| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: TPS RESET, Saw Faq, Still Have One Question
03-05-08, 11:42 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | TPS RESET, Saw Faq, Still Have One Question So I reprogged my TPS sensors as they werent displaying the tire pressures. It indicated to end on the rear left tire, I however had to end on the rear front right tire.
FAQ:
FL
FR
RR
RL
ME:
FL
RR
RL
FR
Im assuming the my sensors are in the wrong rims. Does this mean that the pressure displayed for the FR tire is really the pressure for the RL tire?
Thanks |
03-06-08, 12:11 AM
|  | Caution: Woman Driver Cadillac(s): '10 SRXy; Previously '07 3.6L CTS | | Join Date: Sep 2006 Location: Keep Right™ | | | Re: TPS RESET, Saw Faq, Still Have One Question Um, why didn't you just follow the instructions?  |
03-06-08, 12:13 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: TPS RESET, Saw Faq, Still Have One Question I would just re-do it the correct way. Since they use an RF signal, or whatever, I'd imagine there's a reason for doing it in a specific order. The computer probably sets them in a specific order. After you set each tire, I think you can go look and see which one is registered and which isn't. At least, it appears to be like that, in the instructions. They can't be on the wrong rim, I don't think they have to be on a certain one, just have to be registered in an order. |
03-06-08, 12:38 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: TPS RESET, Saw Faq, Still Have One Question The computer learns them in a specific order. That order is LF, RF, RR, LR. Each sensor sends an individual RF signal and is learned by the computer in that order. This is so you can replace the sensors or reprogram the computer when you rotate tires.
Almostav - You can simpy let out some air from each tire, one at a time, and see which one has changed on your display. |
03-06-08, 12:44 AM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: TPS RESET, Saw Faq, Still Have One Question I tried doing it the correct way....Im not that ignorant! heheh...the only way to get the double honk was to finish with the front right. |
03-06-08, 12:57 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V | | | | | Re: TPS RESET, Saw Faq, Still Have One Question Did it work correctly? Is it reading the pressures for the correct wheel placement? Sometimes the TPM systems do some funky crap. We deal with them everyday here at an assembly plant. |
03-06-08, 01:45 AM
|  | CTS-V Owner Cadillac(s): 2007 Cadillac CTS-V | | Join Date: Sep 2007 Location: Monterey, CA | | | Re: TPS RESET, Saw Faq, Still Have One Question The order in the FAQ is correct. Plus the entire procedure is also spelled out for you in the owner's manual. It has taken me a few tries to get the first honk to start the sequence. However, once it gets going, it will work. The key is to let the air out of each tire for a bit (3-5 secs) then wait for the sensor to read the new data. If you don't get an acknowledgement honk right away, let a little bit more air out. And then wait for the honk. Shouldn't take more than 30 seconds per tire. |
03-06-08, 01:44 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: TPS RESET, Saw Faq, Still Have One Question Had to let a bunch of air out when I did mine, but it worked. Seemed like more than 5 seconds. I held the pin down till it honked.
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
