Oil Pressure Sensor Sender Failure - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 52
2004-2007 Cadillac CTS-V General Discussion Discussion, Oil Pressure Sensor Sender Failure in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by heavymetals Where there is a will........ You will end up grinding that off when you are replacing ...
  1. #31
    wmskateteam is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V
    Jun 2010
    49
    Re: Oil Pressure Sensor Sender Failure
    Quote Originally Posted by heavymetals View Post
    You will end up grinding that off when you are replacing sensor #3
    i hope not, but all in all it isn't too bad. i was expecting worse
  2. #32
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    Good for you.
    It isn't as big of a deal as it is made out to be.
    It is just hard to get at cuz you can't see it.
    I replace em by "feel" now.
  3. #33
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Quote Originally Posted by darkman View Post
    Is there a specific auto parts store (chain) that sells that brand?
    I don't know honestly, I think Dormont is a pretty common manufacturer. I have a buddy that works for PAPA Automotive and he has been giving me stuff at cost for years, so that's where I got mine. Just stay away from KEM, its all junk.
  4. #34
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8
    May 2008
    35
    1,354
    Are we talking about Dorman? Never heard of Dormont. Dorman (mainly chinese manufacture) is famous for coming to the rescue for either expensive, unavailable or faulty factory parts, just like this. Though my sensor is original at nearly 100k, no funny business. But I should stop saying that because it'll fail the next time I drive the car.
  5. #35
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,181
    Quote Originally Posted by kevm14 View Post
    Thank you. I bought some "universal" Dorman exhaust studs (manifold to cat) a while back but I could not remember the name. Their parts are sold at many part stores and do have an online catalog.
  6. #36
    MauiV's Avatar
    MauiV is offline Cadillac Owners Connoisseur
    Automobile(s): Tis Gone :(
    Nov 2007
    3,414
    I use this:
    Also, if the valley cover is interfering, you may have to break out the Dremel and grind some material away (I had to so I know).
    Old story, but when I installed my maggie I was telling my friend helping me that I hoped I never had to replace that sensor.
    I am on #4. but I can replace those POS in short order now.
    Did you have to shave down the outside of the actual socket Or trip the block? I cant get it to fit between the block and the nut. My Maggie just returned today with install tomorrow morning so I want to knock this out while its right in front of me. Thanks.
  7. #37
    Nov 2004
    8,787
    It was a "lip" on the maggie I had to grind down.
  8. #38
    MauiV's Avatar
    Nov 2007
    3,414
    Does your socket package say that its for 4cyl GMs and 3.0l V6s? Mine has the same part number at the top but it definatly doesnt fit in he VERY thin gap
  9. #39
    MauiV's Avatar
    Nov 2007
    3,414
    Well, after MUCH deliberation and temptation with the Dremel, I have decided to remove the valley floor plate to get to this sensor bolt. That is the actual like that sits right up next to it. I worried about triming off the necessary metal that close to a the hex bolt. The new gasket for the bottom is ordered so it is just the removal of the 10 hex bolts on the plate, remove the sensor, replace. Anyone know the torque requirements for thse hex bolts? I am almost tempted to replace the knock sensors while I am here since I did have one alarm on me over the summer after it more than likely got wet.
    Heavy mentioned trimming off a lip of the Maggie but I would guess this is the piece that he actually got....
  10. #40
    Nov 2004
    8,787
    That's it.
    Just grind it off with a Dremel.
  11. #41
    MauiV's Avatar
    Nov 2007
    3,414
    Im weary to grind it off that close to that bolt and grinding with so many open holes in the engine bay right now where that stuff is going to end up. I have a couple of towels over the ports and stuff right now but I still worry about anything finding its way into the engine.
  12. #42
    Nov 2004
    8,787
    I duct tape a shop vac hose next to whatever I grind on.
    Catches most of it.
    Just spray with a degrease solvent first.
  13. #43
    white2001formula is offline Cadillac Owners Member
    Jun 2009
    36
    Rey,
    I had the exact same scenario happen to me earlier today. Monitored everything else and came home to research it. Sadly, I just passed my 100k warranty. Thank you for the information and part number. I just ordered the part, should be here in a few days.
    -Chris
  14. #44
    Alcohawk is offline Cadillac Owners Member
    Automobile(s): 2005 CTS V
    Jun 2010
    9
    nice
  15. #45
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Funny I should spot this thread. My sensor went this morning. Maxxed out then after a couple of hours went to blanks and alarms started chirping. Not fun to listen to bongs all day.
    heavy, thanks for the info, I'll try it out without removing the maggie.
  16. Remove Advertisements
