Spark plug change = blood on driveway - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 71
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Spark plug change = blood on driveway in Cadillac CTS-V Series Forum - 2004 - 2007; I'm not opposed to all-expenses-paid trip to DFW .... hehehe...
  1. #46
    POS VETT is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2010
    44
    274
    Re: Spark plug change = blood on driveway
  2. #47
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by ELES6CTS View Post
    SkullV or Darkman, did yall use any special tools to remove the boots? Thinking about doing these soon.
    No special tool for the boots, just pulled. I use tune up grease on the boots every time I change plugs/wires though. Makes it much easier the next time around.
  3. #48
    Overd0s3 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V blk/blk
    Dec 2009
    28
    323
    When you guys do plug changes, do you regap? or use factory gap?
  4. #49
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by Overd0s3 View Post
    I would gap according to NGK reccomendations assuming you are using their TR55 plug for NA. I use different gaps though since everytime I have swapped plugs on this car was for a different heat range of nitrous plug. I am now on a BR7EF non-projected plug at .032 gap.
  5. #50
    lilgCTS-V is offline Cadillac Owners Enthusiast
    Automobile(s): 06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
    Nov 2008
    967
    i am dreading chaning my plugs
  6. #51
    gerrr2025's Avatar
    gerrr2025 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-v
    Feb 2010
    37
    31
    Quote Originally Posted by verywhitedevil View Post
    getting mine put in with the headers and motor mounts at the same time... 200.00 to install headers, plugs and motor mounts.
    thanks for the heads up, now I know I am glad I took my shop up on the install.
    im new to the V world and woundering about the motor mounts. Why did you get them and where? whats wrong with the oem mounts?
  7. #52
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by gerrr2025 View Post
    The oem motor mounts are liquid-filled units with a tendency to fail. When they fail the fluid leaks and leaves visible evidence. Failed motor mounts can cause the motor to shudder a lot at shut down, contribute to driveline clunk and several other symptoms. Even if the oem units get replaced under warranty the replacements can fail too. Aftermarket replacements are therefore, popular. On the other hand, some get a good number of miles on the oems.
  8. #53
    Mar 2010
    44
    274
    I use the gap that NGK set in TR55IX/TR5IX.
    Quote Originally Posted by lilgCTS-V View Post
    Nah, no big deal. It's the same as any other V8 spark plug change, just add removing coil packs (4 dual-ended bolts and an electrical connector on each bank).
  9. #54
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    36
    1,747
    Im in the middle of this now too. It took me just over an hour to remove strut bar, coils, plug wires and plugs. Spent nearly 30 minutes of that getting the damn boots off. I had a pickle fork and it was worthless to me. I ended up using a nail pry bar and leveraging against the valve cover.....ONLY BROKE 2 PLUG WIRES!
    Now I guess I'm headed to Autozone/pep boys for some plug wires. I assume I reuse the stock aluminum plug heat shields with the new wires?
    Next is pulling the manifolds off and replacing the motor mounts with the black CS ones. I'm going to paint my valve covers too I think while I've got er all apart.
  10. #55
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    I transferred my OEM heat shields to a set of FireCore50 wires -worked just fine.
  11. #56
    deedubb's Avatar
    Feb 2005
    Mile High
    36
    1,747
    Cool thanks!
  12. #57
    silver02stang's Avatar
    silver02stang is offline Cadillac Owners Enthusiast
    Automobile(s): LS6 CTS-V
    Oct 2008
    Appleton, WI
    39
    548
    Quote Originally Posted by darkman View Post
    nice! i was just wondering that. i took a slice out of one of my wires when doing the plugs yesterday so i've been looking at the FireCores and Moroso Utra 40's. The Moroso's are almost half the cost of the 'Cores and still seem to be good wires.
  13. #58
    Oct 2008
    Appleton, WI
    39
    548
    I used a garden sheers of all things. Sounds ridiculous but the boot puller was useless, the pickle fork didn't grab the metal sleeve well enough, but the sheers fit perfect. Even had the perfect 30º angle to it. I just needed to be careful....
    ...more careful than i actually was. hence needing to buy new wires now.
    ...also - don't let your neighbors see you if you want to keep your dignity intact. any idea of you being the car guru on your block goes right out the window the moment someone see's you under the hood with a sheers.
  14. #59
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by silver02stang View Post
    I did not price them everywhere but the GeForce Engineering price on the FireCores is about the same as the Moroso 40's at Jeg's.
  15. #60
    Oct 2008
    Appleton, WI
    39
    548
    darkman - did you get the 45 or the 180? i can't really tell the difference and they are both the same price
  16. Remove Advertisements
