Wideband o2 Placement - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
2004-2007 Cadillac CTS-V General Discussion Discussion, Wideband o2 Placement in Cadillac CTS-V Series Forum - 2004 - 2007; put it in your bunghole EPP had his on the drivers side when he tuned mine, but he uses EFI ...
  1. #16
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Wideband o2 Placement
    EPP had his on the drivers side when he tuned mine, but he uses EFI Live (you already know) But I would assume it wouldn't matter what program you use
  2. #17
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by lollygagger8 View Post
    Yeah, most tuners either put it post cat because they don't want to remove the narrowband o2 sensors pre cat (and don't want to weld in a bung for one tune) or they put it post cat because they use a tailpipe clamp on the dyno. Either way it will read a little leaner then the true reading but they either just roughly "correct" for it or just run with it!
  3. #18
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    At this point, I'm not worried about it showing a little lean.
    When I really get into tuning, I'll have it welded pre-cat. For now, I'll keep it a bit rich anyway.
  4. #19
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I have the LC-1 on the driver's side only hot wired into the NB o2 sensor.The purple is the one volt signal line, FYI...You will have to turn off the Heater option for MIL light codes..
    So far i havent had any issues, For better balance if you are goin to hot wire in the NB o2 it would be better to do both sides, but if your tune is correct then its a waste of money for the trim wouldnt be that far off...I have about 1-4 point difference between my two sides. Not a big deal...But if you blow a fuse you will go into HEAVY enrichment on WB side. Been there done that...
    The LM-2 is AMAZIN, got one to tune friends cars as well as my fathers boat...Wow very small, can be used alone or with PC and its Logable....Very happy with this buy..
  5. #20
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    sorry to bring up a dead thread but how did you guys feed the wire from the sensor into the cabin?
  6. #21
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Under the dash. Big grommet for the steering linkage. Keep in mind the crazy ground offset we have on these cars.
  7. #22
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by Twitch View Post
    Yep.
  8. #23
    Feb 2009
    Long Beach Ca
    35
    2,741
    thanks guys, maybe take a look at this thread and maybe lend me some advice.
    http://www.cadillacforums.com/forums...-2005-cts.html
  9. #24
    Feb 2009
    Long Beach Ca
    35
    2,741
    Where did you guys get power and ground from, i just noticed that the fuse panel is in the rear of the vehicle. And what did you mean by crazy ground offset?
  10. #25
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by liqidvenom View Post
    I ran an 8 gauge power line straight from the fuse block up front. Then I have that powering another fuse block under my center console which is run by an ACC relay. This pic shows all of my grounds in an attempt to avoid grounding offsets (all in one spot, different lugs).
    The grounding offsets cause different readings on your WB gauge and HP Tuners then what the actual sensor is putting out. To fix this you need to adjust your gauge and HP Tuners to match what you are seeing in Log Works which is raw data from the LC-1. Get ready for a LOT of reading and it will eventually make sense.
  11. Remove Advertisements
