Results 1 to 12 of 12
Thread: Clutch question. will hold 550rwhp?
    v10boost is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jan 2008
    340
    HI guys,
    right now my car is at Lindsay because it might have rear main seal problem. If it does, I am thinking about doing different clutch setup.
    first is uuc flywheel and factory V clutch and pressure plate. Second is going with all z06 stuff with spacer. I know they are both lighter than factory V dual mass. So will these setup hold 550rwhp? If not what other options do I have? I need to get it done asap.
  2. #2
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Re: Clutch question. will hold 550rwhp?
    Good luck, that is gonna be some clutch.
  3. #3
    CTSV_Rob's Avatar
    CTSV_Rob is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 CTS-V Thunder Gray; 2004 Cowboy Cadillac (SRT10)
    Mar 2007
    Sunny CA.
    50
    17,682
    550 rwhp on the sotck clutch, No. Wish I had more for you but Lunarx is working with a sweet setup if he can get the bugs worked out.
    I hope someone posts to this with something constructive, not sure how to proceed myself.
  4. #4
    gcoan's Avatar
    gcoan is offline Cadillac Owners Member
    Automobile(s): 07 CTS-V
    Apr 2006
    50
    I have 500 rwhp and the ZO6 clutch very smooth easy to drive no shudder. Tried spec stage 3plus maybe a little stronger but harder to drive without the shudder.
  5. #5
    CTSV_Rob's Avatar
    Mar 2007
    Sunny CA.
    50
    17,682
    Still have the Spec3+ in your sig gcoan. No biggy, just thought you might want to know.
  6. #6
    gcoan's Avatar
    Apr 2006
    50
    Thanks corrected
  7. #7
    CTSV_Rob's Avatar
    Mar 2007
    Sunny CA.
    50
    17,682
    Good to know about the Z06 clutch though, how heavy is it do you remember?
  8. #8
    STAGEUP is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Mar 2007
    Mesa, AZ
    428
    The stock V clutch should be good for about 480whp, thats it.
  9. #9
    CTSV_Rob's Avatar
    Mar 2007
    Sunny CA.
    50
    17,682
    As much as 480 WHP? Sweet, I'm good until the engine gets upgraded.
    I'm guessing at 480 the clutch won't last too long though.
  10. #10
    lunarx's Avatar
    lunarx is online now Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s, 07 Legacy GT Wagon
    Aug 2006
    SoCal
    1,739
    Just do the UUC FW w/ Stock V clutch.
    I never heard of a single regret on that option.
    The LS7 clutch isn't good for much over 425 WHP.
    LS7 and V clutch are not much different.
    Why do unnecessary mods when a factory fit solution like the UUC exists?
    Later when you get to 550WHP, you will want a Twin Disk and will wrestle with the drivability vs. power holding vs. cost equations.
  11. #11
    NormV is offline Cadillac Owners Connoisseur
    Automobile(s): XTS VSport-550+ lb-ft of torque, ATS 2.0T AWD HPTuners tuned
    Jun 2007
    OH-IO!
    2,654
    Usually it is not so much hp that causes clutches to slip, but torque. So if someone is advertising how many hp a clutch will hold I'd ask how much torque will it hold. If they can't answer look elsewhere.
    Twin turbos are a problem as can create a large amount of torque quickly.
    Norm
  12. #12
    PISNUOFF Guest
  • You may not post replies
