NAV install good, but problem...GPS
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V General Discussion Discussion, NAV install good, but problem...GPS in Cadillac CTS-V Series Forum - 2004 - 2007; As some may see, I installed a factory Nav unit into my base CTS over the week. Everything works (still ...
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    As some may see, I installed a factory Nav unit into my base CTS over the week. Everything works (still need to hook up the voice prompt lines) exept I get a GPS calculation error "Out of Range" (on the GPS screen, no satellites are shown, and no info is shown except for under Calculation is says "out of range"). Any idea what this means? Am I not getting the signal from the Onstar GPS, or is there something that needs to be reset/recalibrated?
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
  2. #2
    sefa01's Avatar
    sefa01 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    New Jersey
    931
    Re: NAV install good, but problem...GPS
    My understanding of the navigation system is that you cannot plot a route of more than 1,200 miles (if it's longer you do it in sections). I can't give a technical answer, but I wonder is somehow yours is set up so that the destination, at least according to the nav system, is more than 1,200 miles away.
  3. #3
    6104696 is offline Cadillac Owners Connoisseur
    2,178
    is the "out of range" notice in all locations? Try going to higher ground. I sometimes get that notice when I get into low spots on hilly areas. Is there a remote antenna on the system?
    Doug
  4. #4
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Here's the weird thing, and maybe I'm just being stupid, but...
    When I drive, the car indicator on the navigation moves, turns, backs up, etc on the nav map. The car indicator just moves too fast (goes about 2 miles for every mile I actually travel, which means when I adjust the vehicle position for say my house, and start down the road, the map will say I passed a road which I haven't even come up yet. By the time I reach the middle of town, I'm on the other side of the town according to the map. How could it do this without having a GPS signal?
  5. #5
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    The N arrow will show you when the GPS is making contact with the car and when its not. If you're not getting anything on the satellite positioning screen, then I'd assume you have a connection problem at some point.
    As to the distance factor, I wouldn't think it would get so far off base in such a short time. Obviously, the Nav system should be able to go offline from a satellite signal for a time by using vehicle speed and such. I could understand some positional error by not having contact, but not that much.
  6. #6
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    I think I answered my own question here by research. From everything I can tell, the Navigation system in the CTS is a Blaup unkt system. Most Blaup unkt use vehicle speed sensors and an internal gyroscope to provide dead reckoning incase of GPS failure. I bet that is what I am experiencing and why it's not accurate.
  7. #7
    Innocent Bystander is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2003
    50
    Isn't there a separate GPS antenna under the I/P pad? If I remember, it's on the driver side near the very front of the windshield. It should have its own mini coax cable to the NAV unit independent of any OnStar antennae.
  8. #8
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Quote Originally Posted by Innocent Bystander
    Yeah, I think so - most schematics say it's not needed with the onstar system, but it shows in the parts system as non-export, so.... I ordered it today, overnight from Lansing.
  9. #9
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    May 2004
    Fenton, Michigan
    870
    I have a friend at Bose who told me the Nav system was made by Denso, as opposed to Blaup unkt(Bosch)
  10. #10
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Quote Originally Posted by ronr
    No, the other Cadillac's are Denso. The flip panel systems are Denso (Deville, Seville, SRX, XLR), but the CTS and V systems are Delphi units contracted to Blaup unkt. I figured it out when I took my face plate off my unit and it says "Blaup unkt" inside under the main DVD drive. Also, you can tell by the connectors - noone else uses those 20 pin offset connectors for nav except Blaup unkt.
  11. Remove Advertisements
