CTS-V top speed? - Page 5
Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 61 to 75 of 117
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, CTS-V top speed? in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by TGrits10 Threads related to LS6 rpm limits: http://forums.corvetteforum.com/show....php?t=1971101 http://forums.corvetteforum.com/show....php?t=2000644 http://forums.corvetteforum.com/show....php?t=1988291 Thanks for the info. Would be interesting ...
  1. #61
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    Re: CTS-V top speed?
    Would be interesting to see a dyno graph of a stock LS6 with the rev limit increased to 6900-7000, to see where the power drop off is. Even with a power drop in the higher revs, you'd still have the gearing advantage, which may, in all likelihood, produce stronger acceleration and warrant sticking through the lower gears.
    So the ability to hold a gear longer (i.e., accelerate longer for each gear) and have stronger acceleration in that lower gear, during that extended range (relative to one gear higher), poses a very good reason to increase the rev limit. Seems like a relatively simple way to gain performance, if, in fact, we can spin the stock internals that high.
    Quote Originally Posted by TGrits10 View Post
    Bouncing off the rev limiter isn't any harder on an engine than sitting at that rpm, it just sounds/feels awful.
    You know, thinkin' bout it, I actually seem to recall, I think, that Stealth offers a soft cut off (i.e., throttle body closing), as opposed to the hard fuel cut off in the stock configuration. In other words, I think hitting the rev limiter is less than ideal, especially, if someone continues to keep their foot in it, leading to a lean state, due to the fuel cut off. I think it's for that reason that Stealth offers a soft cut off - so that you don't risk going lean.
  2. #62
    TGrits10's Avatar
    TGrits10 is offline Cadillac Owners Member
    Automobile(s): 99 STS, Black/Tan
    Jul 2006
    Fort Lauderdale, FL
    47
    Quote Originally Posted by atdeneve View Post
    Ya know, I hadn't thought about that. Makes a lot of sense.
  3. #63
    TGrits10's Avatar
    Jul 2006
    Fort Lauderdale, FL
    47
    True, as long as you have more power at rev limit than you do at the rpm you shift to, you can benefit from more revs....which may be why there's so much discussion about bumping the limiter on these motors.
  4. #64
    StealthV's Avatar
    StealthV is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
    May 2004
    MN>ND>MN>SD>IL>MN>IL
    48
    4,860
    Quote Originally Posted by bpitas View Post
    ... I remember reading somewhere (maybe it was "All Corvettes are Red"?) ...
    Good book - Just read it again for the umpteenth time. A similar book on V1/2 development would make for a very interesting read.
    V Owners: Wheelhop sucks. The diff sucks.
    GM's Public Side: It doesn't wheelhop when driven properly and the diff meets design criteria.
    GM Internal Memo: Don't let this happen on V2 or they'll be really pissed.
  5. #65
    tdyguy2k's Avatar
    tdyguy2k is offline Cadillac Owners Connoisseur
    Automobile(s): 12 Blk Diamond CTS-V M6, 05 Stealth Grey V Traded
    Feb 2004
    Pickerington, Ohio
    53
    1,358
    Quote Originally Posted by MikeNice View Post
    whisler what did happen? just curious
    Check this thread: http://www.cadillacforums.com/forums...l-element.html
    I asked the same question this afternoon.
  6. #66
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    Sorry...missed this post. Check out http://www.cadillacforums.com/forums...ph-i-need.html then http://www.cadillacforums.com/forums...ng-ticket.html to see the conclusion.
    Everything is good now. The ticket never hit my record. I'm guessing it had something to do with the three states that had to communicate with each other (Nevada, Arizona and Texas).
  7. #67
    cobra29svt's Avatar
    cobra29svt is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Jun 2008
    Richmond, Va
    35
    154
    As fast as I've been in the V so far.
  8. #68
    92nsx's Avatar
    92nsx is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V , 07 EXT
    May 2005
    Clearwater, MN
    34
    174
    Quote Originally Posted by cobra29svt View Post
    And then................?????
  9. #69
    v-ape's Avatar
    v-ape is offline Cadillac Owners Enthusiast
    Automobile(s): (did) CTS-V
    Apr 2006
    Tokyo, Japan
    39
    723
    I got to 155 then had to shut it down. I was on 540 in NC and it was starting to come to a curve/and my exit. Also, my friend with the V1 was in front and I had just blown past his VW VR6, he was rollin at ~140 when I passed him at 155.
    He now has a Turbo VR6 and says hes smoked a V from a roll. Anyone in NC want to run him for me? I sold my car and am in Tokyo now.
  10. #70
    Jan 2006
    2,114
    Arigato, Mr. Roboto.
  11. #71
    cobra29svt's Avatar
    Jun 2008
    Richmond, Va
    35
    154
    And then???
  12. #72
    Jan 2006
    2,114
    I refuse to play your Chinese food mind games!
  13. #73
    cobra29svt's Avatar
    Jun 2008
    Richmond, Va
    35
    154
    No and then!!
  14. #74
    sleepys4 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS V
    May 2008
    196
    174 Mph the other day I have a friend that can confirm. I have the mods listed below. I was doing 162 up a slight hill then hit 6th expecting the motor to fall flat on its face, It pulled steady all the way up to 174, before a turn. It was kinda stable at that speed. It must be from my lowering springs. I know people will not believe this, but I have no reason to lie. It can be done! I will get a video next time.
  15. #75
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by sleepys4 View Post
    Your mods aren't listed. Also, a great way to confirm is to get the GPS in the video.
  16. Remove Advertisements
