Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Not Just Radio Knobs Flaking, Console Behind Also
Old 04-06-08, 10:17 AM
majoraward's Avatar
Did you drive? No, I took the V.
Cadillac(s): CTS-V 2005 Platinum
View majoraward's Photo Album
Casino Cash: $1305
Dang, yesterday I saw a white flake on my right hand radio knob so I reached over to clean it off thinking it was lint or something when I discovered I had actually taken off more of the finish. I then examined it closely and the finish behind the knob on the console is starting to come off also.
I read on this forum just now about the radio knobs flaking, I’ll dry a permanent marker, but what about the problem behind the knobs??? Has anyone had this problem and what did you do? Did anyone have the console, maybe not the correct term, the enclosure for the NAV system and radio area, replaced because of this? If so, how much did it cost? Thanks.
  #2 (permalink)
Old 04-06-08, 10:39 AM
rlj5's Avatar
Cadillac Owners Enthusiast
Cadillac(s): '05 ProCharged cts-V -Silver on Black
View rlj5's Photo Album
Casino Cash: $16776
Re: Not Just Radio Knobs Flaking, Console Behind Also
If your still in warranty they should cover that.
I had the vent panel above the radio replaced under warranty for the same reason. "that was when I still had a warranty"
F1-A ProCharged LS2/402 Forged w/AFR 225 heads & Fast 92mm intake |Meth | 1-7/8" kooks w/ Corsa |Stage V Trans by RPM w/ 9" Ford IRS |UUC Shifter |Msd shift lite |custom gauge pod w/dual interceptor scan gauges w/wide band |launch control |Line lock |Hre C-20 wheels |GY gsd3's 255/40/18 front & BFG T/A 295/35/18 DR rear |Kw,var-3 Coilovers
Built & Tuned by EPP------- 864 rwhp / 812 rwtq
9" IRS built & installed by------- Madman Racing
http://s478.photobucket.com/albums/rr148/indy-v/
  #3 (permalink)
Old 04-06-08, 11:28 AM
majoraward's Avatar
Casino Cash: $1305
The V has 37,000 miles so it is under warranty, I'll check it out. Thanks for info.
  #4 (permalink)
Old 04-06-08, 11:31 AM
Cadillac(s): Maggied 2004 CTS V Black Raven cause its faster
View MauiV's Photo Album
Casino Cash: $12065
Mines on its 3rd radio/nav unit for flaking.
  #5 (permalink)
Old 04-06-08, 01:07 PM
Rey Rey is offline
View Rey's Photo Album
Casino Cash: $5935
Check out FAQ. I coated my buttons with a spray clear satin epoxy as per the FAQ. Now, 25K miles later there is no flaking whatsoever. Nevertheless, GM will continue to replace entire radios if button paint flakes. You do not actually receive a brand-new virgin radio, but rather the current edition that has been recycled with new buttons.
My sense is that these buttons are painted with a spray laquer, which is not the best long-lasting finish when frequently touched by human hands.
  #6 (permalink)
Old 04-07-08, 07:20 AM
majoraward's Avatar
Casino Cash: $1305
That seems drastic to replace the whole unit, but Cadillacish. I did use a combination of brown and black permanent marker and it covers well, temp fix at least.
Tags: , , , , ,
console, flaking, knobs, radio
Censor is OFF
