Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). - Page 15
Page 15 of 17 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 211 to 225 of 245
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98). in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by verywhitedevil I just purchased this with the Hotwire kit. So you have pics on your ground kit ...
  1. #211
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    Re: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
    Quote Originally Posted by verywhitedevil View Post
    I just purchased this with the Hotwire kit. So you have pics on your ground kit installed?
    It's very simple. A wire from the battery terminal to the chassis ground. I will add a picture when I get a chance.
  2. #212
    spdracer's Avatar
    spdracer is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Apr 2012
    CA
    Man am I glad I found this forum. I just bought a 2005 V last week. I was reading about sat nav update firmware. I noticed this thread but payed little attention to it because I wasn't experiencing the sensor problem. Yesterday the oil temp alarm went off. And panic ensued. Then I remembered this thread and started watching temp go from 300 to 270 then 250 then back to 300 and realized it must be the ground issue. so this morning I cleaned up the chassis ground and installed star washer. Temps now staying under 220 and not fluctuating so bad. When I have more time I will attack the other ground wires. Thanks for saving me a bunch of stress. If I hadn't read this thread I would still be stressing out thinking I just bought a broken car.
  3. #213
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    If I remember I'll grab you one tomorrow. It is really simple though, I have mine run to an open bolt near the 18mm strut bolts. I think its like a 10mm.
    Quote Originally Posted by spdracer View Post
    Yeah the dinging alarms can be quite nerve racking until you realize its a grounding offset issue. Thanks those early pioneers like Heavymetals and Reed for the direction to go down!
  4. #214
    ddeem is offline Cadillac Owners Member
    Automobile(s): cts-v
    Jun 2009
    44
    6
    I know this battery ground to the chasis seems simple but after having this problem for two years, nothing has been simple for me. Can someone explain hot to connect this 8" hotwire kit (Racetronix) with the battery terminal lugs that are provided? I do not see any 10mm bolts near the battery or strut tower that would be a quick connect. In addition, doesn't the battery ground go directly to the strut tower now? I have replaced the oil temp sensor, cleaned grounds on the back of both heads & main strut ground, added the star washers, added a ground wire from the black lead on the sensor pigtail to the lower part of the chasis and still have this jump in the oil temp from 220 to 300 in seconds while driving. I am at a loss and would really appreciate any help to finally resolve this issue...
  5. #215
    mlimanti is offline Cadillac Owners Member
    May 2006
    81
    I have added this ground wire from the negative battery terminal to the chassis ground, and this still does not fix the problem. It is a large battery cable. Is there any reason why a large gauge wire would be any less beneifical in solving this issue?
  6. #216
    May 2006
    81
    Where exactly is the sensor? I think I would like to try grounding it.
  7. #217
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    45
    4,000
    Sensor is on the passenger side of the oil pan. To the inside of the wheel. It has three wires.
    Knowing I can't trust the sensor, I cut the wire for the temp, I think it was green and white (look back several pages). Now I get --- in my display but the oil level sensor still works. FYI same sensor for oil and temp.
  8. #218
    joshuajohn1981's Avatar
    joshuajohn1981 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS V
    Aug 2012
    35
    329
    OK guys, I have a question, and I'm sorry if this has been covered but bear with me. I am looking at buying a V and when I went to test drive it it was having the oil temp gauge issues. However, the coolant level was staying nice and steady and didn't show any issue. In your opinions, would I still be safe buying this car? The price is pretty damn right! Thanks
  9. #219
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    The probability that the indicated high oil temp is anything other than a gauge/grounding issue is quite small. You could, presumably, attempt cover the issue is the sales agreement.
  10. #220
    Twitch's Avatar
    Mar 2006
    NYC
    45
    4,000
    My fix in post 217
    I would think your safe. You WILL be annoyed, but safe.
  11. #221
    Talyon's Avatar
    Talyon is offline Cadillac Owners Member
    Automobile(s): 2005 Stealth CTSV & 2004 SRX V8 AWD
    Aug 2010
    ATX
    40
    47
    Just wanted to say thanks for this thread. 1.00 worth of washers and no more oil temp warnings. My bad ground was at the passenger side fender. 5 mins and done. Thanks again
  12. #222
    V user is offline Cadillac Owners Member
    Automobile(s): 2005 CTSV
    Jan 2013
    Olympic pennsulia
    59
    42
    Well I added the star washer and it worked until I drove in the rain and then it started again. The next fix is
    to ground the sending unit from the oil pan to a chassis ground anyone else do this yet? Where did they attach the ground?
    I have to put the car up to install my new Revshift trans mount and will take car of the ground at the same time.
  13. #223
    Mar 2010
    San Jose, CA
    29
    979
    Quote Originally Posted by V user View Post
    The best solution is to add an additional grounding strap from the battery to the chassis. I have tried everything else and this is the only one that has worked for me long term.
  14. #224
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,786
    The two "main" grounds are:
    1. Under the hood support. This one is the WORST and you have to wire brush the surface, both sides of the terminal, everything else on the bolt and use contact cleaner on the threads. Install the star washer between the bolt and cable terminal, not between the cable and surface.
    2. Right above the starter motor. Engine ground
    OTHER GROUNDS:
    3. Behind the heads, two.
    4. Driver side near radiator bottom.
    5. Dash board instrumentation, buried in the dash
    A couple of guys (I think it was a couple) found a bad crimp for the ground connection on the sensor plug in.
  15. #225
    Jan 2013
    Olympic pennsulia
    59
    42
    Quote Originally Posted by OneFast V View Post
    Well I went this route , I even had some leftover 4 AWG and bought nice connectors to make it look nice. And still have the problem so either the sending unit or the ground somewhere else?
  16. Remove Advertisements
