Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). - Page 8
Page 8 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 106 to 120 of 245
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). in Cadillac CTS-V Series Forum - 2004 - 2007; It is the ground to the frame/body. There is another battery ground right next to cylinder #7 (passenger side). Glad ...
  1. #106
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    re: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
    Glad it worked for ya!
    Heavy strikes again.
    Science triumphs over superstition!
  2. #107
    SuperVeee is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    May 2006
    149
    All these bogus temp numbers are pretty scary not knowing if we are cooking the motor or not. I know on my aircooled cars with dino oil if I ever reach 250 I have to turn it off or risk bearing damage by going higher.
    After my V hit 285 the dealer said it was a bad sensor and replaced it.
    I am picking up my V today and I have yet to find anyone at the dealer that can give me a straight answer on what the maximum oil temp should be for the V.
    Anyone know?
  3. #108
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Anybody know what ground the oil pressure uses?
  4. #109
    Nov 2004
    8,787
    Oil pressure sensor uses the ground on the back of the head.
    However, that may not "fix" the problem as a bad ground to the frame may set off the reference voltage used in the PCM so you may still get errant readings.
    If you can use a DVM, connect one lead to the battery negative and then measure the voltage drop (in millivolts) at the HEAD of the bolt (usually a 15mm) securing the ground connection..
    Should be less then 50 millivolts with everything on (lights, A/C).
  5. #110
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,319
    Quote Originally Posted by SuperVeee View Post
    Anyone know?
    The V is no different than any other engine, in that it's pretty hard to define what exactly the highest allowable temperature is. Somewhere in the 280-300F sustained temperatures at the bearings is probably not good, as even good synthetic oils are going to start breaking down somewhere in that range.
  6. #111
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Quote Originally Posted by heavymetals View Post
    Thanks heavy
    T/J over
  7. #112
    calicadi's Avatar
    calicadi is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Aug 2004
    797
    Fixing that ground really made a difference. Ambient today was 107. Oil never got above 222 in stop&go. Now this could be psychological but I think all the guages are reading different and steadier, and my wife says I'm better looking and my breath has never been fresher. Thanks again!
  8. #113
    Nov 2004
    8,787
    I am very glad that this "fix" seems to solve a lot of the errant problems.
    The "acid test" is to have everything on full blast and see if you get alarms to go off.
    I think your 107degs and stable readings is the proof it works.
    The best proof would be no alarms at the track.
  9. #114
    calicadi's Avatar
    Aug 2004
    797
    Ditto that range from http://www.azautomasters.com/
    They do all the work on my V I can't do. Here in the desert, theytell me they do a share of dry sump conversions for their vette customers.
    p.s. I use nothing but Redline... engine, trans and diff. Everything's holding up well and still on original diff.
    Quote Originally Posted by AAIIIC View Post
  10. #115
    May 2006
    149
    I have produced rod knock bearing damage at 260 oil temp on another car. Confirmed the gauge and sensor were only a couple of degrees off on that car so high oil temps really make me sweat.
    Even with synthetic oil I saw 285 just before I dropped at the dealer. I just found out from the dealer that my sensor was off in the V and it was replaced. Now sitting in traffic with AC on and 95 air temp I never got over 230. So the sensor was about 50 degrees off. Nice that I don't have to freak out now although I still watch the oil temp more than the speedometer.
  11. #116
    AAIIIC's Avatar
    Aug 2007
    6,319
    I did the star washers on the fender/chassis ground and the passenger side head ground last night. Sanded some paint off the fender one, and sprayed Caig PreservIt contact cleaner/preserver on both. I most likely won't drive the car until Sunday as I head to Summit Point, and then Monday will be the true trial by fire. At past track days I've pegged the oil temp gauge at 329F within probably 10min or so each session, so I'm curious to see if fixing this issue is/was as simple as improving the contact for those two grounds.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  12. #117
    Nov 2004
    8,787
    Me to.
    Hope it works out for ya.
  13. #118
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Looking forward to hearing about your results. And check it on the highway, that's when mine gets bad.
  14. #119
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Feb 2003
    California
    3,987
    Heavy was 100% right... We fixed the grounds and my temp went from running in the 300s and dinging like a mofo to 200s-220s SIMPLY by fixing the ground on the back of the heads and the right part of the engine bay...
    KUDOS TO HIM for finding this and saving me a headache (I was about to drain oil and start replacing sensors!). When it comes to electrical, heavy is my guy!
    Reed-out.
  15. #120
    Nov 2004
    8,787
    Aw shucks it was nutin
    YOUR WELCOME.
  16. Remove Advertisements
