Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: clutch pedal switch, code P0833
Old 03-18-08, 11:46 PM
Ronsv's Avatar
Cadillac(s): Black on Black 07 CTS-V, CAI, Kooks, Corsa and TTP tune
View Ronsv's Photo Album
Casino Cash: $495
Cruise control would not come on, next day MIL light comes on, I pulled up code P0833 - Clutch Pedal Switch B circuit. I took a look at the clutch pedal and saw what looks to be the clutch pedal switch floating on the clutch pedal shaft. Is the switch supposed to ride up and down on the pedal shaft, or should it be attached to the firewall? Anyone else have this problem?? Hate to go to the dealer and risk having them wipe my custom tune out. Rather fix myself.
Thanks!!
  #2 (permalink)
Old 03-19-08, 02:40 AM
mcfaddens17's Avatar
Cadillac(s): 2005 CTS-"V"
View mcfaddens17's Photo Album
Casino Cash: $2010
Re: clutch pedal switch, code P0833
Had same issue with my clutch switch. Dealer repaired under warranty. Computer thinks the clutch is always engaged due to the bad switch, which is why the cruise control will not work. I'd probably talk to your dealer to see if they would have to wipe your computer tune with the repair before trying to make this fix yourself.
  #3 (permalink)
Old 03-20-08, 12:14 AM
Ronsv's Avatar
Casino Cash: $495
Thanks for chiming in Mcfaddens17, the dealer would certainly not have any reason to delete my tune to fix my car, however during the diagnostic process they would probably scan my computer and see my post O2's are turned off and that would alert them that something is up. I then risk having my warranty voided. If the replacement of the clutch safety switch is not too expensive, I would rather do it myself and avoid the issue stated above.
Looked on alldata to see the procedure on changing the part, but they only show a diagram of the switch, not how it is oriented on the clutch shaft, i.e is the switch supposed to float on the shaft (as it is now) or should it be anchored at the firewall?
Any help would be greatly appreciated!
  #4 (permalink)
Old 03-20-08, 08:51 AM
oh brother...
Cadillac(s): GROO-V
View Redline CTS-V's Photo Album
Casino Cash: $10589
This should help...
  #5 (permalink)
Old 03-20-08, 02:10 PM
Cadillac Owners Enthusiast
Cadillac(s): 04 CTS-V
View rangerrob's Photo Album
Casino Cash: $6685
Thanks!!
will the dealer wipe out a custom tune anytime you take it in for anything??? this would be good to know, especially since i'm taking mine in tomorrow to have them replace the rear bushings... thx
  #6 (permalink)
Old 03-20-08, 07:22 PM
The Tony Show's Avatar
How YOU doin?
Cadillac(s): 2007 SRX (Previously 04 CTS-V)
View The Tony Show's Photo Album
Casino Cash: $18620
Even if they plug the Tech2 in to diagnose the clutch switch they're not going to see the rear sensors turned off- that's in a totally separate menu in the Tech2, and they wouldn't have any reason to go there.
The only thing that would wipe out a tune should be a reprogram of the PCM. Unless they're doing the oil temp bulletin or something else software related I don't see any reason the PCM would be reflashed.
  #7 (permalink)
Old 03-20-08, 11:16 PM
Ronsv's Avatar
Casino Cash: $495
Originally Posted by Redline CTS-V View Post
This should help...
Thanks for posting Redline!
Tonyshow, promise?
Since I have to bring my car in for the rear diff recall, might as well have them fix the clutch pedal switch too.
Thanks to all who responded!
  #8 (permalink)
Old 03-20-08, 11:54 PM
Cadillac(s): Cadillac CTS V
View mgscustomtune's Photo Album
Casino Cash: $2855
Ok guys being a tuner l have to speak up here. There is a very little chance they will reflash your tune. When they replace the switch they will just clear the code, The dealership will not waste there time reprogramming the pcm. If you do it yourself, after you replace the swtich start up the car if it does not clear disconnect your battery 10 min then code will be should be gone. If that does not work get someone with the tech 2 to clear the code. To be honest l wouldn't even hesitate to take it to the Dealership if the tuner stayed within the parameters everything will be ok to them. As Tony stated there is no reason for them to do so
  #9 (permalink)
Old 03-21-08, 12:02 AM
Casino Cash: $2855
I am actually amazed that people are worried about bringing there cars back to GM after a Custom Tune. Things must be different up here in Canada because l have GM Dealerships refering Customer to me to have there cars/trucks performance tuned.
  #10 (permalink)
Old 03-21-08, 12:56 AM
Ronsv's Avatar
Casino Cash: $495
Thanks for your input, I have a very nice data logger and scanner so clearing the codes is a piece of cake. With regards to the tune, I too am a tuner, however not with HP tuners or the LSx platform. I do quite nicely however with datamaster and tuner cat on my 92 lt1 corvette. Sadly, the dealers around NYC will go out of their way to void a warranty. I am not nearly as concerned about a tune re-flash as I am about the hassles of them attempting to void my warranty. Glad to hear that things are better up north.
  #11 (permalink)
Old 03-21-08, 02:49 PM
Casino Cash: $2855
I use the HP on the 06-08 Duramax/Topkicks/Kodiaks only. I like the GMT Tuner Software it alows me to do eveything from GM 1995-2008. Also l have the Ford Editing Software. For the older vehicales l use Tunercat and Williams. I allows thaught there was laws down there so you can modify your Cars in the USA.
Tags: , , , ,
clutch, code, p0833, pedal, switch
Censor is OFF
