Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Changing clutch fluid
  #16 (permalink)
Old 04-10-08, 05:43 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
Re: Changing clutch fluid
I have been using the GM stuff and it gets pretty gummy, can be real bad for drivers like Trukk.
It also seems to disappear... not sure what that is about. I haven't seen one leaking yet.
If the car is in for other service I'll usually do it for about 50 bucks or so. It isn't a big deal once you figure out how to work it.
Some places might charge more depending on how many they have done and how much they don't like V's.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #17 (permalink)
Old 04-10-08, 06:14 PM
benelliwang's Avatar
Cadillac(s): CTSV, C5TT, STi, 70Camaro
View benelliwang's Photo Album
Casino Cash: $6567
Originally Posted by mbiker97 View Post
The bleeder is on the driver side of the trans almost touching the body tunnel at the top. It's in a awful spot. Did the same steps as listed above, but made my friend pump the clutch for me. I may have to install one of those remote bleeders since the system seems to get contaminated really quickly.
Sounds like it is no harder to reach then a C5, good deal.
  #18 (permalink)
Old 04-10-08, 06:28 PM
Cadillac(s): 04 V Raven
View Civardi's Photo Album
Casino Cash: $5420
HMmm so find a shop, get a firm price and make them deal with it. I like that idea. I got a price of $170 to change the oil, trans fluid, and diff. Thats with me having the RP and AMSOIL.
  #19 (permalink)
Old 04-10-08, 08:57 PM
Cadillac(s): 2005 CTS-V
View Jayrcr3's Photo Album
Casino Cash: $7235
I did a hard 2-3 shift the other day and thought I was imagining things. My clutch pedal stuck to the floor for about a 1/4 second before it came up. Evidently I wasn't imagining it. Now I know how to fix it. Thanks guys.
  #20 (permalink)
Old 04-11-08, 09:57 AM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138390
FYI, there is a TSB for that issue. Check the FAQ.
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #21 (permalink)
Old 04-11-08, 10:20 AM
View atdeneve's Photo Album
Casino Cash: $9348
Getting into 1st and R was not a problem about 1,000 miles ago (getting into second was actually harder than getting into 1st). Now, it's a real bitch. Lo and behold, my clutch fluid was below the min, at about the F A G (no, I'm not prejudice). Didn't make sense, being that all the fluids were supposed to have been full about 1,000 miles ago. The clutch fluid reservoir is pathetically meek, but still, couldn't believe that the fluid would have gone down that fast. Anyways, suctioned out the old black fluid and wiped away the congealed gelatinous stuff. Topped it off (I use RBF 600) and it still isn't good as it was. Clutch engagement is more abrupt. Less control. Not as linear. All this leads to more clunking. Next step is the flush.
The rate that the clutch fluid in our Vs gets so dirty/black and disappears is astounding. It can only worsen the shifting problems. Getting into gear will only be that much more difficult. Synchros will wear out. Shifting gets worse and worse. It's like you have to do a full flush at least once an oil change. Such a high maintenance bitch, she is. Eh. Yagottado, whatchagottado.
  #22 (permalink)
Old 04-13-08, 04:10 PM
Cadillac(s): 06 CTS-V
View C66 Racing's Photo Album
Casino Cash: $1235
Using my Z06 for track day use required frequent clutch bleeds. I got tired of having to drop the center section of the exhaust, remove the tunnel plate (which has something like 36 bolts holding it in place) and finally bought and installed an LAPD clutch bleeder extender. What a time saver. For those tracking the car and needing frequent clutch bleeds, I would install an extender line at the first convenient opportunity.
As a caution, on the Corvette, routing this extender line up to by the clutch reservoir requires routing it very near the fuel line. On a buddy of mine's Corvette, the aeroquip line of the clutch bleeder extender wore through the fuel line and caused a fire. I had installed my line in rubber sheath so I didn't have the same problem - and I recommend anyone installing this line consider doing the same.
C66 Racing LLC - AMSOIL Direct Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program Members buy at Wholesale - a savings of about 25%
C66 Racing
2004 SCCA MidWest Division T1 Champion
Tags: , , , ,
changing, clutch, fluid
Censor is OFF
