| Re: TSB for Transmission replacement? I had mine replaced under the TSB as well... it was more of a vibrating very low drone at 60-70 mph in 6th gear... they tried balancing the driveshaft first, that didn't work, so I had them replace the transmission after I did some research on the issue.
They replaced the tranny and I took it out and to my surprise it was worse... turns out they left the balancing weights on that they had tried before they replaced the transmission... they knocked those weights off and all was perfect again...
Jay |
