  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Transmission issues
Old 11-18-08, 10:58 AM
ichpen's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Cadillac CTS-V (2006)
View ichpen's Photo Album
Casino Cash: $10425
Transmission issues
Not sure if this particular case has been discussed yet.
Recently (a few weeks), I'm getting noticeable shaking/vibration when shifting from 1st to 2nd at high rpm (3k+). Not necessarily when accelerating hard. It seems to be quite consistent now and on occasion it's quite a violent shake (no rattling).
It happens not when the clutch is being depressed but when I'm physically moving the shifter from 1st to 2nd (best I can pinpoint) with the clutch fully down.
Not having issues getting into gear (over and above what is normal).
Could this be the diff bushing acting up?
Motor mounts look fine.
Opinions?
UUC shifer/knob l Tints l Racing Pedals l The Wagon l Hotchkis sways l FG2s l Spoiler l Magnaflow l Lots of LEDs l UUC Flywheel l UUC SS Brake Lines l Dynamat Extreme l RT Hi-Flow Cats l Speed Bleeders l Adjustable endlings l Custom cradle bushings l UUC diff bushing l P&P throttle body l Maggie (2.7 pulley) l Snow Stg 2 METH l Ground Control l 160 TStat l Crank Case Vent l Solid Motor Mounts l Braille Battery l 8 rib pulley (OD) l VRX2 CAM | dyno tuned to 474 HP/474 TQ
  #2 (permalink)
Old 11-18-08, 11:06 AM
lollygagger8's Avatar
There I is
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $9253
Re: Transmission issues
Trans Mount?
Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Shifter Bushings/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff w/updated pinion, Clear Fogs DDM bulbs, Clear Sidemarkers, CTS center console, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq
  #3 (permalink)
Old 11-18-08, 01:00 PM
Cadillac(s): '05 Stealth V
View p0ng0rs's Photo Album
Casino Cash: $2180
Master/Slave issue not disengaging the pressure plate 100%?
  #4 (permalink)
Old 11-18-08, 01:37 PM
ichpen's Avatar
Casino Cash: $10425
Good suggestions. The dealer did replace the slave recently so perhaps you're onto something.
  #5 (permalink)
Old 11-18-08, 01:47 PM
Casino Cash: $2180
If they didn't bleed it right that could be a problem.. or if it's just faulty parts.. I've seen bad parts come out of a brand new box too many times for comfort.. try diagnosing a problem when you replace a faulty master with a brand spankin new.. faulty.. master. then replace the slave.. then rebleed 4 times.. then mess with the clutch pedal assembly.. throw a bunch of things around in a fit of rage, and replace the master/slave/lines from a working car to find it works.. and reverse-engineer what happened down to the new master being also bad. ;(
  #6 (permalink)
Old 11-18-08, 01:51 PM
ichpen's Avatar
Casino Cash: $10425
Dear god that does sound like endless fun worthy of a ticket booth and admission price.
I'll let the dealer take it apart and figure it out (was looking to for suggestions to guide them) whilst I surreptitiously slip in a UUC flywheel when they're not looking....
  #7 (permalink)
Old 11-21-08, 05:05 PM
ichpen's Avatar
Casino Cash: $10425
Update, dealer couldn't figure it out on a visual inspection. Fluid looked fine. Tranny mount looks fine. Any other suggestions I can throw at them? (Bringing it back to the dealer next Monday).
  #8 (permalink)
Old 11-21-08, 07:11 PM
Cadillac(s): Maggied 2004 CTS V Black Raven cause its faster
View MauiV's Photo Album
Casino Cash: $12340
Flywheel balanced?
  #9 (permalink)
Old 11-21-08, 07:52 PM
PISNUOFF's Avatar
Cadillac(s): 2007 CTS-V
View PISNUOFF's Photo Album
Casino Cash: $11635
Does it do it if you don't move the shifter? i.e. If you run it up to 4000 rpms, push in the clutch and just coast while the rpms drop.
  #10 (permalink)
Old 11-22-08, 09:57 AM
ichpen's Avatar
Casino Cash: $10425
Nope. Only seems to happen when shifting
issues, transmission
Censor is OFF
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
