Guys - I'm giving away my last set of these tomorrow, so I took a few pictures before they go. They're very easy to make yourself.
Parts: (4) hockey pucks (any Michigan sporting goods store - you SoCal guys are out of luck), (4) 3" long, 1/4"-20 thread, 2" wide head spring loaded toggle bolts (Lowes), 4 3/4"washers, 4 lock washers.
Tools - 3/4" spade bit, 1/4" standard bit, drill press or hand drill, tape, screw driver or ratchet - see below.
Drill the pocket to about half the depth of the puck. (mark bit with tape to make them all the same) Do this outside unless you want the house to smell like burnouts. Finish the holes with the 1/4" bit. Thread bolts in. I smashed the tip of the threads on all 4 with a hammer to keep them from accidentally spinning off if I ever wanted to remove them.
Feed the spring head into the oval holes in the support rails at the jacking points. Pull down as you tighten. I've had mine on the car for about a year now, and they're really nice for rotations and snow tire swaps. There's only about 5 1/2" of room to the ground on the fronts, and 7" or so on the rear. Check your jack clearance before you get too far.
They will work on most GM cars, but I tried a set on my 02 Z28, and I didn't have enough clearance for the jack. The hole picture shown is on the wife's STS. The front pair sticks down far enough to see from across an empty parking lot if you look close, but it doesn't bother me. It may be an issue for some of you.
Possible improvements would be to use hex bolts instead of the Phillips heads shown. It takes a stubby screwdriver as is. If you want to someday take them off, stainless hardware wouldn't hurt, or at least you should grease the threads before you put them on.
V8V
V8V
