Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Acceleration feeling in Third?
    Cooly0 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    50
    How strong should the V pull on a running start ~40-45 and flooring the pedal in third? It seemed it took me quite some time to get up to 65-70. Say just under 10 seconds as a guess? It was only running about 5 minutes, maybe not enough warm up time. This was the first one I've test driven.
    I was test driving a questionable one, and to me it did not feel like I had an 8 cyl., and 400 horses at my calling... I'm comparing to a 2.5L 4 cyl. smaller 4 door.
    At some point the gearing seemed high to the tight gearing I have that might explain my underestimated feeling?
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,207
    Re: Acceleration feeling in Third?
    Quote Originally Posted by Cooly0 View Post
    If you a coming up through the gears to maximize acceleration you would not arrive at 3rd gear until over 60 mph (64 mph), and 3rd gear is only good until 94 mph. 4th will get you to 134 mph.
  3. #3
    c4ss's Avatar
    c4ss is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V, Black
    Jun 2008
    Northern New Jersey
    2,166
    I think you'd be in a better powerband in 2nd there.
  4. #4
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by darkman View Post
    Correction - 3rd goes to 99 MPH. Also, even at 45 MPH, if you floor it in third, you should still feel a lot of acceleration.
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    Quote Originally Posted by tweeter81 View Post
    The 94 mph I stated of 3rd gear is 93.6 mph and is calculated based on data contained in the FAQ. The 93.6 mph is consistent with a graph provided by StealthV also contained in the FAQ. I believe the calculations are based on stock tire sizes but I did not reverify that. In any event I believe the 94 mph to be accurate.
  6. #6
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    If you are trying to pull hard at 40-45, dont use 3rd. That is perfect for 2nd.
  7. #7
    Alan F's Avatar
    Alan F is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V
    May 2007
    Cartersville, GA
    40
    497
    yep, 2nd gear is your friend at that speed. However, I call the V a 3rd gear car just because of how hard it really does pull from 60+ in 3rd. Put it this way...i put the V on the 1/4 drag strip just to see and I could nearly finish the 1/4 in 3rd.
  8. #8
    945liter is offline Cadillac Owners Fanatic
    Aug 2008
    203
    lol thats not good your saying you can finish the 1/4 almost trapping 100mph lol.
    We everyone should do a 60-100 punch and see how long it takes im curious to time my cammed car
  9. #9
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    ... I'm comparing to a 2.5L 4 cyl. smaller 4 door ...
    The appropriate comparison is to have the 4-cylinder below its powerband and floor it. Can you spell sluggish?
  10. #10
    PISNUOFF Guest
    "We everyone should do a 60-100 punch and see how long it takes im curious to time my cammed car"
    On a level surface. NO CHEATING!
  11. #11
    Alan F's Avatar
    May 2007
    Cartersville, GA
    40
    497
    Quote Originally Posted by 945liter View Post
    sounds crazy, but look in the forum at the vid I just posted. I trapped at 106mph and wasn't in 4th long at all, check it out, and no rev limiter hit either.
  12. #12
    Aug 2008
    203
    Quote Originally Posted by PISNUOFF View Post
    LOL no point in cheating just cheating yourself ill do it today when i leave work on a level surface.
  13. #13
    PISNUOFF Guest
    I have a virtual dyno program that plugs into the ALDL plug and reads from the ECM. It gives 0-100 mph numbers and you can pick out only the 60-100 time.
  14. #14
    Aug 2008
    203
    More details.
  15. #15
    PISNUOFF Guest
    Can't remember the name of the program off the top of my head. I'll try to look for it tonight. You input certain parameters and it produces Hp and Tq curves also. It's very sensitive to the inputs so you can easily lie to yourself. The Hp and Tq numbers are good for an A to B comparison when tuning.
  • You may not post replies
