Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). - Page 5
Page 5 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 61 to 75 of 245
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). in Cadillac CTS-V Series Forum - 2004 - 2007; Any progress?...
  1. #61
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,790
    re: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
    Any progress?
  2. #62
    CtsVrod's Avatar
    CtsVrod is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V / 06 Escalade
    Oct 2007
    So Cal - Agoura Hills
    34
    1,059
    Nada... It was going off today in traffic again
  3. #63
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by CtsVrod View Post
    Unplug that bitch.
  4. #64
    c4ss's Avatar
    c4ss is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V, Black
    Jun 2008
    Northern New Jersey
    2,166
    Quote Originally Posted by Twitch View Post
    Unplug that bitch.
    Mine was going off TONIGHT....as in like 60 degree weather. I'm about to unplug it. Where is this sensor again? Thanks.
  5. #65
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by c4ss View Post
    Just got back from a short ride. At startup, the nav tells you to check your oil level. Press OK once, and it wont bother you till you turn the car off. I did check my level, and its perfect.
    You might be able to get to the plug with the car on the ground, and wheel turned to the left (I had the wheel off anyway). Its on the oil pan, facing the pass wheel.
  6. #66
    c4ss's Avatar
    Jun 2008
    Northern New Jersey
    2,166
    Thanks bud. I'm kind of lazy these days
  7. #67
    nxlr8's Avatar
    nxlr8 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Platinum CTS-V
    May 2006
    Aurora, IL
    446
    I can make it come on now though... Since I've dealt with it for soo long. Just wait for the Car to Warm up (30+ mins) Hit the Brakes, Turn on AC, Hit the Window Up Buttons, and WA LAH!!! Ding Ding Ding - Pisses me OFF!!
    Did this "trick" and it did the same thing...
    250*, hit the brakes, jumps to 280* in a second.
    Hit both windows down buttons while hitting the brake - Chimes go off!
  8. #68
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Anybody check their battery voltage? Mine seems to be a little low. Starts at 14+. Then as the car warms up, and I'm using the AC, it drops to +/- 13. I really need to get off my ass, and check those grounds before I waste $$$ on a new battery.
    Keep you guys posted.
  9. #69
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Sensor is a 3 wire connector, passenger (right) side oil pan.
    If electrical loads seem to change the reading then it could be a grounding issue.
    I have read a TSB on redoing the ground but have never done one.
  10. #70
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Hmmm, can TSBs be done out of warranty?
  11. #71
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Sure, but standard labor rate applies.
    The only thing the TSB will get you is a quicker diagnosis.
  12. #72
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by CTSV_510 View Post
    So in my language, TSB means DIY
  13. #73
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quick update.
    I seem to be having charging issues, and a new battery didn't help. So I decided to check the grounds. Did the one on the fender first. Maggie guys should really check this (except Randy). Took off the bolt, and wire brushed everything. Did one behind the drivers side head, but could not get so much as a finger behind the other head. Then I got under the car to check the starter wires. Took one wire off. It was pretty bad, but I cleaned it up best I could.
    Plugged the sensor in, and drove to work this morning. It was a cool morning, and a short ride. But I had everything on, A/C, lights etc. Oil temps moved around between 210 and low 220s.
    I'll update after I've been on a longer ride.
    Unfortunately, car is still showing low to mid 13v
    Tony
  14. #74
    Nov 2004
    8,790
    If you remove the windshield wiper facia (very easy) you can get at the rear of the heads much easier.
    The passenger side is less of a problem if you remove the battery.
  15. #75
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by heavymetals View Post
    Battery was out. With the wire harness, and some extra Maggie stuff back there, it was too tight.
    I'll see if I fixed the oil temp. Not too worried about that now. Trying to figure out why my voltage doesn't stay at 14 when the car warms up.
  16. Remove Advertisements
