| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Stupid tires
08-02-09, 12:55 AM
| | Cadillac Owners Member Cadillac(s): 2006 CTS-V | | Join Date: Feb 2009 Location: Durant, Oklahoma Age: 32 | | | Stupid tires Ok...these tires are costing too much every few thousand miles. Can someone please tell me what I need to tell my guys at the alignment shop to keep from wearing the inside tread down to nothing every 2-3 months? |
08-02-09, 01:18 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Stupid tires cadillacfaq.com
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,165 and counting... |
08-02-09, 11:47 AM
| | Cadillac Owners Member Cadillac(s): 2006 CTS-V | | Join Date: Feb 2009 Location: Durant, Oklahoma Age: 32 | | | Re: Stupid tires Quote:
Originally Posted by thebigjimsho cadillacfaq.com | Ok...so the specs listed under "FE2, FE3, FE4" are the ones I should use? |
08-02-09, 12:11 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 04 CTS-V | | Join Date: Jul 2008 Location: Alabama Age: 27 | | | Re: Stupid tires Quote:
Originally Posted by epershica Ok...so the specs listed under "FE2, FE3, FE4" are the ones I should use? | depends on what shocks you have. if u cant tell the difference take a picture of the sticker on your shocks and post up here. these guys can look at it and tell you which ones.
__________________ 04 V, Magnaflow Catback w/ x-pipe, K&N CAI, HID conversion fogs (4300K), LED's, UUC shifter and bushings, more to come....(hopefully my cam package very soon!!!) |
08-02-09, 12:31 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V | | Join Date: Nov 2005 Location: Spring, Texas | | | Re: Stupid tires Quote:
Originally Posted by epershica Ok...so the specs listed under "FE2, FE3, FE4" are the ones I should use? | The way I read the FAQ information it says that the specifications are for FE2, FE3, and FE4; and is also applicable to FG2s. Most (perhaps all) Vs had either FE4s or FG2s on them when first delivered. These shocks have identical outside dimensions (body diameter, rod diameter, length when compressed, and length when extended) so it would make sense for the alignment specs to be them same.
Bottom line is, unless you have FE5s (unlikely) or aftermarket shocks the FAQs specs should be fine. |
08-02-09, 11:03 PM
| | Cadillac Owners Member Cadillac(s): 2006 CTS-V | | Join Date: Feb 2009 Location: Durant, Oklahoma Age: 32 | | | Re: Stupid tires ok...I haven't got under to look at the shocks yet...just know it's a stock 2006 v at the moment...have had it since february and my new wife tells me we have to be married a year before i make any changes (come on October!) anyway, i'll take a look thanks to everyone for the help...i still say this is the best owners forum on the net! |
08-03-09, 09:31 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS-V | | Join Date: May 2007 Location: Cartersville, GA Age: 33 | | | Re: Stupid tires your V will be FE4 or FG2 -same alignment.
There's two things you can do:
Have the shop custom align it w/ less agressive stance, but you will lose handling ability.
Or...do like I did and have the tires pulled OFF the wheels and swapped to the other side putting the "worn" inner ring of the tire on the outside, spinning in the same direction obviously. I did this at 10k after a 5k front to back rotation and will get 25k out of my toyos in total. The GYs and more aggressive tires may need this at 5k. So, that means you'll be doing a $50-$75 "rotation" often.
__________________ 2005 CTS-V, FG2, Hendrix Axle, Jantzer TB, GM SuperAlloys, H-Pipe, Magnaflows, Toyo T1R 245/275s, CAI, 347rwhp, 342rwtq. Before Kooks/Jantzer TB/bushing best 13.55@106mph and 1.27g's on The Tail of the Dragon
1993 GM High Tech Performance Mag Project Thunderchicken Firebird Formula -MTI 396 LT1. 10.98@124mph |
08-03-09, 10:01 AM
| | Cadillac Owners Member Cadillac(s): 2006 CTS-V | | Join Date: Feb 2009 Location: Durant, Oklahoma Age: 32 | | | Re: Stupid tires I don't track the v so losing a little handling ability shouldn't hurt too much...i appreciate all the suggestions... |
08-03-09, 11:10 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS-V | | Join Date: May 2007 Location: Cartersville, GA Age: 33 | | | Re: Stupid tires Quote:
Originally Posted by epershica I don't track the v so losing a little handling ability shouldn't hurt too much...i appreciate all the suggestions... | just a thought, don't know how the measurements/figures would convert, but I've seen several 03/04 Cobras on the lift and for an IRS they handle well and don't tilt in like our Vs. Of course, the GTOs have IRS and don't tilt in but don't handle very well either. Just work with a good alignment shop and I'm sure you can come up w/ a good balance. |
08-03-09, 01:28 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: Stupid tires I've heard of this issue before with earlier CTS's. Not sure if a solution was ever found. Just take it to an alignment shop and get a free alignment check to see where you are currently at. |
08-03-09, 01:48 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Stupid tires Ask your new wife if that year moratorium includes breast augmentation......
__________________ I am so expensive I can't even afford to hire me.... |
08-03-09, 03:53 PM
| | Cadillac Owners Member Cadillac(s): 2006 CTS-V | | Join Date: Feb 2009 Location: Durant, Oklahoma Age: 32 | | | Re: Stupid tires I've already tried that one...slept in the V for 2 days...but maybe I can try again when that year anniversary hits...the V is fairly comfortable...hahaha | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
