| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Tire Load Rating Questions BFG KDW 2
08-06-08, 10:54 PM
| | Cadillac Owners Member | | Join Date: Oct 2003 Age: 25 | | | Tire Load Rating Questions BFG KDW 2 Just to start off I've searched, and didn't find anything relating to load rating. Now on to the question, I just purchased some new BFGoodrich KDW 2 NT tires size 255 45 R18. Problem is they are 255 45 R18 LL 93W (LL = Light Load) supposedly factory tires from a Mustang. My question is the load rating is 93W on the tires I just purchased and 96Y on the factory tires. 93W tires are rated at 1433lbs at 51PSI and 96Y tires are rated at 1565 at 51PSI. I did some research and the CTS-V looks to weight about 300lbs more than a Mustang GT. I didn't see this as a big deal when I purchased the tires as I got them for just under $500 shipped. I know I could have gotten 255 45 R18 96Y KDW 2's but they were over $720 a set and out of stock. Now for some reason I'm wondering if I should put them on due to the lower load rating. 95% of the time the car is empty and I'm the only one in it, and I only weight 150 lbs. Never has the car been fully load and it never will be. I daily drive the car a mix of city and highway driving, and don't road race or drag race the car. Does anybody have any information on this, thoughts, experiences, etc...? I'm reluctant to call a tire retailer, as I really don't trust them and figure they will just tell me to buy another set of tires.
Thanks in Advance
-Justin |
08-06-08, 11:50 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS V | | | | | Re: Tire Load Rating Questions BFG KDW 2 They should work fine! |
08-07-08, 12:14 AM
| | Cadillac Owners Member Cadillac(s): 2004 CTS-V | | Join Date: Jan 2007 Location: Davenport, IA | | | Re: Tire Load Rating Questions BFG KDW 2 You planning on running them at 51 psi... yah didn't think so...
You'll be fine no problems at all.
$500 is a great deal. I bought mine from discount and they were $200/tire or so.
p.s. I love mine. |
08-07-08, 12:42 AM
| | Cadillac Owners Member | | Join Date: Oct 2003 Age: 25 | | | Re: Tire Load Rating Questions BFG KDW 2 Quote:
Originally Posted by jashearer You planning on running them at 51 psi... yah didn't think so...
p.s. I love mine. | I believe at 51 psi that is where the tire can handle the max/most weight. So I would assume at say 32 psi, the tire would have an even lower weight rating. This is my concern at normal pressure levels is this tire going to be safe. Unless I'm misunderstanding how the load rating works.
I guess what I'm worried about is irregular or excessive tread wear, or poor handling. Honestly if they wear a little faster so be it, since I paid considerably less for them. |
08-07-08, 01:44 AM
| | Cadillac Owners Fanatic Cadillac(s): LS6 CTS-V | | Join Date: Jun 2007 Location: Montgomery, Al. Age: 26 | | | Re: Tire Load Rating Questions BFG KDW 2 Quote:
Originally Posted by Sherlock I believe at 51 psi that is where the tire can handle the max/most weight. So I would assume at say 32 psi, the tire would have an even lower weight rating. This is my concern at normal pressure levels is this tire going to be safe. Unless I'm misunderstanding how the load rating works.
I guess what I'm worried about is irregular or excessive tread wear, or poor handling. Honestly if they wear a little faster so be it, since I paid considerably less for them. | im running my kdw 2's at about 32psi, they vary between 31-33 and run up to about 35-36 when hot. I filled mine with nitrogen and it seems to limit the volumetric expansion you get with compressed air.
I also found that lower pressures seem to help the wheelhop in the back. |
08-07-08, 01:44 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Tire Load Rating Questions BFG KDW 2 Well, there goes that vacation to Death Valley in July with the whole family plus their luggage.
Otherwise, I agree, you'll probably be fine.
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
08-07-08, 04:04 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2004 CTS-V Black | | Join Date: Dec 2007 Location: Maryville, TN | | | Re: Tire Load Rating Questions BFG KDW 2
__________________  [center] |
08-07-08, 06:19 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05' CTS-V | | Join Date: Feb 2006 Location: Palm Beach Gardens, FL Age: 24 | | | Re: Tire Load Rating Questions BFG KDW 2 I wouldn't worry about it too much...I've got the same tires...255/40/18 with a 95y rating...just doesn't seem like a big deal to me. |
08-07-08, 06:45 PM
Originally Posted by nikon I wouldn't worry about it too much...I've got the same tires...255/40/18 with a 95y rating...just doesn't seem like a big deal to me. | I decided to go ahead and get them mounted. I took the rims and tires to the dealer today, they will be done tomorrow. Dealer wanted $66 to mount and balance where Discount Tire wanted $107 and Belle Tire wanted $120. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
