Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: $8.88 - Brake Caliper Decals
Old 03-01-09, 07:49 PM
View 8th Day's Photo Album
Casino Cash: $2415
Arrow $8.88 - Brake Caliper Decals
The Finishing Touch
*V-series set pictured; CTS set also available.
CLICK HERE for details, color options and ordering information.
Cut from premium automotive grade vinyls that have been tested to adhere to aluminum with no ill effect from -58 to 230 degrees and are resistant to most oils, greases, and fuels. The decals also come on clear application paper for easy installation.
  #2 (permalink)
Old 03-01-09, 08:15 PM
jweymar's Avatar
Cadillac(s): 05 Maggied CTS-V
View jweymar's Photo Album
Casino Cash: $11080
Re: $8.88 - Brake Caliper Decals
cant order them
2005 BlackRaven CTS-V Maggied and Forged LS3 |2.6 pulley |Lingenfelter Stage 2 Heads | Comp Blower Cam | Spec 3+ clutch | Corsa | Kooks 1 3/4 | High Flow Cats | UUC Engine & Trans Mounts | B&M Shifter | BMR Pinion Brace | BMR AWH | BMR Toe Rods | BMR Trailing Arms |Hendrix Pro Axles | Eibach F/R sway bars | Meth Injection | Ground Control 600F/650R | FG2 | Hawk HP+/HPS | Built by RPM Motors
  #3 (permalink)
Old 03-01-09, 08:30 PM
LUVMY04V's Avatar
Cadillac Owners Master
Cadillac(s): 04 cadillac cts v
View LUVMY04V's Photo Album
Casino Cash: $18158
i need another set of these just for good measure Goth I sending u a pm
Used To ..............LUV my 04 V
  #4 (permalink)
Old 03-01-09, 08:49 PM
Casino Cash: $2415
Originally Posted by jweymar View Post
cant order them
I've sent you a PM.
If anyone else encounters a problem using the 8th Day site, please send me a PM here or an email to administration@8thdaycreations.com . Thank you.
  #5 (permalink)
Old 03-01-09, 08:59 PM
LUVMY04V's Avatar
Casino Cash: $18158
rofl!!!!
http://8thdaycreations.com/catalog/p...products_id=53
  #6 (permalink)
Old 03-01-09, 10:49 PM
Cadillac Owners Enthusiast
View rjoffe's Photo Album
Casino Cash: $10960
230 degrees just won't cut it.
  #7 (permalink)
Old 03-01-09, 11:16 PM
Vecstasy's Avatar
Cadillac(s): Cadillac
View Vecstasy's Photo Album
Casino Cash: $15005
Just curious. Are these the exact same size as the Decals that are on the calipers stock?
  #8 (permalink)
Old 03-01-09, 11:35 PM
gothicaleigh's Avatar
Cadillac(s): Current: '94 STS Past: '93 Eldorado, '98 ETC, '03 CTS
View gothicaleigh's Photo Album
Casino Cash: $15988
They're going on the outside of your caliper, not your rotor.
For an idea on caliper heat levels, most caliper seals need to be replaced if they exceed 240 degrees (not to be confused with rotor temps, which can easily climb to double that).
The decals are tested to adhere to bare aluminum (which is a very slippery metal) with no ill effect up to 230 degrees. Trust me, if your caliper becomes hot enough to melt off the adhesive on these, you will have more things to worry about than your decals.
  #9 (permalink)
Old 03-01-09, 11:49 PM
Casino Cash: $2415
They will. We've installed them on cars that have seen fairly heavy track use and sold many other sets online (including to members here) and have never had a reported failure.
We use only the finest automotive-grade vinyls available.
Each set comes with three different sizes (8 decals total).
4 @ 3.000" long
2 @ 4.000" long
2 @ 2.500" long
$888, brake, caliper, decals
Censor is OFF
