Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Extended my Warranty at 139,000 Kms
Old 03-25-08, 05:06 PM
CadiKing2006's Avatar
View CadiKing2006's Photo Album
Casino Cash: $1225
Arrow Extended my Warranty at 139,000 Kms
So guys im officially at 139,000 kms and my GMPP plus is over at 140,000. I went to the dealership today and took the bullet. I need warranty on this car.
So I bought 2 years 40,000 kms Max I can get, powertrain. It costed me $2014 CDN. He quoted me 2600. I negotiated and saved $600
Anyhow rear diffs and alot more stuff is covered for 2 yrs now
Here is a list
Engine Gasoline/Diesel
Cylinder block, heads, all internally lubricated parts; manifolds; timing gears, timing chain/belt, timing cover; flywheel; oil pump/oil pump housing; water pump; fuel pump; fuel level sensor; harmonic balancer; OHC carriers; valve covers; oil pan; engine mount; seals and gaskets. Also covered are turbocharger/supercharger housings, internal parts, valves, intercooler, seals and gaskets, diesel fuel pump, lines, nozzles and vacuum pump.
Transmission/Transaxle
Case, all internal parts; torque converter; transfer case; vacuum modulator; transmission mounts; seals and gaskets.
Front/Rear Wheel Drive Assembly
Final drive housing, all internal parts; axle shafts and axle shaft bearings; constant velocity joints; axle housing, all internal parts; propeller shafts; universal joints; wheel bearings; locking hubs; front differential actuator; supports; front hub bearings and rear axle hub bearings; seals and gaskets.
If you have a choice get it. My one rear diff would have costed me $5000 if I didnt have warranty.
Btw I have mods from headers to anything you can imagine except maggie and my dealership doesnt care.
GoodLuck!
  #2 (permalink)
Old 03-25-08, 08:10 PM
DILLIGAF's Avatar
Cadillac(s): 04 ctsV platinum,maggied,rt cats,headers,corsa,stealth tune
View DILLIGAF's Photo Album
Casino Cash: $14353
Re: Extended my Warranty at 139,000 Kms
Geeeeeezzzzzzzzzzzzzzzz,I'm pretty sure this board is pretty much dollars and miles.Could you post an easy conversion chart?
  #3 (permalink)
Old 03-27-08, 06:39 AM
Casino Cash: $1225
basically i got my car extended for 25,000 miles and currently i have 86000 miles on my car 8-)
  #4 (permalink)
Old 03-27-08, 01:25 PM
Dave-V's Avatar
View Dave-V's Photo Album
Casino Cash: $3432
That is a bunch of $ for 25000 miles. I have gone through 1 rear in 36K. You could but at least 2 for what you paid for that warranty.
Tags: , , , ,
000, 139, extended, kms, warranty
Censor is OFF
