| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why?
07-19-09, 08:13 AM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Just got a Magnavolt to install. I know some of you guys had some problems with having an adequate ground, but is there a preferred mounting location? Why there? Heat? Better grounding? Accessibility?
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
07-19-09, 11:08 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Jan 2008 Location: Nashvegas, TN Age: 27 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? I'd like to know also. Good question Randy. |
07-19-09, 11:57 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 04 CTS-V with a little hp persuasion device | | Join Date: Oct 2007 Age: 24 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? If you have the new one that is all one piece, probably the best place is under the hood so you have a good clean boost reference. Now I believe Heavy Metals has basically a separate map and then then the magnavolt so he installed the magnavolt in the trunk and the map under the hood. The shorter you can keep the boost reference line, the better off you'll be.
__________________ 04 Raven CTS-V / Forged and maggied LS6 / 90mm TB / 8 rib pulleys / 8" overdrive balancer with 2.7" blower pulley / LG G5X1 / Crane 1.8 gold rollers / 1 7/8 Kooks / ARP hardware throughout / Melling oil pump / Cloyes double roller / Volant CAI / Fidanza LS7 flywheel / Spec Stage 3 / Ground Control / QA1's / RC51 motor mounts / UUC diff, and shifter bushings / UUC Vknob / Katech STS / Rear strut bar / Kars III |
07-19-09, 01:39 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Correct. The pressure switch is under the hood, mounted on the firewall with the wires running to the trunk to trigger the Magnavolt (old design but works for me).
I am still on my original(!) Magnavolt and only blew the fuse once when I first turned it on (no load on the fuel pump).
I don't like putting electronics in a hot engine compartment.
MAKE SURE YOU GROUND THE HECK OUT OF IT.
__________________ I am so expensive I can't even afford to hire me.... |
07-19-09, 01:45 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? WhAt does a magnavolt do ? Exactly |
07-19-09, 01:57 PM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Randy - I think you'll have to go under the hood unless you have the extra hardware required to mount it elsewhere like heavy. The under the hood location is certainly convenient for installation, but now that I think about it you actually might be able to mount it somewhere under the passenger side of the dash (I don't remember how much room is in there). Your boost reference line and wiring could go right through the firewall and not be any longer than if the magnavolt was under the hood. That might be worth taking a look at since it would be a good bit cooler in there.
And GROUND THE HECK OUTTA IT x1000000! Quote:
Originally Posted by lilgCTS-V WhAt does a magnavolt do ? Exactly | It increases voltage to the fuel pump when under boost to keep pressure up when there is high demand for fuel. It is triggered when boost goes to ~4psi I believe, but someone else can verify or correct me on that.
__________________ 05 CTS-V / maggie 2.8 / b&m shifter & uuc bushings / gto shift knob / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps / 265|40 bfg kd / ngk tr6
434 rwhp / 412 rwtq..........are you new to the forum? READ THIS and then TRY THIS. |
07-19-09, 02:08 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? The Magnavolt is a switching power supply that "boosts" the voltage to the fuel pump on demand (vacuum) to increase fuel pressure. |
07-19-09, 02:09 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 CTS-V | | Join Date: Mar 2009 Location: Los Angeles, CA Age: 25 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? any pics guys? |
07-19-09, 03:20 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Here's the kit I bought. Don't have any install pics, though.  |
07-19-09, 03:32 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Jan 2008 Location: Nashvegas, TN Age: 27 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? That's what mine looks like. |
07-19-09, 03:35 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? That's encouraging! (Mod Hell is very lonely when you're by yourself. ) |
07-19-09, 03:44 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 04 CTS-V with a little hp persuasion device | | Join Date: Oct 2007 Age: 24 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? No mount? If you are mounting under the hood they sell a mount that bolts it to the the passengers side strut tower. Very convenient but hot. Like 510 said it may be worth looking into mounting inside if possible. |
07-19-09, 04:35 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? I'm assuming the "boost reference line" is a vacuum tube that connects to a nipple on the maggie and tells the Magnavolt that the supercharger is in boost mode (i.e. pressure, not vacuum) and to crank up the voltage to the fuel pump.
Also, I'm assuming by keeping it short, there's less opportunity for it to get in trouble (i.e. kink, get cut, melt, etc.) thereby not relaying the boost-condition info on to the magnavolt.
True those? |
07-19-09, 06:07 PM
| | Cadillac Owners Enthusiast Cadillac(s): '05 CTS-V Black-Black | | Join Date: Oct 2008 Location: SouthEast PA Age: 39 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Quote:
Originally Posted by rand49er ...Also, I'm assuming by keeping it short, there's less opportunity for it to get in trouble (i.e. kink, get cut, melt, etc.) thereby not relaying the boost-condition info on to the magnavolt.
True those? | You want that line as short as possible. The shorter the line the less [air] mass it takes to pressurize (boost)/depressurize(vacuum) the line giving a more accurate and quicker transient for the Manga-Volt to react to. |
07-19-09, 07:41 PM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: Magnavolt Mounting Location -- Engine Bay? Trunk? Other? Why? Quote:
Originally Posted by rand49er I'm assuming the "boost reference line" is a vacuum tube that connects to a nipple on the maggie and tells the Magnavolt that the supercharger is in boost mode (i.e. pressure, not vacuum) and to crank up the voltage to the fuel pump.
True those? | Yes, though, the line that comes with the kit is the size that Magnuson intended to be used with the setup, so as long as you don't lengthen that line, you will still be working within the original specs. I guarantee that if you find a place under the passenger side dash, the supplied line will reach just fine.
The line itself is pretty tough. It seems to me to be holding up to the engine heat very well, and it actually is firm enough that you would have to try pretty hard to get a kink in it. I have it running through a series of zip tie loops that keep it in place but don't squeeze it too much.
So, IMO, I don't think you need to worry about shortening the line at all, just don't lengthen it. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
