will get the info tomorrow.
  8. #23
    Cedar Rapids, IA
    806
    Engine Oil Filters. I have used Canton/Mecca Oil Filters for many years. They are very expensive for the initial set-up. One must buy a filter housing first; either spin-on or remote installation. From then on, just buy the their universal 8 micron filter media for about $13.50 each. Bulk purchases are a little less but quite an outlay when buying 24 at a time. The approximately standard 4-1/4" replacement housing is $95.00 which gets you a machined aluminum unit. A remote filter housing is $102.50 to which you must add the engine block adapter plus hoses, etc. The CM Site provides vehicle specific application information; or, if no auto/engine specific applications, there is a cross-reference to major a manufacturer index such as FRAM. They provide the thread type and O-Ring size information for any car to verify the correct application. Cadillac CTS V LS6 CM Housing = 25-232
    Note that the housing length is added to by the bottom plate and attachment set screws. I had a 6-1/4" on a Pontiac Trans-Am and managed to scrap it off in a rough poorly maintained parking lot. The aluminum failed the scrape test and did not affect the engine block. I like the larger unit for the much increased filter volume. High flow with no pressure drop.
    www.cmfilters.com/
  9. #24
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    I have used Canton oil filters and their oil temp thermostat's on previous cars... *extremely* high quality product.
  10. Remove Advertisements
