| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Electric water Pump
03-26-09, 09:33 PM
| | Cadillac Owners Member Cadillac(s): 06 CTS V | | Join Date: Feb 2009 Age: 31 | | | Electric water Pump has anyone installed an electric waterpump on any of the V's?
The manufactures claim 10-15 hp? |
03-26-09, 10:06 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V | | Join Date: Nov 2005 Location: Spring, Texas | | | Re: Electric water Pump Good question - I have not installed one but I have thought about it. The horespower gain seems plausible, but I have not seen any independent verification. I would want to know with certainty that the flow rate was adedquate for a hot climate with heavy AC use. I also am concerned that an electric pump would effect the motor warranty. |
03-26-09, 10:19 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Electric water Pump What is the horsepower loss due to requiring the alternator to run the pump motor ? Electricity in a car isn't free. Maybe a few HP gain at WOT, otherwise overall loss. (As it is now, if your engine uses electric fan(s), you're only running a small belt-driven water pump, not a viscous or hard drive fan, so the claimed "gain" is even less.) If your HVAC system is in any mode requiring the A/C compressor to run, not only does the compressor present a big engine load, but the fans run in slow, another load. Just turning the A/C system to some "ventilation only" mode will give you 6 - 8 HP across the board (the A/C compressor drops out at WOT). |
03-26-09, 10:39 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V | | Join Date: Nov 2005 Location: Spring, Texas | | | Re: Electric water Pump Quote:
Originally Posted by submariner409 What is the horsepower loss due to requiring the alternator to run the pump motor ? Electricity in a car isn't free. Maybe a few HP gain at WOT, otherwise overall loss. (As it is now, if your engine uses electric fan(s), you're only running a small belt-driven water pump, not a viscous or hard drive fan, so the claimed "gain" is even less.) If your HVAC system is in any mode requiring the A/C compressor to run, not only does the compressor present a big engine load, but the fans run in slow, another load. Just turning the A/C system to some "ventilation only" mode will give you 6 - 8 HP across the board (the A/C compressor drops out at WOT). | It is my understanding that while electricity in a car isn't "free" it is almost free because the system has storage (the battery), is designed to meet peak or spikes, is underutilized most of the time, and the incremental drag is insignificant. This is evidenced by the fact you can add lots of accesories before you need to upgrade standard alternators. (If someone has some hard facts to the contrary I have an open mind on this point.)
I agree that the AC is probably a bigger power drain than a mechanical water pump, but the AC already has an off switch that the mechanical water pump does not. |
03-26-09, 10:45 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 CTS-V raven black | | Join Date: Nov 2008 Location: North West Florida Age: 33 | | | Re: Electric water Pump ^^^agree....only a before and after dyno would tell...I searched a few pages here and didn't see anything or anyone do this, so good thread debate/topic
__________________ 2005 Black-on-Black-on Black | Trifecta tune | frankenstien exhaust: kooks headers, magnaflow X-pipe, corsa ss pipe, flowmaster race cans, and magnaflow tips | Katech V2 w/UUC bushings | Katech ported TB | |matching black painted engine cover | custom Intake tube | drop-in K&N filter | 265/40 BFG KD's | powdercoated factory wheels (gloss black) | Limo tint all around | tinted turns/fogs/3rd & reverse lights | Powdercoated upper/lower grill | UUC diff bushing | 3000K HID fog lights | 360rwhp |
03-26-09, 10:48 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Electric water Pump The kicker is that the battery functions only to start the car, never afterward. The alternator carries every bit of the total electrical load as long as the engine is running and the charging system is intact. Cyclical loads, such as A/C clutch cycling and electric fan loads, as well as radical audio loads, have no effect on the battery, per se: they vary the amperage/voltage supplied by the alternator as a function of sensed battery condition. The installed alternator is usually loaded to only some of its high rpm capacity. Yes, the battery may contribute current, but only at low rpm idle when the alternator cannot maintain output vs. load.
Electricity in a car is anything but free......it costs quite a bit of power and gas mileage to run all the toys, same as your home electric bill: more toys, more load, more $$$ at the end of the month.
Theoretically, and practically, if you were to start the car, insert a large load resistor of the same rating as current internal battery resistance, and remove the battery, the car would be perfectly happy until you had to start it again. |
03-26-09, 10:48 PM
| | Cadillac Owners Member Cadillac(s): 06 CTS V | | Join Date: Feb 2009 Age: 31 | | | Re: Electric water Pump the only reason I am interested in doing the conversion, is due to a coolant leak stemming from the waterpump seal (unconfirmed). The cost is about the same OEM mechanical pump is $450, high performance electrical pump is $500.
PS. a friendly word of advice: for those who are living in a cold climate, make sure the F#@*ing idiots at the cadi dealership put the proper antifreeze in the cooling system (not water). Mine froze, and I am extremely lucky I did push out a frost plug or worse cracked or stretch a head. |
03-26-09, 10:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 04 CTS-V with a little hp persuasion device | | Join Date: Oct 2007 Age: 24 | | | Re: Electric water Pump They filled it with straight water? No antifreeze at all?
__________________ 04 Raven CTS-V / Forged and maggied LS6 / 90mm TB / 8 rib pulleys / 8" overdrive balancer with 2.7" blower pulley / LG G5X1 / Crane 1.8 gold rollers / 1 7/8 Kooks / ARP hardware throughout / Melling oil pump / Cloyes double roller / Volant CAI / Fidanza LS7 flywheel / Spec Stage 3 / Ground Control / QA1's / RC51 motor mounts / UUC diff, and shifter bushings / UUC Vknob / Katech STS / Rear strut bar / Kars III |
03-26-09, 10:57 PM
| | Cadillac Owners Member Cadillac(s): 06 CTS V | | Join Date: Feb 2009 Age: 31 | | | Re: Electric water Pump yep... I do ask the question who's the bigger idiot? me for not checking or them for being too lazy or stupid.
don't answer |
03-26-09, 11:01 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 CTS-V raven black | | Join Date: Nov 2008 Location: North West Florida Age: 33 | | | Re: Electric water Pump Quote:
Originally Posted by JohnnyV yep... I do ask the question who's the bigger idiot? me for not checking or them for being too lazy or stupid.
don't answer | if they did fill with 100% water and it was still within a reasonable time frame ago they should have to pay to fix |
03-26-09, 11:04 PM
Originally Posted by submariner409 The kicker is that the battery functions only to start the car, never afterward. The alternator carries every bit of the total electrical load as long as the engine is running and the charging system is intact. Cyclical loads, such as A/C clutch cycling and electric fan loads, as well as radical audio loads, have no effect on the battery, per se: they vary the amperage/voltage supplied by the alternator as a function of sensed battery condition. The installed alternator is usually loaded to only some of its high rpm capacity. Yes, the battery may contribute current, but only at low rpm idle when the alternator cannot maintain output vs. load.
Electricity in a car is anything but free......it costs quite a bit of power and gas mileage to run all the toys, same as your home electric bill: more toys, more load, more $$$ at the end of the month. | This reminds me of the discussion about electric radiator fans versus mechanical fans many years ago. Since then electric fans have become almost standard on many domestic and foreign cars. I thought this was because it had been established with little doubt that the electric fans used less energy (increased mpg) as compared to the mehcanical fans.
Afterall is said and done the before/after dyno test already mentioned would answer the specific question as whether the electric water pump would increase instaneous (WOT) horsepower without regard to its effect on mpg, etc. |
03-26-09, 11:10 PM
Originally Posted by darkman This reminds me of the discussion about electric radiator fans versus mechanical fans many years ago. Since then electric fans have become almost standard on many domestic and foreign cars. I thought this was because it had been established with little doubt that the electric fans used less energy (increased mpg) as compared to the mehcanical fans.
Afterall is said and done the before/after dyno test already mentioned would answer the specific question as whether the electric water pump would increase instaneous (WOT) horsepower without regard to its effect on mpg, etc. | Mods can we get a little dyno "smiley" it always comes up and would be funny
"this thread is worthless without a dyno" |
03-26-09, 11:12 PM
| | Cadillac Owners Member Cadillac(s): 06 CTS V | | Join Date: Feb 2009 Age: 31 | | | Re: Electric water Pump I had the car shipped from California to Toronto Canada through a dealership network. If I start accusing the dealership, service techs, etc. they will just point the finger at the other guy or me. The part that floors me is not the fact that it hit minus 10 uphere frequently, who in their right mind would use water... coolant is not only designed not to freeze, but to lubricate the pump and prevent internal corrosion. The warranty is almost up, I will be doing my own service from now on. |
03-26-09, 11:17 PM
Originally Posted by ccextra1976 Mods can we get a little dyno "smiley" it always comes up and would be funny
"this thread is worthless without a dyno" | Agree.
In all fairness however, the original author of this thread was asking if someone had already been down this rabbit trail. |
03-26-09, 11:20 PM
Originally Posted by JohnnyV I had the car shipped from California to Toronto Canada through a dealership network. If I start accusing the dealership, service techs, etc. they will just point the finger at the other guy or me. The part that floors me is not the fact that it hit minus 10 uphere frequently, who in their right mind would use water... coolant is not only designed not to freeze, but to lubricate the pump and prevent internal corrosion. The warranty is almost up, I will be doing my own service from now on. | Hell I thought you guys ran Dexcool in your toilets up there. I cannot imagine someone grabbing a water hose to fill a radiator. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
