Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: AMSOIL or RP in diff
  #46 (permalink)
Old 07-16-08, 09:22 PM
Rich H's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2004 CTSV
View Rich H's Photo Album
Casino Cash: $4247
Re: AMSOIL or RP in diff
Originally Posted by CTSV_Rob View Post
I was a little concerned with the warranty so I taiked with the Service Manager and he told me the AMSOil with the GM friction modifier was a good combination. When I asked him if they would void the warranty with the AMSOil instead of the regular fluid and he told "not at this dealership". He told me that it would be hard to tell the GM stuff from the AMSOil when it's used anyways.
I'm liking this dealership so far.
What one dealer says isn't necessarily what all would say but AMSOil is probably the best of the lot if you believe their "independent" overall quality test data. GM comes in a close second. I would be a little hesitant using anything else unless you were getting monetary kickbacks.
Regarding the use of tracers, including smell, to tell if you were using different lube, the most telling story will be if you have fluid that is visibly degraded in color or flow characteristics due to extreme operating conditions. In that case they might send the fluid in for chemical analysis (if there's any left along with the exploded rear-end) to support or refute the claim.
  #47 (permalink)
Old 07-16-08, 09:47 PM
CTSV_Rob's Avatar
<10 poasts, CF newbie
Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior
View CTSV_Rob's Photo Album
Casino Cash: $1121660
I am in no way affliated with AMSOil and I understand what your saying. I am in no way saying that one should go out and use this fluid, I am just posting what I do use.
Everyone needs to make their own descision and if your even moderately worried about being denied a claim then I would recommend sticking with the recommended fluid.
With all of that said I would recommend changing the fluid more often then recommended by GM for 2 reasons. When I changed the fluid in mine there was a lot of the clutch material on the plug. If this gets into the gears it will probably accelerate wear. Second is it's not that expensive and it's easy to do with the right tools.
I think if GM wants to find a reason to deny a claim they will and if not the fluid I'm sure they will find something else.
Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth.
  #48 (permalink)
Old 07-16-08, 09:54 PM
Cadillac(s): 04 V Raven
View Civardi's Photo Album
Casino Cash: $5420
I am going with every other oil change.
  #49 (permalink)
Old 07-16-08, 10:00 PM
CTSV_Rob's Avatar
I do about 5K which is close to every other.
  #50 (permalink)
Old 07-16-08, 10:08 PM
Rich H's Avatar
Casino Cash: $4247
I changed my new diff fluid at ~6K and found very little contamination on the drain plug. Unless I track the car in the future, I doubt I will change it again for quite some time. The whole reason for using a quality lube is to have confidence it will stand up to moderate demands over time. If I found some evidence of component wear related contamination I would change it sooner.
  #51 (permalink)
Old 07-16-08, 10:16 PM
CTSV_Rob's Avatar
I saw the most wear on the first change and of course it was the GM recommended fluid. I figured this should be expected because the clutch packs are breaking in and a little extra on the first change was normal. If you had very little wear it sounds like you got one of the better diff's.
  #52 (permalink)
Old 07-16-08, 11:09 PM
Cadillac(s): 2004 CTS-V
View vegasVowner's Photo Album
Casino Cash: $5490
I had a new diff put in 10,000 mi ago and cahnged to RP after 1500 mi. There was no audible difference, still some whine. I just changed to the Amsoil severe gear a couple weeks ago and no noise so far, just crappy Falken 452 road noise.
Tags: , , ,
amsoil, diff
Censor is OFF
