Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Clutch Position Sensor
Old 01-27-09, 03:48 PM
Cadillac(s): CTS-V
View MKC7's Photo Album
Casino Cash: $1015
Hey everyone. About a week ago, i threw a CEL. Right before that, the cruise control stopped working. I hooked up an obd-II reader, and it showed something for the clutch position sensor.
I cleared the code and it stayed off for a few days, however, the cruise control did not work and it recently came back. This leads me to believe i definitely need a new clutch position sensor (the cruise control not working makes sense, as it ties into this sensor)
Where can I find one of these sensors, and how hard are they to replace?
Any help is greatly appreciated, Thanks!
  #2 (permalink)
Old 01-27-09, 05:29 PM
wgbanks's Avatar
Cadillac(s): 2004 CTS-V
View wgbanks's Photo Album
Casino Cash: $5480
Re: Clutch Position Sensor
Call Luke at Lindsay and he can get you a new switch. Then search this site for clutch switch and you will find a post with a .PDF that details the replacement procedure. I tried to include the link but was unable... I'm still to much of a newb.
  #3 (permalink)
Old 01-27-09, 05:40 PM
Washin's Avatar
Cadillac(s): Ext and CTS-V
View Washin's Photo Album
Casino Cash: $11515
The replacement is a royal pain in the ass. The sensor rides on the rod of the master cylinder and it is not replaceable by itself. You will have to replace the whole master cylinder. It is buried up in the dash and the only way to replace it is removing the brake master, which requires a special tool then crawling up under the dash. If you are not an advanced wrench I would highly recommend having it professionally replaced. Good luck
Your source for the "V" series flag!
  #4 (permalink)
Old 01-27-09, 07:04 PM
darkman's Avatar
Cadillac(s): 2005 CTS-V
View darkman's Photo Album
Casino Cash: $12594
Here is the thread with the PDF instructions.
http://www.cadillacforums.com/forums...ode-p0833.html
Rock Auto sells the part - not very expensive.
My reading of the PDF (in the above thread) as well as the Service Manual indicates this is a relatively easy replacement. The switch is located under a panel that is underneath the steering wheel and held by three screws and an electrical connector.
clutch, position, sensor
Censor is OFF
