Oil Pressure Sensor Sender Failure - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 52 of 52
2004-2007 Cadillac CTS-V General Discussion Discussion, Oil Pressure Sensor Sender Failure in Cadillac CTS-V Series Forum - 2004 - 2007; Well, got dizzy looking at it with the maggie so we decided to just slide the maggie forward by a ...
  1. #46
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Re: Oil Pressure Sensor Sender Failure
    Well, got dizzy looking at it with the maggie so we decided to just slide the maggie forward by a few inches. Worked like a charm and probably quicker than dremel/facia removal. Unbolt maggie, take out intake tube, unplug sensors, unplug injectors and slide forward. No need to remove coolant hoses. About an hour and a bit total.
  2. #47
    MauiV's Avatar
    MauiV is offline Cadillac Owners Connoisseur
    Automobile(s): Tis Gone :(
    Nov 2007
    3,414
    Is it just me or does this seem to be a bigger issue on booster V's?
  3. #48
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,790
    It's you.
    These are a known failure in the LS series.
    Vette guys pop them so often someone came out with a relocation kit.
    What really screws them up is cold thick oil on start up and then rev it a bit.
    POP!
  4. #49
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8, 05 White Diamond STS4 V8 1SG
    May 2008
    36
    1,387
    I was going to say the same thing, that it seemed to be a disproportionate number of the maggie folks. But maybe they make all the threads because it's so much harder to get to it with the blower in place.
  5. #50
    hXc95SLS's Avatar
    hXc95SLS is offline Cadillac Owners Enthusiast
    Automobile(s): 1992 Dodge Dakota DD, 2005 CTS-V Black on Black
    Apr 2008
    Toms River, NJ
    28
    573
    So just the sensor sender going is a common problem? I got in mine today after driving it 15 minutes prior and it said oil pressure 0 stop engine. I bugged out. Pulled the filler neck out of the valve cover and didnt see any oil flow and thought the worst towed it home. There is deff a strange tick coming from the engine now so Im not 100% on it being the sensor but well see.
  6. #51
    Nov 2004
    8,790
    If you had no oil pressure it would be more then a "strange tic".
    It would sound like a bucket of bolts having a death rattle.
  7. #52
    Fore V is offline Cadillac Owners Member
    Automobile(s): CTS V 2005 - Black Raven
    Feb 2008
    Windsor, ON Canada
    5
    I did it today! I was tired to have the Oil Pressure reading out of wack and have the "Service Engine Soon" popin up on the NAV.
    Got a BWD (Made in Mexico) oil pressure sender for $69 at Partsouce. Brass fitting and seems and feel better quality than the OEM I pulled out. I also bought the socket for $11. In Ontario Canada, we need to add another $10.40 or 13% (Harmonized Sales Tax) or HST. I have a few other names for this one. Yes, I did remove the windshield washer motor trim. Took me around 15 minutes. All looks good now!
    Thanks for this thread! It made me come to conclusion and fix it myself.
    Cheers
    Fore V
  8. Remove Advertisements
