Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Changing clutch fluid
Old 04-09-08, 05:50 PM
Cadillac(s): 04 V Raven
View Civardi's Photo Album
Casino Cash: $5420
Since I am doing the diff this weekend and just got a new radiator I figured why not do the whole car. I saved this link from before I had my V.
http://www.rangeracceleration.com/Clutch_Care.html
Has anyone tried this? Fluid in mine is really dark. So if I wanted to switch from the DOT3 to the Royal Purple Synchromax does it need to be flushed or will this method work?
  #2 (permalink)
Old 04-09-08, 10:53 PM
benelliwang's Avatar
Cadillac(s): CTSV, C5TT, STi, 70Camaro
View benelliwang's Photo Album
Casino Cash: $6567
Re: Changing clutch fluid
I've bled my C5 clutch 3 times over the years (same location on c5 & c6), and it is not as hard as that links Alternative 3 says.
1. Jack car up.
2. Drink beer.
3. Call wife.
4. Crawl under car with one wrench.
5. Open the valve with wrench.
6. Tell wife to push clutch like she wants to kick me.
7. Close valve.
8. Repeat 5 to 6 & refill reservoir until the fluid is done.
9. Drink more beer.
10. Wipe clean.
11. Lower car.
12. Buy wife jewelry for help me with car.
  #3 (permalink)
Old 04-10-08, 03:36 AM
PISNUOFF's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2007 CTS-V
View PISNUOFF's Photo Album
Casino Cash: $9210
I tried that 'just keep refilling and pumping' method and it did not work for me. It really only takes 5 minutes to fully bleed the system. Ben has it right, but I used a rubber hose and didn't have to wipe anything clean. Also, no wife and I don't buy the G/F anything for helping. She just thinks it's nice to spend time with me.
  #4 (permalink)
Old 04-10-08, 07:37 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
It will have to be bled, it sucks... but no real way around it.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #5 (permalink)
Old 04-10-08, 08:45 AM
Cadillac(s): CTS-V
View Bueller's Photo Album
Casino Cash: $5664
If you use the remove some, add some, remove, add and so on...why won't this work? I can understand if you remove too much and bleed in some air. Please help me understand. Thanks
  #6 (permalink)
Old 04-10-08, 09:36 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Adding fluid on top and pumping the clutch will just cause the fluid to move back and forth, it will never put the fluid on top to the bottom.
Imagine a long pipe with fluid in it, putting some on one end will hardly replace the fluid at the other.
The bleeder screw is at the bottom end, the only way to effectively remove the fluid is to open the bleeder and force the fluid through from the top by flushing it out.
There are no magical forces that rotate the fluid through a single straight pipe, it just sits there until the molecules on top press them down.
When the force is released they just move back up a little.
  #7 (permalink)
Old 04-10-08, 12:22 PM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138390
WOW is Bill talking about fluid dynamics and molecules
All you guys need to do what I do....Have Bill flush and change the clutch fluid the next time you are at Lindsay Cadillac. So much easier to stroke a check. Bleeding the clutch is a PITA.
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #8 (permalink)
Old 04-10-08, 02:27 PM
Casino Cash: $5420
-Chris
I am on the west coast or I would be there. How much of a check will I be writing to have this done?
  #9 (permalink)
Old 04-10-08, 02:49 PM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7808
ewill's write up:
http://www.cadillacfaq.com/faq/answers/clutchbleed.html
just one question: where's the bleeder valve, any pics?
  #10 (permalink)
Old 04-10-08, 03:00 PM
Cadillac(s): Cadillac
View lilred's Photo Album
Casino Cash: $4705
Yes inquiring minds want to know. I need to do this as well. Already have Amsoil DOT 4 brake fluid on order.
  #11 (permalink)
Old 04-10-08, 03:18 PM
Casino Cash: $6567
If you are truely lazy, install one of these and you can bleed the clutch from the engine bay:
http://www.thelapd.com/index.php?mai...roducts_id=194
This is great for track day people who likes to bleed all the fluids before the event.
  #12 (permalink)
Old 04-10-08, 03:46 PM
Casino Cash: $7808
I'm cheap and am not going to change fluid every other day.... where's the bleeder?
  #13 (permalink)
Old 04-10-08, 03:48 PM
trukk's Avatar
Installing the remote bleeder is an absolute no brainer when you do a clutch swap, untill then, that's a lot of work to pull so much appart just to install it.
-Chris
  #14 (permalink)
Old 04-10-08, 04:59 PM
Casino Cash: $6567
-Chris
Yeap no brainer.
It can be easily done in corvettes though, we just pop the mid pipes and bottom cover and it is there. I can get there in 30 minutes including beer drinking. I guess it not the same with a CTS-v?
  #15 (permalink)
Old 04-10-08, 05:30 PM
Cadillac(s): 04 Cadillac CTS-V
View mbiker97_old's Photo Album
Casino Cash: $1735
The bleeder is on the driver side of the trans almost touching the body tunnel at the top. It's in a awful spot. Did the same steps as listed above, but made my friend pump the clutch for me. I may have to install one of those remote bleeders since the system seems to get contaminated really quickly.
Tags: , , , ,
changing, clutch, fluid
Censor is OFF
