Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Need Urgent Help
  #16 (permalink)
Old 05-03-09, 03:17 PM
View Ak Jim's Photo Album
Casino Cash: $7580
Re: Need Urgent Help
The next time you have this problem try pumping the clutch several times and then putting it in gear. If it works ok after pumping then it probably is air in the system.
  #17 (permalink)
Old 05-03-09, 04:12 PM
Cadillac(s): CTS-V
View Beardog's Photo Album
Casino Cash: $1595
Have you checked your linkage? I parked my V in the garge one night and the next day it wouldn't go into reverse so after pushing it out I discovered that 1-6th gear worked fine. I drove it to the dealer and they replaced someting in the linkage and it was done under warranty.
  #18 (permalink)
Old 05-04-09, 02:05 AM
Koooop's Avatar
Commonsewer
Cadillac(s): Black CTS-V, 1969 Yellow Vette w/ZZ383
View Koooop's Photo Album
Casino Cash: $7945
Originally Posted by heavymetals View Post
Sounds like a funky clutch slave to me.
Yeah that.
(May as well be a clutch with what you have to do to change it out...)
I wanted change, but all I got was a broke ass car company.
  #19 (permalink)
Old 05-20-09, 01:17 PM
nmaier2201's Avatar
Truck Motor FTW!
Cadillac(s): 2006 CTS-V
View nmaier2201's Photo Album
Casino Cash: $504284
Mike any updates? I have one other tidbit that might help. I noticed after my repeated refilling/swapping of the shot glass reservoir that there was fluid that had come out of the top of the reservoir and had dried up.... After a careful examination of the rubber diaphram (accordion looking thing in the cap) that the clear plastic part in the bottom had come out because the rubber accordion had ripped slightly.
At 1st I didn't really think much of it, but Darkman pointed out to be that it does matter because you don't want moisture contaminating the fluid, which will lower the boiling point.
So just for grins I bled the clutch one more time... and just like the other times it helped... but the question is how long will it last? I think the boot being ripped is allowing moisture in there and ruining my RBF600, which is causing my clutch to drag, and therefore making it hard for me to switch gears.
I called up Luke and he's ordering me what we think is the replacement cap. so until I get that fixed it looks like I'll have to bleed my clutch about every 2 months to keep the fluid good enough for the slave to fully disengage...
Why post that novel? check your rubber diaphram in the reservoir... and even if you just bled that clutch.... do it again just to see... it doesn't hurt anything... and it was eye opening to me.
Thanks Darkman!
urgent
Censor is OFF
