| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: My Quest to 500 HP, the right way...
11-23-08, 01:21 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: My Quest to 500 HP, the right way... A heads and cam package will cost more than a maggie if you don't do the work yourself. If you get the right package, you'll be almost exactly where MauiV is at as far as HP and torque numbers. If you're on a budget, maggie is the way to go. The final bill was somewhere about $11,000 - $13,000 for heads, cam, internal motor upgrades for reliability, CAI, headers, exhaust, LS7 clutch and flywheel, tuning and installation. |
11-23-08, 01:38 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: My Quest to 500 HP, the right way... Quote:
Originally Posted by UnsafeAtAnySpd ...I miss California.  | Not West Los Angeles, I hope.
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
11-23-08, 03:44 PM
| | Cadillac Owners Enthusiast Cadillac(s): '04 CTS-V, '97 AWD Talon, '86 Fiero, K5 Blazer, '68 Corvair | | Join Date: Aug 2007 Location: Cheyenne, WY Age: 24 | | | Re: My Quest to 500 HP, the right way... Just have to watch out for the lippy broken skateboard types. |
11-23-08, 05:45 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: My Quest to 500 HP, the right way... |
11-23-08, 07:01 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: My Quest to 500 HP, the right way... Quote:
Originally Posted by rand49er There's nothing wrong with FI. Since everybody's still waiting for a turbo setup that's in kit form with some miles on it as proof it's a viable alternative, that leaves us with a Maggie or a ProCharger.
Staying with the Maggie since it achieves the power you want whereas the ProCharger might be overkill, it's less intrusive than a cam et al as far as altering the motor (you only replace the intake manifold), it's on tap ANYTIME you want it without regard to what's left in the bottle, it's proven to stay within the constraints of the stock motor internals, it's readily available in kit form, it retains excellent driveability as a DD, it's easily reversible, guys are still getting warrantly work done by a lot of dealers (though maybe not all), and it might be JUST within your budget, though it's close. It does overshoot your desired power level significantly especially when coupled with LT headers.
Also, as suggested above, see if you can drive a V setup with a bottle, one with a good cam setup, and a maggie before you take the plunge, do it. | 1 word for ya. Heat. Soak.
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,327 and counting... |
11-23-08, 07:47 PM
| | Cadillac Owners Connoisseur Cadillac(s): Kooks,MOMO seats,C5 hubs,3489# | | Join Date: Jun 2007 Location: Ashland, Ohio | | | Re: My Quest to 500 HP, the right way... Maggie is probably the most reliable but the worst in efficiency, like Jim mentioned.
Norm Quote:
Originally Posted by thebigjimsho 1 word for ya. Heat. Soak.  | |
11-23-08, 07:51 PM
| | Cadillac Owners Connoisseur Cadillac(s): Maggied 2004 CTS V Black Raven cause its faster | | | | | Re: My Quest to 500 HP, the right way... My 437/431 numbers came with a IAT of 190 on the 6th pull of the morning. The tune pulls timing when the heat gets up there so I am interested to see what I could pull in weather like today. |
11-23-08, 08:35 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: My Quest to 500 HP, the right way... If you get a Maggie installed, they have to remove the crank pulley. Might as well put in a bigger pulley. It'll give some more hp, but a lot more torque (30-40?).
In SoCal, you'll need a meth kit to keep the heat soak. In check. Sould only be a few hundred dollars.
With labor+tune, you should be under your budget. Down the road you can install headers. At that point, you should be real close to 500rwhp. Probably over 600hp at the crank.
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
11-23-08, 10:36 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: My Quest to 500 HP, the right way... Thanks for the posts. I will check in once I begin. BTW, I am in San Diego, not West LA. lol. No need to reply anymore to this thread... |
11-24-08, 09:04 AM
|  | Cadillac Owners Fanatic Cadillac(s): 05 Maggied CTS-V | | | | | Re: My Quest to 500 HP, the right way... Quote:
Originally Posted by thebigjimsho 1 word for ya. Heat. Soak.  | I am in love with Meth injection, just got done with track day and heat soak didnt rob me of power and everything ran cooler.
__________________ 2005 BlackRaven CTS-V Maggied and Forged LS3 |2.6 pulley |Lingenfelter Stage 2 Heads | Comp Blower Cam | Spec 3+ clutch | Corsa | Kooks 1 3/4 | High Flow Cats | UUC Engine & Trans Mounts | B&M Shifter | BMR Pinion Brace | BMR AWH | BMR Toe Rods | BMR Trailing Arms |Hendrix Pro Axles | Eibach F/R sway bars | Meth Injection | Ground Control 600F/650R | FG2 | Hawk HP+/HPS | Built by RPM Motors |
11-24-08, 10:31 AM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: My Quest to 500 HP, the right way... Originally Posted by thebigjimsho
1 word for ya. Heat. Soak. <- isn't that two words?
__________________ Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Shifter Bushings/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff w/updated pinion, Clear Fogs DDM bulbs, Clear Sidemarkers, CTS center console, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq |
11-24-08, 10:58 AM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: My Quest to 500 HP, the right way... Quote:
Originally Posted by MauiV Trick flow heads, Vindicator cam, Kooks LTs plus upgrade some internals. But what do I know I have a Maggie and only get 437 to the wheels.
Trukk should be checking in anytime now...... | Quote:
Originally Posted by PISNUOFF A heads and cam package will cost more than a maggie if you don't do the work yourself. If you get the right package, you'll be almost exactly where MauiV is at as far as HP and torque numbers. If you're on a budget, maggie is the way to go. The final bill was somewhere about $11,000 - $13,000 for heads, cam, internal motor upgrades for reliability, CAI, headers, exhaust, LS7 clutch and flywheel, tuning and installation. | You rang
The one thing the OP has going for him, that some of us don't is he has an LS2 based V. This gives him the option of using much less expensive heads and getting great results if he goes heads and cam, due to the 4" bore of the LS2.
A nice L92/L76 heads intake package will meet or beat a much more expensive Premium Gen III head (i.e. AFR 205's TrickFlow's etc.) / FAST 92 setup IF the right cam is chosen.
Here is a heads kit, with most of the bits you'd need: http://www.slponline.com/view_product.asp?P=12292
You' dhave to pair that with the right cam, and accessories (I.E. headers, etc.) to meet your goals, but you could get very close @ about 8k budget installed.
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
11-24-08, 12:03 PM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: My Quest to 500 HP, the right way... ^^dang truck motors^^ lol |
11-24-08, 03:02 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: My Quest to 500 HP, the right way... Yup truck motors and now we're putting actual truck motor parts on them. The L76 heads are actually some of the first iterations of the LS7 heads. They flow almost as good as aftermarket P&P ones in raw cast form. I ended up going with P&P 243 stock castings because at the time people were just starting to use the L76/L92 setup and I wanted something proven. |
11-24-08, 05:10 PM
|  | Cadillac Owners Fanatic Cadillac(s): 06' cts-v infrared | | Join Date: May 2006 Location: south dakota | | | Re: My Quest to 500 HP, the right way... So would I be better off going with the L92/L76 setup (for the money) over a trickflow 225 head on my truck motor. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
