Oil Pressure Sensor Sender Failure - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
2004-2007 Cadillac CTS-V General Discussion Discussion, Oil Pressure Sensor Sender Failure in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone replaced the oil pressure sensor with a miggie installed?...
  1. #16
    Ssspeed is offline Cadillac Owners Member
    Automobile(s): Cts-v
    Feb 2009
    33
    25
    Re: Oil Pressure Sensor Sender Failure
  2. #17
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,200
    Quote Originally Posted by Ssspeed View Post
    See posts #7-9 of this thread.
  3. #18
    Feb 2009
    33
    25
    Thanks but my the dealer wants to charge me 800 bucks because he said the supercharger has to be removed.
  4. #19
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,200
    With that much at stake I would PM Heavymetals - he has a maggie and has apparently replaced the sensor with the maggie in place. He can give you the details, or correct me if I have misinterpreted his posts.
    PS - He is on west coast time.
  5. #20
    Feb 2009
    33
    25
    Cool I'll pm him thanks
  6. #21
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    PM sent.
    You can DIY.
    Duck soup.
  7. #22
    wmskateteam is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V
    Jun 2010
    49
    i tried to PM you heavymetals, but i'm still not authorized. i have my windshield wiper fascia off and bought a 1 1/16 sensor socket which i've ground down as much as i can and still can't get it to fit over the sensor. it keeps hitting my maggie valley cover, what did you use to get the sensor out?
  8. #23
    Nov 2004
    8,788
    I use this:
    Also, if the valley cover is interfering, you may have to break out the Dremel and grind some material away (I had to so I know).
    Old story, but when I installed my maggie I was telling my friend helping me that I hoped I never had to replace that sensor.
    I am on #4. but I can replace those POS in short order now.
  9. #24
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by wmskateteam View Post
    Quote Originally Posted by heavymetals View Post
    I use this:
    Would a crows foot work?
  10. #25
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by Rey View Post
    The part number for the sensor/sender is 12616646. GM sells this for about $75. GMPD price, including shipping, was a bit over $50.
    FYI, I'm selling that same part for $52
  11. #26
    Jun 2010
    49
    thanks for the input, i ended up cutting 1/3 of the socket wall off and doing minimal turns. i borrowed a dremel but didn't have a good bit so i couldn't grind enough of the portion on the valley cover that was interfering with the sensor removal
  12. #27
    Nov 2004
    8,788
    Where there is a will........
    You will end up grinding that off when you are replacing sensor #3
  13. #28
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    I had to replace mine twice...once when pressure went high and again when I snapped the connector off installing the Maggie. The valley plate does need to come off to replace it.
    I opted to go aftermarket and got a Dormont(?) sensor for $45.00, and I think it is actually a much better piece than the OEM one. It is made from brass and has a weighted, quality feel vice the fly-weight OEM piece. Aftermarket feels and looks like a higher quality piece IMO.
  14. #29
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,200
    Quote Originally Posted by DMM View Post
    Is there a specific auto parts store (chain) that sells that brand?
  15. #30
    Sep 2007
    Wilmington, NC
    13,986
    we've found a Standard part that is for an older n* with a smaller thread works best for cars where the OEM sensor seems to fluctuate too much
    (you just need a fitting to step up the thread size to fit into the oil filter housing)
    PS270 i think is the Standard part number
  16. Remove Advertisements
