| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Help V Wont Start
03-21-08, 01:37 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Help V Wont Start Ok so i go for a drive come home about 15 mins later get in my car put the keys in, all the lights come on like normal, turn the key and completely nothing except my engine light and the nav screen doing something weird. There is also a weird clicking noise coming from the fuse box when i try to lock/unlock the car with the remote. Tried to jump it and still nothing?? think theres a bad relay/ computer idk what does everyone think?? Thanks |
03-21-08, 01:42 AM
| | Cadillac Owners Connoisseur Cadillac(s): Kooks,MOMO seats,C5 hubs,3489# | | Join Date: Jun 2007 Location: Ashland, Ohio | | | Re: Help V Wont Start Original battery? Sounds like it is dead.
Norm |
03-21-08, 01:55 AM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Help V Wont Start Battery most likely.
Call roadside assistance.
__________________ I am so expensive I can't even afford to hire me.... |
03-21-08, 03:17 AM
| | Cadillac Owners Connoisseur Cadillac(s): Maggied 2004 CTS V Black Raven cause its faster | | | | | Re: Help V Wont Start Mine goes back tomorrow for similar issue. They replaced the dome light/dash dimmer switch Wed and thought that would do it.
Mine does only not start after sitting 16+ hours or so and it will start on a jump immediately. |
07-06-08, 11:54 PM
| | Cadillac Owners Member | | | | | Re: Help V Wont Start Hey guys, my car is doing the exact same thing.
Hooked up a battery charger and nothing. Hooked up jumper cables and nothing. Hooked up both at the same time and it started.
Battery is charged, dome light is bright. As soon as I put the key in the ignition and start to turn the power goes out and get some weird clicking sounds from the fuse box and throttle body.
When I pull the key out and wait 10 seconds there is a few more clicks and all the lights in the car come back on again.
Did anyone figure this out or did the dealer tell you what the problem was?
I just turned 51,000 miles; so Im guessing that I am screwed on warranty.
Curt |
07-07-08, 12:14 AM
|  | Cadillac Owners 10000+ Posts Cadillac(s): > BMUU | | Join Date: Mar 2007 Location: jersey | | | Re: Help V Wont Start you have some warranty left, if it ended at 50k you have some leeway |
07-07-08, 01:14 AM
| | Cadillac Owners Enthusiast Cadillac(s): 2004 Cadillac CTS REDLINE 2006 CTS-V Infared | | Join Date: Oct 2006 Location: Calgary, Alberta Age: 60 | | | Re: Help V Wont Start Check for bad battery ground. The low amp draw of the lights doesn't take a good ground. As soon as you try to draw heavy amps, the poor ground acts as a resistance and everything goes out. Could also be a battery with a bad cell although usually you wouldn't get lights to come on. |
07-07-08, 07:46 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Help V Wont Start With chargers/jumpers on these cars I doubt this is a battery issue.
Check the clutch switches, I have seen a few failures. If the spring breaks inside the switch they will do all sorts of funky things, one of them being not starting.
Apart from that if you don't know where to go, find a shop to fix it.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
07-07-08, 10:07 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: May 2007 Age: 23 | | | Re: Help V Wont Start I thought I was being a smart ass when I thought to myself "did you push the clutch in?" haha. I just got a new Jeep and didnt drive it for a week. After I installed the K&N and new PCM, I went to start it and forgot to push in the clutch... I felt like I was 14 and it was my first time driving a standard vehicle again.
__________________ 2005 CTS-V Black Raven w/ Ebony: Kooks Headers, Corsa cat-back, K&N CAI, W4M tune, UUC 2-piece front and 1-piece rear slotted rotors, Specter cradle bushings, UUC shifter/knob/bushings, HID fogs, ALL lights tinted, PC'd Accessory wheels/grills...
2007 Red Rock SRT8GC  With some mods
2009 Yamaha R1- Pearl white w/ red |
07-07-08, 02:48 PM
| | Cadillac Owners Member | | | | | Re: Help V Wont Start I decided to replace the battery before paying for a tow. Wasnt easy to find one, but a chevy dealer tracked one down.
Anyway, with a new battery it seems to be working fine. Check engine light is on, but I should be able to reset that. |
07-07-08, 02:51 PM
|  | Cadillac Owners 10000+ Posts Cadillac(s): > BMUU | | Join Date: Mar 2007 Location: jersey | | | Re: Help V Wont Start reset the check engine light by disconnecting the battery for a few minutes?
if so, then it would have gone away while you had disconnected the old battery to install the new one you bought from the chevy dealer. |
07-07-08, 03:03 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 CTS-V / 06 Escalade | | Join Date: Oct 2007 Location: So Cal - Agoura Hills Age: 26 | | | Re: Help V Wont Start Had something similar happen to me on a previous car (wrx) Replaced the Battery, and it started right up, but I couldnt get it to turn over with jumper cables. |
07-07-08, 03:22 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Help V Wont Start Quote:
Originally Posted by 1QWKZ28 I decided to replace the battery before paying for a tow. Wasnt easy to find one, but a chevy dealer tracked one down.
Anyway, with a new battery it seems to be working fine. Check engine light is on, but I should be able to reset that. | Check on the CadillacFAQ ( www.cadillacfaq.com ) http://www.cadillacfaq.com/faq/answe...ryreplace.html
__________________ | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
