Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Braking in the rain and x-drilled rotors
Old 04-15-08, 05:06 PM
Seattle CTS-V's Avatar
Cadillac(s): Temporarily None
View Seattle CTS-V's Photo Album
Casino Cash: $4749
Would cross-drilled front rotors help with the brief "hydroplaning" I get with my Hawk HPS pads? They don't quite have the initial cold grip that the OEM pads used to have. They're awesome on the track and have very little dust but when the rotors are coated in water they don't have that bite. I'm imagining the water getting pushed through the drilled holes and better initial grip. They also look cool.
  #2 (permalink)
Old 04-15-08, 05:09 PM
The Tony Show's Avatar
How YOU doin?
Cadillac(s): 2007 SRX (Previously 04 CTS-V)
View The Tony Show's Photo Album
Casino Cash: $18680
Re: Braking in the rain and x-drilled rotors
"Look Cool" is the only real reason to get them for street driving. Since there's less swept area, the initial brake response is less. The only real advantage to them is increased heat dissipation under extreme use, but they're not going to do anything on the street.
  #3 (permalink)
Old 04-15-08, 05:13 PM
Cadillac(s): 04 CTS-V
View kgoch's Photo Album
Casino Cash: $3245
Does not make a difference. I have drilled rotors and hawk pads and when they are wet, the initial brake application is eye opening. I learned to brake hard the first time and that corrects the problem.
  #4 (permalink)
Old 04-15-08, 05:21 PM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138415
I've noticed that I still get it when comming out of the car wash in the morning. I have HP+, and cross drilled rotors.
You need to chuck those HPS's for the track, they are not as good as the OEM Ferodos. With falken RT615's and HPS's all around at the track, my tires were way outperforming my brakes. When I swapped mid weekend one time to HP+'s, my brakes started out performing my tires. I'd much rather have brakes > tires, than the other way around (tires slowly fade over the session, vs the brakes which always have a habit of going P00F just more or less all at once.)
HP+'s are a bit squeeky, and dust almost as much as the OEM's, but perform better.
I'm trying CarboTech XP10's (with Hawk HPS in the rear) next track day. If I like them, I am considering going to AX6's for the street. That might be an option for you if you don't want to swap pads at the track. I *hear* they are pretty good on dust, but haven't hear it from a V guy, so who knows. My understanding is that the Bobcat's are pretty similar to HPS's.
http://www.ctbrakes.com/faqs.html#4
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #5 (permalink)
Old 04-15-08, 05:47 PM
nikon's Avatar
Cadillac(s): 05' CTS-V
View nikon's Photo Album
Casino Cash: $22398
Dunno about the V but with x-drilled rotors on my camaro my braking went down the drain initially in the wet
  #6 (permalink)
Old 04-16-08, 03:34 AM
Cadillac Owners Enthusiast
View AAIIIC's Photo Album
Casino Cash: $10355
Originally Posted by The Tony Show View Post
The only real advantage to them is increased heat dissipation under extreme use...
... which, for most of us, is offset by cross-drilled rotors' MUCH greater propensity to crack under extreme use. Even if they don't crack, the rotors themselves won't last as long, and they'll wear your pads out faster, too. They're just not worth it IMO.
There's an SAE paper out there in which they tested a couple different vehicles (Vette and 911, as I recall) with cross-drilled and plain rotors. Summarizing very briefly, the cross-drilled rotors were cooler during hard use, but lasted about 1/2 as long (as did the pads). They did no better in wet conditions than non-drilled rotors.
'05 Stealth Grey CTS-V, GM Accessory wheels w/Falken FK452s, Hyperblack Rota Torques w/Bridgestone RE-01Rs, KW Variant3s, Magnaflow exhaust, UUC shifter (not worth the trouble), Specter cradle bushings (somewhat useful), BMR pinion brace, and more to come I'm sure...
  #7 (permalink)
Old 04-16-08, 03:58 AM
GMBOUND's Avatar
Cadillac(s): 2006 INFRARED CTS-V - BADCADY
View GMBOUND's Photo Album
Casino Cash: $4824
I just thank you guys for this post, a week after I ordered my cross-drilled rotors!
  #8 (permalink)
Old 04-16-08, 04:40 AM
Naf Naf is offline
Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT
View Naf's Photo Album
Casino Cash: $12256
Trust me, at least you can still off load your parts if you arent happy...If i get the wrong part returns would cost me more than ordering the right ones...
Not to mention i am always treckin in new territory...The dealer here just dont know much about much. And the garages here are very primitive. I have to be present most of the time to do quality checks...They stripped the bolt that holds the dipstick...WHO does that
  #9 (permalink)
Old 04-16-08, 06:10 PM
Casino Cash: $4749
Thanks for all the replies guys. I guess I'll just stick with the stock rotors and HPS pads for now and try to remember to press a little more firmly initially.
Tags: , , ,
braking, rain, rotors, xdrilled
Censor is OFF
