Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: AMSOIL or RP in diff
  #31 (permalink)
Old 06-06-08, 09:58 PM
Cadillac(s): '05 Platinum V
View SS from the "Wood"'s Photo Album
Casino Cash: $2320
Re: AMSOIL or RP in diff
Originally Posted by Loading... View Post
Which dealer- Carter? I need some work done too, are they friendly to a modded car?
BTW- your car looks really low, what did you use?
Thanks- sorry I stole the jump the other day, bad habit sometimes.
Hey man what up???? Yeah you go the jump alright... then I felt like a chump trying to catch up...
Yeah, I went to Ron Cartier (that's kart-ee-yay) to have the stuff done... all I can say is that be sure they know ALL of the items you need done ahead of time... oh, and Brian, service writer, said they're backed up like 2 weeks! They may try to tell you that GM won't warranty certain items if that's what you're taking it in for.
BTW - the RP diff fluid has given me a little more confidence in the ass end of my V... no whine whatsoever
  #32 (permalink)
Old 07-15-08, 11:32 AM
Cadillac(s): 2004 Cadillac CTS-V
View V-Spot's Photo Album
Casino Cash: $4585
Hey Guys,
Just picked up a 2004 V and am very happy with it!!! I have been pouring over this forum for the last little bit and tons of great info.
So my question is....I'm getting ready to change out the diff fluid and have read that this stuff is pretty good..
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90.
How many quarts do I require?
Thanks in advance
Jeff
  #33 (permalink)
Old 07-15-08, 11:47 AM
Cadillac(s): 04 V Raven
View Civardi's Photo Album
Casino Cash: $5420
Pick up 4 quarts. There will be some left over.
  #34 (permalink)
Old 07-15-08, 12:14 PM
Cadillac Owners Enthusiast
Cadillac(s): CTS-V
View Bueller's Photo Album
Casino Cash: $5664
I am in Florida. What Amsoil would I use in the diff and trans? 4 quarts for the diff and how much for the trans?
  #35 (permalink)
Old 07-15-08, 01:10 PM
ahahnu's Avatar
It's a V thing.
Cadillac(s): 05 LS6 Stealth Grey
View ahahnu's Photo Album
Casino Cash: $7697
4 quarts? I thought it was 1.5?
Did everyone use ramps or jacks and stands? I was planning on accomplishing this feat tomorrow.
  #36 (permalink)
Old 07-15-08, 01:14 PM
Casino Cash: $5420
2 quarts is right. I was thinking of the trans.
  #37 (permalink)
Old 07-15-08, 01:17 PM
ctsv154's Avatar
Cadillac(s): 04 CTS-V with a little hp persuasion device
View ctsv154's Photo Album
Casino Cash: $15572
Transmission (4.0 qt)
Diff (2.0qt) you wont use all of it. Just fill untill it runs out the fill port
  #38 (permalink)
Old 07-15-08, 01:20 PM
Cadillac(s): Cadillac
View lilred's Photo Album
Casino Cash: $4705
It's more like 1.25 quarts. I did mine on ramps and used Amsoil. I would say use anything but change it often. I had some nasty stuff on that plug after only 750 miles on a new rear diff.
  #39 (permalink)
Old 07-15-08, 02:07 PM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7808
Use ramps....easiest way to go. I went GM Fluid in the new diff and it was whining...switched to Redline 75w90 and now it's pretty quiet!! I'm loving that stuff......they make good trans fluid too.
Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff, Clear Fogs/Sidemarkers, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq
  #40 (permalink)
Old 07-15-08, 03:56 PM
Cadillac(s): 07 cts v
View peter simov's Photo Album
Casino Cash: $4857
what amsoil do u use in the trany
  #41 (permalink)
Old 07-15-08, 10:41 PM
CTSV_Rob's Avatar
<10 poasts, CF newbie
Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior
View CTSV_Rob's Photo Album
Casino Cash: $1121660
AMSOil ATF for the trans. There is a gear oil atf mix that is supposed to work best. if your interested, do a search.
I used the Severe Gear in the Diff with the GM friction modifier. She is quiet after 17K so I'm happy.
Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth.
  #42 (permalink)
Old 07-16-08, 02:55 PM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138390
Originally Posted by trukk View Post
FYI, I would NOT recommend putting in Mobil 1. I added it,m and it has caused my plutch packs to grind on low speed turns. This is with the GM friction modifier added for good measure.
-Chris
FYI,
I switched back to OEM fluid, and no more binding on tight turns. Damned, mobil1.
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #43 (permalink)
Old 07-16-08, 03:04 PM
Rich H's Avatar
Cadillac(s): 2004 CTSV
View Rich H's Photo Album
Casino Cash: $4247
I replaced the stock OEM fluid with the same and haven't had any problems at all. The only disadvantage in using the stock GM fluid is the price. The advantage is that GM might deny a claim if the replacement fluid in the differential does not have the distinctive "grape" smell when they do their warranty investigation - so why take a chance?
  #44 (permalink)
Old 07-16-08, 03:16 PM
Casino Cash: $7808
Hahahha that "distinctive" Grape smell doesn't smell like Grapes! You can be dumb like me and take a whiff.....I'm sure the engineers are over that one
  #45 (permalink)
Old 07-16-08, 05:32 PM
CTSV_Rob's Avatar
I was a little concerned with the warranty so I taiked with the Service Manager and he told me the AMSOil with the GM friction modifier was a good combination. When I asked him if they would void the warranty with the AMSOil instead of the regular fluid and he told "not at this dealership". He told me that it would be hard to tell the GM stuff from the AMSOil when it's used anyways.
I'm liking this dealership so far.
Tags: , , ,
amsoil, diff
Censor is OFF
