| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Hi temp Plug Wires
05-13-08, 05:18 PM
|  | Cadillac Owners Member Cadillac(s): All of them | | | | | Hi temp Plug Wires with the next V day a year away its time to get back to sellin....
high temperature silicone booted plug wires perfect for you header guys, $100.00 plus shipping.
__________________ Luke Butler
(703) 647-8670 lbutler@lindsaycadillac.com
GM Performance Division T-Shirts - $19.95 plus shipping
05-13-08, 05:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Stealth Gray V | | Join Date: Sep 2006 Location: Ft Myers FL | | | Re: Hi temp Plug Wires ummm those are some nice wires! |
05-13-08, 06:08 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Mallett 427 CTS-V | | Join Date: Aug 2006 Location: SoCal | | | Re: Hi temp Plug Wires Pics on a V?
Any way to get 90 deg boots coming of the plugs?
__________________ 05 Mallett [M] CTS-V: 499WHP 497WTQ | 427 C5R Block | Ron Davis 2-Row Rad | [M] Oi1 Cooler | P&P LS6 Heads | FAST 78 IM | LPE CAI | SW 1-3/4" Headars | RT Hi Flow Cats | B&B 3" Exhaust | RPS Street-Twin Clutch | McLeod Billet Slave Cyl | [M] ST Shifter | RPM Trans Level-V Build | MN6 Geer Ratio Conv | Cryo Treated Diff | GM T2 Diff Cooler | [M] Anti Wheel Hop Kit | FG2 Shocks | SS Brake Limes | Slotted Cryo Rotars | [M] Modified Front Spindles | 275-35-19 PS2 F&R | [M] 19x9 Billet Whels F&R | |
05-13-08, 06:30 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Hi temp Plug Wires Quote:
Originally Posted by lunarx Pics on a V?
Any way to get 90 deg boots coming of the plugs? | your best bet is to buy lsx truck wires (longer) cut and crimp 90* boots if they dont have some. also you are going to need a long 90* boot unless you have some custom headers .. i use longer 45* boots atleast they look longer  and have cleared most headers on lsx stuff with these http://img.photobucket.com/albums/v2...1/SANY0051.jpg |
05-13-08, 07:04 PM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: Hi temp Plug Wires mmm ... bookmarked
__________________ 05 CTS-V / maggie 2.8 / b&m shifter & uuc bushings / gto shift knob / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps / 265|40 bfg kd / ngk tr6
434 rwhp / 412 rwtq..........are you new to the forum? READ THIS and then TRY THIS. |
05-13-08, 08:38 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: Hi temp Plug Wires ohm rating> |
06-05-08, 01:41 PM
|  | Cadillac Owners Member Cadillac(s): All of them | | | | | Re: Hi temp Plug Wires still a few sets left.... |
06-08-08, 12:47 AM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Aug 2007 Location: Brooklyn, NY | | | Re: Hi temp Plug Wires what brand are these? |
06-08-08, 03:25 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | | Re: Hi temp Plug Wires Question,
What is the ohm resistance on the wires?
Stock GMs are somewhere between 900-1000 ohms of resistance...
MSD 150ohms (Not my favorite)
Moroso 20ohms (MUST HAVE BUT YOU PAY BIG) |
06-11-08, 03:44 PM
|  | Cadillac Owners Member Cadillac(s): All of them | | | | | Re: Hi temp Plug Wires Quote:
Originally Posted by AlmostAV ohm rating> | OHM rating is 180 |
06-11-08, 03:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: Hi temp Plug Wires Quote:
Originally Posted by Lindsay Cadillac Parts with the next V day a year away | Year? Its still Oct. 20, right?
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
06-11-08, 04:22 PM
Originally Posted by Twitch Year? Its still Oct. 20, right? | Still is, I started this thread before I decided to it again this year |
06-11-08, 04:54 PM
Originally Posted by Lindsay Cadillac Parts Still is, I started this thread before I decided to it again this year | Oh,,,duuuh  |
06-11-08, 10:23 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 CTS V Black | | Join Date: Jun 2004 Location: Cedar Rapids, Iowa | | | Re: Hi temp Plug Wires I am using Pulstar Capacitor Spark Plugs. My CTS V and 07 Vette run very nicely with the Pulstar Plug installation. However, they induce an EMF effect that causes an intermittent "Check Electrical System" because of the Electro-Magnetic Field affecting the Alternator signal to the ECM.
Are there Plug Wires that can effectively shield this EMF effect from the Alternator wiring. http://www.pulstarplug.com/ |
06-11-08, 10:31 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: Hi temp Plug Wires Quote:
Originally Posted by Stephen P. I am using Pulstar Capacitor Spark Plugs. My CTS V and 07 Vette run very nicely with the Pulstar Plug installation. However, they induce an EMF effect that causes an intermittent "Check Electrical System" because of the Electro-Magnetic Field affecting the Alternator signal to the ECM.
Are there Plug Wires that can effectively shield this EMF effect from the Alternator wiring. http://www.pulstarplug.com/ | Flux capacitor wires? What happens when you hit 88mph?
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
