Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). - Page 9
Page 9 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 121 to 135 of 245
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Twitch Looking forward to hearing about your results. And check it on the highway, that's when mine ...
  1. #121
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,455
    re: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
    Quote Originally Posted by Twitch View Post
    Looking forward to hearing about your results. And check it on the highway, that's when mine gets bad.
    Looks like I dropped about 20-25F on the highway. It stabilized in the mid 220s yesterday, instead of the upper 240s.
    Tomorrow at V Day 4 will be the true test.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  2. #122
    VforMe's Avatar
    VforMe is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V with 2 carseats in the back and a f'ing minivan
    Nov 2008
    Franklin, TN (Nashville)
    37
    607
    Thanks Heavy
    My oil temp has been running up to 300 for a while but it's been really bad since we've been in the mid 90's for the whole month of June. I checked the voltage and it was running 250mv. I pulled off the bolt and sanded everything down and it went down to 110mv and after a 15 minute spirited drive my oil temp held steady at around 200*. I was hoping the voltage would of dropped a little more but it's fixed so I'm happy. I did not do the bolts on the back of the heads only the main ground on the the right side.
    I've been putting this off for a while because I thought it was going to involve pulling the sensor, but this took all of 5 minutes. I feel like a dummy for not doing it sooner.
  3. #123
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    I would appreciate it that if you do this and it fixes your problem, please post so.
  4. #124
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    As I was changing my spark plugs, I found another ground. I had my coil packs off, otherwise I couldn't see it. It's on the back of the passenger side head right above the last plug.
    So I finally put a star washer on the fender wall ground. I scratched some paint off, but need to get back in there and do a better job. As is, driving around town with AC and lights on temps were very steady at 222. It used to bounce around 5-10*.
    Didn't pay attention to highway temps (this is when mine starts to climb) cuz I was focused on something else.
    I'm getting closer every time I mess with it and will post up when I have more to add.
  5. #125
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    I'm going to check into this too.
    I'm sure you guys in the yellow group noticed me at V Day during 1 session just puttering around at 50.
    My oil temp had hit 302 and the alarm was going off so I put it into 5th and just cruised for 2 or 3 laps.
    I don't think it was an issue with the sensor as the track temps were probably over 100 and I was winding 3rd into the rev limiter quite often.
    I did manage to get it to drop during that session and once it sat for lunch it was fine the rest of the day.
    I'm guessing the rain cooled the track down plus I was shifting into 4th before redline.
    Still something I want to look at tho...
  6. #126
    Nov 2004
    8,788
    Here are pics of where the voltage is measured and the washer used to "fix" it.
    Notice the probe is on the head of the bolt (not the cable terminal).
    The voltage being measured (lights and A/C on) is the drop across the junction of the bolt (body ground) to the cable terminal after the washer was installed.
  7. #127
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Damn, dopy me did it with the car off.
    I'll check it again in a bit, but this is what I got.
  8. #128
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Ok this is what I got with everything on.
    CRAZY hot the next couple days. If I'm brave enough to go out, it should be a good test.
  9. #129
    Nov 2004
    8,788
    Turn on the A/C, and the lights for the "acid test".
    Pretty interesting to see that much drop huh?
    This is a major problem with the high tech electronic monitoring systems in autos.
    Ground referenced (single ended) measurements can change when the ground reference is different as the PCM is using "frame ground" and the sensors are using "engine ground".
    The sensor sends a variable 5 volt signal to the PCM which got offset almost 1/2 volt (in Reed's car) because of the bad contact.
    Because of the low current the sensor draws, the biggest offset it could generate is minimal though its' ground.
    To put is simpler, the voltage is correct coming out of the sensor.
    The "ground reference" the PCM uses for measurement gets "tricked" by the bad connection into reading a false high (sensor output + offset).
  10. #130
    jnrandall's Avatar
    jnrandall is offline Cadillac Owners Enthusiast
    Jul 2006
    Manhattan
    674
    Thanks for the tip! I was dinging all over place yesterday and for the past 5 years. I applied the fix about 20 minutes ago and IT WORKED! It seemed too simple a fix to actually work, but it did. Just before I applied it, my temps were hovering around 270 with out the ac and off the chart with the ac on. right after the fix, 218 without the ac and 224 with the ac. Its 94 in NYC and it's 69 in the car!
  11. #131
    Nov 2004
    8,788
    Next to FREE, I bet this is the cheapest fix for a problem with the V.
  12. #132
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    What battery voltage are you guys getting in the DIC? I'm still at low 13s with everything on.
  13. #133
    Nov 2004
    8,788
    Lowest is 12.8
    Highest over 14.
  14. #134
    DRKSIDE's Avatar
    DRKSIDE is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V Black
    Dec 2007
    Maryville, TN
    325
    Quote Originally Posted by heavymetals View Post
    I helped Reed with the same problem(s) as the hot weather is starting to return (and so are the alarms).
    The culprit in his case turned out to be the ground right under the hood support and very easy to get at.
    Reading a DVM from the bolt head to battery negative showed almost 1/2 volt! (450 mv).
    We removed the 15 mm bolt, added a 3/8" "star" washer (between lug and frame) and the voltage dropped to less then 50 mv.
    All the problems vanished.
    This solved my problem too. A little sand paper and a star washer did the trick. 5 minutes and nothing out of pocket as I had a washer laying around the garage. I had been to the dealership twice with this issue and once again, you guys fixed what they couldn't.
    Is my membership up for renewal?
  15. #135
    AAIIIC's Avatar
    Aug 2007
    6,455
    Quote Originally Posted by AAIIIC View Post
    I'm still not sure the temps I'm seeing are real, but they were definitely lower on track than they had been before. As previously stated, at previous track days I would peg the oil temp at 329F within 10min or so each session. At V Day 4, oil temp typically peaked around 290Fish. Only in the last session did I get the alarm, and even then I don't think it went above about 305F.
  16. Remove Advertisements
