Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Floor Jack Question
Old 04-03-08, 12:28 PM
JD03Cobra's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2006 Platinum CTS V
View JD03Cobra's Photo Album
Casino Cash: $12140
Floor Jack Question
Does a standard size floor jack fit underneath the car or do you need a low profile jack? I typically lease and do the quick lube oil changes but now that I own I want to do this myself.
Thanks for helpin a noob.
  #2 (permalink)
Old 04-03-08, 01:07 PM
Claimslngr's Avatar
Cadillac(s): 06' cts-v infrared
View Claimslngr's Photo Album
Casino Cash: $13020
Re: Floor Jack Question
Unless I am missing something there is app. 8" of clearance from ground to jack points. The average rolling floor jack needs app 5.5" so it should work.
(Been looking for a new jack also!)
  #3 (permalink)
Old 04-03-08, 01:30 PM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138390
I got an aluminum floor jack at Costco, and it fits fine. Cheap too, less than $100.
http://www.costco.com/Browse/Product...topnav=&browse=
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #4 (permalink)
Old 04-03-08, 01:41 PM
Feffman's Avatar
Cadillac(s): CTS-V
View Feffman's Photo Album
Casino Cash: $8696
I purchased a similar (little more $$$) aluminum jack at Sears and love it. Make sure you buy the jacking point pucks that install on the underside of the V so you don't crinkle the chassis.
Feff
www.MVPTrackTime.com
MVP Track Time
  #5 (permalink)
Old 04-03-08, 01:43 PM
StealthV's Avatar
Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting...
View StealthV's Photo Album
Casino Cash: $3517
My normal sized jack fits fine. With the jacking pucks, it takes a little wiggle to get the jack under the car.
  #6 (permalink)
Old 04-03-08, 02:04 PM
Cadillac(s): Cadillac CTS-V
View Dirk Diggler's Photo Album
Casino Cash: $750
Does the dealer sell the pucks?
  #7 (permalink)
Old 04-03-08, 02:18 PM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7808
Why buy pucks? just use a piece of 2x4 or 1x4 and jack it up by the actual frame. Or best yet, just get some of those plastic $38 Blitz ramps (autozone has the 8000 lb ones which are more than enough) and you won't have to worry about jacking it up. I just bought some last week. I needed the whole car up in the air, so pulled up on the ramps backwards, and I jacked up the front on the actual frame (about 4 inches in) but the jack fit just fine
  #8 (permalink)
Old 04-03-08, 02:20 PM
JD03Cobra's Avatar
Casino Cash: $12140
-Chris
Awesome thanks! I'm heading there tonight for food..I'll pick this up too!
  #9 (permalink)
Old 04-03-08, 02:34 PM
Cadillac(s): 06 CTS-V, 99 Vette, 02 Escalade EXT, 04 MB E320
View jr_vette's Photo Album
Casino Cash: $2455
I believe so, but you can find much cheaper pads in the aftermarket. The ones I have for my Vette work fine on my V. I'm still new to the forum, so I don't know if it's ok to post the vendor I bought them from (not a site supporting vendor from what I can tell). They were $50 for a set of 4.
As for a jack not fitting, I drive my C5 up on some 2x6's prior to jacking it.
  #10 (permalink)
Old 04-03-08, 02:43 PM
MSOsr's Avatar
Cadillac(s): 2007 SRX and 2005 CTS-V (both black)
View MSOsr's Photo Album
Casino Cash: $14260
Where did you get the pucks?
It's OK...........
Mike
  #11 (permalink)
Old 04-03-08, 02:55 PM
BBD BBD is offline
Cadillac(s): CTS-V
View BBD's Photo Album
Casino Cash: $2145
I have a couple floor jacks, do not have clearance issues, but I am running stock suspension so my car is not lowered at all, but works great. I do not have any pucks would love to know where you guys get them.
As far as ramps go, I have to drive my car onto a 1-1/2" block in order to clear the nose, then I can drive right up the ramps. I have to do the same with the rear, the ramps hit the mufflers if I do not use the blocks first.
  #12 (permalink)
Old 04-03-08, 03:06 PM
JD03Cobra's Avatar
Casino Cash: $12140
It's OK...........
Mike
I found this somewhere on the site...
http://www.protechproducts.net/jackpads.htm
  #13 (permalink)
Old 04-03-08, 03:08 PM
Casino Cash: $7808
I have B&B exhaust, so I never had a problem backing up...I never had a prob going up them either with stock springs/shocks. If you really want some pucks, go to a sporting good store and buy their cheap hockey pucks....gotta be less expensive than that!
  #14 (permalink)
Old 04-03-08, 03:16 PM
OldRoadDawg's Avatar
"gotta get a Wait4Me tune"
Cadillac(s): 2009 CTS-V
View OldRoadDawg's Photo Album
Casino Cash: $6071
It's OK...........
Mike
There are several Corvette accessory suppliers that will sell you 2 for $50 or more. Personally I think it's a rip-off, cuz I bought some.
Oh yeah.... remember to remove them when done. If you don't . . you'll hear them bounce once or twice against the undercarriage as you're cruising down the road before they go rolling into a ditch somewhere.
I like this idea. (plagarized from a corvette forum)
"Made mine from 4 old hockey pucks. Drilled a hole in the center of each puck and threaded a carriage bolt into the hole. Ground down the top edges of the carriage bolt so that it fit into the slot in the rail. Rotated the puck 90 degrees to hold them in place. Works like a charm and cost less than $5 total."
  #15 (permalink)
Old 04-03-08, 09:50 PM
2004ctsv's Avatar
Cadillac(s): 2004 CTSV
View 2004ctsv's Photo Album
Casino Cash: $6319
I used two Craftsman 2 ton jacks and hockey pucks ($2 each). They fit in the cup in the jack and do a great job of protecting the underside.
I used to use 1X3 lumber but the pucks store easier in the jack cases.
Tags: , ,
floor, jack, question
Censor is OFF
