Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: 808 rwhp and 23 mpg "WoW"
Old 04-04-08, 05:25 AM
rlj5's Avatar
Cadillac Owners Enthusiast
Cadillac(s): '05 ProCharged cts-V -Silver on Black
View rlj5's Photo Album
Casino Cash: $16776
Had to replace my Cobra 8.8" center section dif cause there was a hairline crack leaking fluid. The new unit was a 355 gear compared to the stock 373.
Had to make a trip up to EPP for some follow up stuff yesteday. Set my cruise on 78 mph and got an astounding 23 mpg on the trip, And I think that is amazing for a streetable car to have 800 + rwhp and still get 23 mpg.
Now my overall average isn't that good , been running from 11.5 to 14.5, haven't drove it enough yet to get a for sure averaged. Been checking miles driven to fuel used at the pump. My dic is way outa wack now ,fuel used is only about 1/2 of what is actually used and the mpg average says about 35 mpg. As far as I know there isn't any way to adjust this. I assume the main reason is it has no maf sensor it is speed density tuned. Anyone know it this can be adjusted in any way ?
F1-A ProCharged LS2/402 Forged w/AFR 225 heads & Fast 92mm intake |Meth | 1-7/8" kooks w/ Corsa |Stage V Trans by RPM w/ 9" Ford IRS |UUC Shifter |Msd shift lite |custom gauge pod w/dual interceptor scan gauges w/wide band |launch control |Line lock |Hre C-20 wheels |GY gsd3's 255/40/18 front & BFG T/A 295/35/18 DR rear |Kw,var-3 Coilovers
Built & Tuned by EPP------- 864 rwhp / 812 rwtq
9" IRS built & installed by------- Madman Racing
http://s478.photobucket.com/albums/rr148/indy-v/
  #2 (permalink)
Old 04-04-08, 09:16 AM
theloanman219's Avatar
Cadillac(s): 05 Stealth Gray V
View theloanman219's Photo Album
Casino Cash: $2385
Re: 808 rwhp and 23 mpg "WoW"
Damn Bob! I have a stock V and im at 16.5
  #3 (permalink)
Old 04-04-08, 09:22 AM
JD03Cobra's Avatar
Cadillac(s): 2006 Platinum CTS V
View JD03Cobra's Photo Album
Casino Cash: $12140
Impressive! Any photos of that monster?
  #4 (permalink)
Old 04-04-08, 09:37 AM
StealthV's Avatar
Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting...
View StealthV's Photo Album
Casino Cash: $3517
Yes, the fuel burn in the DIC is adjustable with tuning software. {B3501} in EFILive speak.
  #5 (permalink)
Old 04-04-08, 12:52 PM
stkshkr's Avatar
Cadillac(s): 05 Maggied V Black/Black
View stkshkr's Photo Album
Casino Cash: $10870
Wow thats impressive, I'm getting 18 on the hwy. I take it your going to have EPP strengthen the bracing on the rear? I changed pulleys and went to 7.5 psi from 5.5 psi, added a 2 step, ProComp tach and made a pod like yours for the AFR and boost gauge. Need a tune now with meth and the additional boost.
  #6 (permalink)
Old 04-04-08, 01:06 PM
rlj5's Avatar
Casino Cash: $16776
yeah, gonna do some reinforcing to hopefully lasts for awhile. Looks like I will probably end up with a Madman rear on this thing,
Sounds like your about to get your beast completed if there is such a thing a completed.
Good luck Gene
  #7 (permalink)
Old 04-05-08, 07:24 PM
10secTy's Avatar
Cadillac(s): none
View 10secTy's Photo Album
Casino Cash: $5382
Do you have any pics of your rear diff set up? Who did the install for you?
Thanks
Nolan
  #8 (permalink)
Old 04-05-08, 07:56 PM
rlj5's Avatar
Casino Cash: $16776
Thanks
Nolan
in the process of switching to Madmans 9" kit , Will be doing it as soon as he gets everything built "about a month" .
The cobra setup continues to give me problems.
  #9 (permalink)
Old 04-06-08, 01:43 AM
Seattle CTS-V's Avatar
Cadillac(s): Temporarily None
View Seattle CTS-V's Photo Album
Casino Cash: $4749
Could you PM me pics of your gauge pod setup? I have a boost gauge I want to install and would love some ideas.
  #10 (permalink)
Old 04-06-08, 03:01 AM
rlj5's Avatar
Casino Cash: $16776
Do a search for "dual gauge pod" and you'll find pictures I posted on 12/10/07 , Had several pics of my current gauge pod
  #11 (permalink)
Old 04-06-08, 03:49 AM
10secTy's Avatar
Cadillac(s): none
Casino Cash: $5382
I would still like to see pics of the cobra set up. In your set up with 800+rwhp I could see that a 9" will be needed but with a 450-500rwhp set up the cobra might be a cheaper alternative? maybe? please any pics would be sweet if you have the time.
Thanks
Nolan
  #12 (permalink)
Old 04-06-08, 10:58 AM
rlj5's Avatar
Casino Cash: $16776
Thanks
Nolan
The Cobra setup wasn't any less expensive to do than the Madmans fix is now (he got less expensive than it was to start) or the Kars fix which is no longer available. The only reason I did the cobra was the others were not yet available & in the end it costs considerably more than the Madmans fix. Will give you some pics if you want, but there is a lot of custom fab work involved for the install of the cobra center section & then of course custom drive shaft & axles. with all that has to be replaced to change out the diff I just can't see how anyone is going to do it for much less than madmans fix.
For all the V owners out there that are looking for a fix for a couple thousand dollars, I just don't see that ever happening, there is just to many things that have to be addressed other than just the center section being replaced.
but like I say if you want some pics let me know & when I get it back from epp next week I'll take some
Note that on the cobra there is a vibration that has never been resolved.
  #13 (permalink)
Old 04-06-08, 03:04 PM
10secTy's Avatar
Cadillac(s): none
Casino Cash: $5382
Ok thanks thats great info. What is the new pricing on the madmen diff?
Thanks
Nolan
  #14 (permalink)
Old 04-06-08, 03:48 PM
rlj5's Avatar
Casino Cash: $16776
Thanks
Nolan
$7,500.00
Tags: , , ,
808, mpg, rwhp, wow
Censor is OFF
